My furnace makes a loud noise on start up
My furnace blower makes a really loud noise on start up. well now it keeps making this noise. im not sure what to do i turned it off till we figure it out
    Genius:
  • 1,033 Answers
What kindof sound? Is it a squelling kind of sound?
Posted on Jan 03, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
  • 80 Answers
SOURCE: heater motor,fan making noise
Check to see if something is in the fan blades that is throwing it off balance. Also check the belt to see if it is ready to break.
Posted on Oct 02, 2009
james3751
  • 614 Answers
SOURCE: My cozy furnace makes a loud clicking noise every
Wall furnaces sometimes do that it is just expansion and conttraction of furnace. rus
Posted on Mar 17, 2010
  • 415 Answers
SOURCE: FURNACE MAKES STRANGE INTERMITTENT CLICK SOUND
Looks like an older system. Tighten all of your electrical connections. Inspect all of the low voltage wiring for any insulation cracks or other damage. The problem you describe sounds like something is either "shorting" or breaking down electrically. Unless the technician can catch it while he/she is there, it will be difficult to determine exactly what is happening. You might get lucky and resolve it yourself by tightening all electrical connections and reinsulating (use electrical tape) any damaged low voltage wire connections. If you continue to experience problems, get the tech. Hopefully the last company you used will be willing to work with you on the bill considering they were unable to "catch" it during the last visit.
Without being there with toolbox in hand, I hope you find this information very helpful moving forward. :-)
Posted on Mar 19, 2010
Testimonial: "Thanks for taking the time to answer my inquiry. I'll let you know how it works out."
  • 415 Answers
Measure the voltage to Terminals #2 and #3 on the main gas valve. If the voltage remains consistent while you hear the sound and the burners diminish slightly, the problem will be your main gas valve. If the voltage fluctuates, you will have to trace it back through the wiring to see through which switch you are losing it.
If this furnace has a hot surface ignitor with flame sensor, try cleaning the flame sensor with some emory cloth.
I hope you find this information to be very helpful as a good starting off point for you.
Please leave a rating. :-)
Posted on May 14, 2010
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
We have an amana ac. It recently started making a loud noice from the furnace closet which is upstairs. 2 different ac repair companies came out but could not find anything wrong. The line to the outside...
Hello, if the line is freezing there is either a airflow problem or low refrigerant charge. If there is a loud noise most likey the bearings on the motor or the blower wheel is bad and causing a lower amount of air passing over the evaporator coil and thus the freezing of the suction line.
Jul 15, 2012 | Heating & Cooling
Our Goodman furnace just started making a a very loud grinding noise when the furnace turns on. Also the temperature in the house keeps dropping so we have to keep adjusting teh thermostat. Any advice on...
If it makes the noise before the blower comes on it would be the exhaust fan. If it makes the noise when the blower comes on then I would say either the blower motor or bearings to the fan.
Dec 27, 2010 | Goodman GMS90703BXA Heater
Loud vibrating noise when the furnace blower starts up.
Try closing damper slightly between humidifier and furnace????
Feb 03, 2010 | Aprilaire 550 Humidifier
Loud noise when furnace starts but furnace won't come on.
Your fan delay relay has failed and must be replaced.
Jan 16, 2009 | York Yankees Bedding MLB Comforter
Loud humming noise
when was last time furnace was serviced --air filter change burner area cleaned vacuumed the hum can be a few reasons ---fan bearing need service [ oiled ] fan bracket bushings damaged or loose --burner out of adjustment burning improper etc these are a few
Jun 03, 2017 | Heating & Cooling
FURNACE MAKING LOUD NOISES
My weathermaker started making a screeching noise and intermittantly would shut down, without blowing any heat. I found the sediment trap clogged and the induction motor was churning through the backed up condensation water. This slowed the motor down and the pressure switch would not stay closed. Unclogging the trap and hoses solved the problem. A bunch of water came out when I disconnected the collector box drain hose, along with gobs of sticky crud. Works great and is quiet now.
Dec 06, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Dec 11, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
451 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
