Question about Dell Dimension 2400 PC Desktop
Belkin wireless adapter
My dell runs fine and works well conneted to my westtel router with the ethernet cable, but not the belkin wireless adapter. That connects and disconnects every few seconds. Other computers run fine in the house. I reset the modem and even downloaded the new belkin driver, but no change. please help, any suggestions
    Scholar:
  • 57 Answers
Sometimes wireless phones will interfere with the signals. If the router or PC is anywhere near a phone, it might have a problem. I have one wireless network card that gives me fits like that. I have yet to get a PC working with it. I have other wireless cards that work fine. I also switched to 5GHz phones, which helped my old laptop. Check to make sure there's not a conflict with the encryption used by either the dell or the router.
Posted on Jan 23, 2009
My Dell desktop using Windows XP can't connect to my Belkin 5720 router but my laptop still works?
This sounds like a hardware failure, but just in case go to your computer Control Panel-Network Connections(Network and Sharing Center for Vista and above), and check your Network adapter settings. If your Network card is not showing, you may have a driver issue, or a bad NIC (Network Interface Card). It shouldn't matter that your router says" wireless hardware not detected", because you are hardwired from the computer to the router. I would check to see if you may have turned off, or blocked Ethernet connections on your router, I would then change my Cat5 (Ethernet) cable, and finally open the desktop and change out the NIC (Network Interface Card).
Mar 24, 2012 | Belkin Computers & Internet
Can I connect my USB Modem to my Belkin n300 Surf? do I need an adapter to connect it??
It is not possible to connect your USB modem to belkin router... You need to run an ethernet cable between the modem and router...
Belkin routers are not compatible with USB modems like cricket broadband, MTS Mblaze modem etc...
Jan 23, 2011 | Belkin Wireless Surf Router (F7D2301)
Cant get connected with my belkin router...all i can get is "connected with limited access
HI
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router
1. Step 1 Position your Belkin wireless G router.
Place your wireless G router in a wide open and central location. Don't connect the power plug into the router, yet. Make sure your computer is turned off.
2. Step 2 Connect all the devices.
Find the Ethernet cable that connects your PC to the modem. Unplug the Ethernet cable from your PC and insert it into the wireless G router's WAN port. You should have an additional Ethernet cable that came with your router. Take this cable and plug one end into one of the LAN ports on the router. Then connect the other end to your PC's Ethernet port.
3. Step 3 Turn on your modem, router, and PC.
Plug the power plug adapter into the modem. Turn on the modem. It'll take approximately 30 seconds for the modem to boot up. Connect the power plug adapter to the router and the other end into a power strip or outlet. Like the modem, it'll take about 30 seconds for the router to boot. Turn on your PC.
4. Step 4 Verify lights are on for your devices.
Make sure the following lights are on for your router: power, WAN, and LAN light. If you don't see any of them lit, confirm these devices are turned on. Make sure the Ethernet cable connections are installed correctly.
Step 5 Install and configure software.
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure ?other settings
Oct 18, 2010 | Belkin N1 Wireless-N Wireless Router
Wired connection randomly drops
Since the wireless works fine on your router, then it is possible that there is a problem either on your ethernet cable or on the port of the belkin router.
Try a different ethernet cable. (Ethernet cable is the one that is connected from your computer to the router.) If you don't have a spare cable, you can directly connect the computer to the modem, just to isolate the issue and determine if it is the cable or the computer itself.
If you have determined that the cable is working fine, then try a different port on the router.
I hope this helps!
Jul 24, 2010 | Belkin F5D7234-4 Router
Security
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} How to quickly install and use your Belkin wireless G router 1. Step 1
2. Step 2
3. Step 3
4. Step 4
5. Step 5
Use the setup wizard application to configure your Belkin wireless G router. Set up features, such as creating your password and setting up your time zone. Continue to follow the setup wizard so you can configure  other settings.
Jul 23, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
How do I hook up a Berklin wireless router to my comcast internet
Use an Ethernet cable to connect the port on the Comcast modem to the WAN port on the Berklin (Belkin????) router.
Use another Ethernet cable to connect one of the LAN ports on the router to the Ethernet port on your computer.
Start Internet Explorer on your computer.
Connect to the web-interface inside the router.
Run the "network setup wizard".
Run the "wireless setup wizard".
Nov 17, 2009 | D-Link 802.11g Wireless Router WBR-1310...
We have just signed up for cable TV/high speed internet/cable telephone. The modem provided is an "Arris" version 1.5. The cable tech said I could connect my Belkin G router so that more than one computer...
Plug the ethernet net cord into the arris ethernet port. plug the other end into the router where it says "internet"
Plug a ethernet cable from one of the router ports to the computer.
First start up the arris modem, then power up the router, then start the computer.
Oct 22, 2009 | Belkin 802.11g Wireless Desktop Network...
Brand new linksys wireless, Host (Hard wired)has intermittent connectivity. Indicates it is conneted and is working properly.Cannot browse Web. The wireless part works great!
try to plug the Ethernet cord for the Host computer on another Ethernet port on the Linksys router.
have you tried replacing the Ethernet cable that's connecting the Host computer to the linksys router?
check if Host computer can get a response from a website by going to Start>Run, then type CMD on the Run box and click OK. On the black screen, type PING www.yahoo.com then press Enter.. if you get the word reply 4 times, it means the computer is connected to the Internet.
If there's no response from the PING test, it means there's totally no connection.
It's also possible the problem is with the Local Area Network adapter or Ethernet adapter. Try disabling the Ethernet adapter and re-enable it by going to Start>Control Panel>Network Connections, you should see the Local Area Connection, right click on it then select Disable then Enable it again. then observe if you're still experiencing intermittent connection on the Host computer.
and if you have security software, try disabling it temporarily and check the connection again.
and let's make sure the cable or dsl modem is connected to the Internet port on the back of the Linksys router.
May 10, 2009 | Linksys WRT160N Wireless Router
Can't configure belkin n wireless router.
yes always best to use ethernet when you can.richardm69
Feb 03, 2009 | Belkin N1 Wireless USB 2.0 Network Adapter...
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Dell Dimension 2400 PC Desktop Logo
144 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
