Question about HP Compaq Presario V2000 Notebook
Replace hd on a v2000 with a Momentus 7200.1 Hard Drive 80GB 7200rpm 100MBps Ultra ATA/100 (ATA6) Ultra ATA/100 (ATA6) IDE/EIDE Internal will it work?
    Problem Solver:
  • 16 Answers
It should,
Posted on Jan 03, 2013
3 Suggested Answers
joecoolvette
  • 5660 Answers
SOURCE: HOW TO REMOVE Momentus 4200.2 100 GB ATA hard drive
From HP Support, and me, (I'm looking at the Service Manual for the HP Pavilion dv8140us right now)
(Laptop facing you in normal position, laptop is closed. AC adapter removed if being used. (Charger)
Work on a table, lay a lint free soft cloth down. Turn the laptop over, lay it on it's top cover.
The back of the laptop is facing you now. The hinges are towards you.
1.Remove the battery.
Slide, and hold the battery release latch to the release position.
2.Lift the Front edge of the battery, and lift it out of the battery bay.
There is a large Panel, or compartment cover, on the side of the laptop facing you. This is the Battery Compartment Cover, for the Battery Bay.
Right above it, on the right side is a Slide button, or Battery Release Latch. Slide it to the right, hold it there.
List the panel edge of this cover, that is away from you, swing it up to remove it. Set the Battery aside.
On the opposite side of the laptop is the Harddrive Compartment Cover. Has three Philips head screws along the edge.
Use a Small Philips head screwdriver, (+), to remove them. The size of the Philips head screws are P1. Use a P1 Philips head screwdriver. (Small)
DO NOT, under ANY circumstances, use a Magnetic screwdriver!!
These three screws are on the panel's EDGE facing away from you . One in each corner, and one in the middle. Remove them with a Small Philips head screwdriver. (+)
They may not all come out all the way. One or two may just come up so far. It's okay. I advise do not turn the laptop over to remove them. They could bounce off the table, and join other mysterious objects that seem to just disappear!
Lift the panel edge of this compartment cover, that has the screws in it. The edge that Faces you. Lay this cover aside.
When you look down in there, you are looking at the Harddrive. There are Two Philips head screws on one edge. Remove these. You may have to carefully use a pair of tweezers, to grab them out of there. Do Not drop them.
Now slide the harddrive out of the connector. It slides towards the side that had the screws.
BE VERY CAREFUL at this point! You can easily bend the small metal pins! Even if the harddrive you're removing isn't any good, the connector in the laptop is.
Slide the harddrive back as far as you can out of the connector. Lift the back, (Where the screws were), up to a 45 degree angle, then keep sliding the harddrive out.
To install, tilt the harddrive at a 45 degree angle when installing also. Be SURE it lines up with those pins. You bend them, and you'll be very angry.
If you need more assistance, I'm right here.
Posted on Nov 03, 2009
Testimonial: "thank you so much for taking the time to help me out."
Muzzi_123
  • 749 Answers
SOURCE: Hard drive compatibility with compaq presario v2000
Hi this hard drive will work with your laptop all it needs to be is to have a SATA connection cable
2.5 inch = laptop
3.5 inch = Computer
Hope this helps
Muzzi_123
Posted on Nov 14, 2009
Testimonial: "Thank you for the advice!"
I've been noticing a squeaking sound intermittently
Good day,i think the problem would be you hard disk sir,better to change a new one.tnx
Aug 16, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
Can not read
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Feb 05, 2011 | Seagate Barracuda 7200.10 ST3160815A -...
I want to detect driver Thanks
There is _NO_ need for any additional device-driver -- Windows "natively" supports all disk-drives.
Dec 17, 2010 | Seagate Barracuda 7200.10 ST3160815A -...
How to read date codes
date codes are usually only 4 characters long so this one is the 48th week of 2007 the last 4 maybe the day of the week.
Dec 14, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Firmware update for Seagate Barracuda 7200 10 80 gb ultra ATA. I got problem due to firmware detection. the firmware on the Hard disk said it going with type 3.AAC, but when I try to open with Sea tool, it...
Dear FixYa team,
Thx for your kind offering to me. I already call my friend to help me here. And he seems already found the solution. The problem was comes from USB cable malfuction, and I think it somehow affect the firmware detection. Gladly he can back up it again with another harddisk, just try to baiting it to make the firmware read. Now I'm still waiting for data recovery only. I'm so sorry that I can't use ur helps now, coz I needed it in hurry. Thx
Regards,
Angeliczone
Jun 26, 2009 | Seagate Barracuda 7200.10 - 80GB - 7200rpm...
Hard disk drive
try reading the hard disk drive myths....it may explain more.
http://www.techarp.com/showarticle.aspx?artno=84&pgno=1
Feb 04, 2009 | Seagate Barracuda 7200.10 - 250GB -...
HP Compaq Presario V2000 Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
