Question about Pelco 300 Computers & Internet
I have a Pelco PMCL542A 42" monitor that power led is on but screen is black
Monitor is plugged in and the power LED is lit up, however, the screen is dark and not activity is on the screen.
SOURCE: Green Power LED is lit- But no image on the screen
Hi, I have just repaired one of these with the same problem. Turned out to be a 680uf 25v capacitor that had failed. Capacitor was visibly domed. Easy repair with new capacitor. Hope this helps.
Posted on Sep 28, 2008
Fix-4U
  • 293 Answers
SOURCE: ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Posted on Oct 12, 2008
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
  • 414 Answers
SOURCE: E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Posted on Mar 25, 2009
  • 1684 Answers
SOURCE: syncmaster 225ms LCD monitor is blank
It sounds like you have a monitor with a common problem. After a few years some LCD monitorswill blow a power supply. The problem is caused by parts calledcapacitors overheating in the confined space of he monitor. If you aregood at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htmYou can take the back cover off your monitor and look for the badparts, replace any that look like the pictues and your monitor shouldwork fine. The capacitors do need to be installed with the correct +and - connections, note the stripe on the old one and insert the new onethe same way. If you don't want to try the repair yourself we offer arepair service for $35 plus shipping. I hope this helps, if so pleaserate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 20, 2009
How do I reset KBD300 pleco keyboard
To initialize the keyboard, wait five seconds after powering-up the CM6700, enter the number for the
monitor you are viewing (1-4), and press MON. The LED display shows the number entered.
NOTE: You must re-initialize whenever power is cycled.
Source: http://www.jmacsupply.com/v/vspfiles/files/PMFiles/Pelco/Instructions/KBD300A-InstallationManual.pdf
Jan 15, 2015 | Pelco Kbd300a Pushbutton Control Keypad W/...
I have a Pelco PMCL542A 42" monitor that power RED led is on but screen is black
Lcd tv's Do that when the backlight bulb is out. There should be a small panel on the back. Order a new bulb and replace it and it should work fine.
Dec 05, 2014 | Pelco PEL-PMCL542A-S 42-Inch Liqued...
What is the best brand of monitor without lot of problem like black screen orange stand by light?
Any known brand, such as Samsung, Dell, Acer etc.
The main thing with monitors these days is to choose one that is LED back lit. LCD's use inverters that are very power hungry and they tend to burn out capacitors after a couple of years of use.
LED how ever are very low energy and don't need an inverter circuit to power the LED's, thus MUCH better life time.
Apr 30, 2014 | Computers & Internet
Screen stays black but lit when shut down
If the monitor led is indicating stand by and it seems as if the monitor is still on, could be a sign of an aging monitor. As long as the led changes along with the function of the monitor there's really no way to indicate the monitor still on after shut down especially when the led is amber telling you it's on standby mode.
Mar 01, 2014 | Acer Aspire Zs600 All-In-One Desktop Pc,...
My Samsung SyncMaster 740N occasionally turns itself off. Timing varies and the condition varies. Usually the screen just goes black - from seconds to hours after it is turned on - the blue LED remains...
This could be because of the 'eco' friendliness of the monitor. Basically a lot of monitors are designed to turn off into a low power state when not in use so to preserve power and life of the monitor. I would return the monitor as the sensors that control this seem to be broken in your monitor.
Mar 15, 2011 | Samsung SyncMaster 740N 17" LCD Monitor
I have the VE278Q which is connected by display port, every time i turn off my computer and then turn it back on the monitor can't be found, I have to unplug the display port cable, unplug the monitor,...
when you say monitor can't be found did you mean the monitor has no reactions when you turn on your pc?
here are some test you may need to do to know which part is faulty
1. Turn on your computer, did it display the monitor's logo on screen? When it does monitor is good, when only blank screen it could be the vga cable or the video card.
2. See if the led indication lit. When it lit to steady green, it's good signal is coming in from the video card. It should be followed by screen display. If no display it could be the backlight inverter lamp busted or faulty inverter board. When lit green then turns red, no signal coming from the video card. Check vga cable if fix properly to both monitor and video card. Or may need to reseat properly connection of video card from the motherboard. If no led indication lamp, then monitor is dead. Check ac power cord for continuity using multitester. Check power supply section in the monitor, replaced bulged or blown capacitor with exact value, this components were the first to get affected when lcd monitor failed o turn on.
3. When computer was turned on got display and then monitor turns black, go check the vga cable, Fix the connection properly or may need to replace it with new one.
4. When no signal appears or display blank screen after logo, then check video card. First remedy is to disconnect it the reseat properly to the motherboard. If this have no effect change your video card.
go follow these steps and let me know which is closely to your problem so I can give you a good advise.
Jan 30, 2011 | ASUS LCD Monitor
How do I turn it on
Hello.
To power on the Gateway VX750, press the power button on the front. The power button has 3 sides with a "G" in the middle.
The LED indicates the power status of the monitor.
  • Not lit - The monitor is turned off or does not have power connected.
  • Blinks one time and then goes off - The LED blinks one time when the monitor's power cord is plugged into an AC outlet to indicate that power is detected.
  • Lit solid blue - The monitor is turned on and active.
  • Blinking blue - The monitor is in power saving mode. Before entering power saving mode, a message briefly appears.
Hope this helps.
Aug 12, 2010 | Gateway VX750 (Black, Platinum) 17" CRT...
Black Screen on the monitor
did you drop or hit the laptop recently?
Try using a flashlight. If you can see the images in the screen, the light behind the LED screen is burnt. If you can't, try attaching a full size external computer monitor and see if it works. If it doesn't, then you may have a bigger problem than just your screen
Mar 27, 2010 | Acer Aspire One PC Notebook
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
Black screen
Try pressing the 3rd button, as it toggles the Analog or Digital inputs...
Oct 05, 2006 | Dell 1703FPs 17" TFT LCD Flat Panel...
Computers & Internet Logo
54 people viewed this question
Top Pelco Computers & Internet Experts
David Payne
David Payne
Are you a Pelco Computer and Internet Expert? Answer questions, earn points and help others
