Question about Whirlpool Microwave Ovens
My new microwave oven will not heat up any thing not even water
I bought the oven from BrandsMart USA. it was shipped by th estore to Barbados where i live. when it arrived here i found that the oven is not heating up anything. what do i do?
    Problem Solver:
  • 9 Answers
Return it. If it already doesn't work then there is clearly a problem. Go for Panasonic, they are a trusted company and I've had my Panasonic NN-SD372S for a year and a half and couldn't be happier.
Posted on Jan 04, 2013
MicrowaveSvc
  • 9047 Answers
SOURCE: the microwave does not heat
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
For Kenmore models, you can usually find an exploded view by entering your model number here: http://www3.sears.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Nov 28, 2007
SOURCE: Microwave oven does not heat anything
Spacemaker XL 1400 worked for 7 years.Yesterday, no more heat. Also plastic door damaged.
will try Panasonic or something commercial
Posted on Aug 14, 2008
  • 52 Answers
SOURCE: Microwave oven not heating
Return from store that it was purchased from. it is unfit for purpose
Posted on Feb 21, 2009
SOURCE: microwave oven not heating
micro does not heat
Posted on Mar 02, 2009
  • 36 Answers
SOURCE: my microwave onen is not heating anything
I would suggest that the overheat stat on the magnetron has blown. If you are happy it's a simple thing to do but just make sure you disconnect from the mains before removing the cover and make sure that the High voltage capacitor is discharged. If you are not sure a qualified service tech will be able to fix this for you at little cost.
Hope this helps
Posted on Jan 07, 2010
Testimonial: "I think you have the right solution for my problem with the microwave. Thanks a lot."
I have aclock on a frigidaire microwave that is loosing time
A defective clock would be the cause, the voltage is regulated by the oven circuit board, so line voltage would rally need to be way off to affect the operation of the clock. Ranges of line voltage here in USA are 110V-120V
Jun 23, 2016 | Frigidaire Microwave Ovens
Why does my brand new microwave produce lots of internal moisture when heating ready meals?
The new oven is providing more heat to your food, causing more water to boil out of it by the time it is done. It may be OK to shorten your cooking times in response to the higher power efficiency if it bothers you. Then again, maybe you bought a microwave steam oven. They're cool.
Feb 23, 2015 | Microwave Ovens
My new Haier microwave isn't working! I just plugged it in for the first time, and set the clock on it. Then I tried to turn it on. No matter what cook time I enter, and then press start/30 sec., nothing...
When it times down but doesnt heat it is typically a problem with the door switches, especially one you just bought, may have been from shipping . A switch or connection may have been disodged when being shipped to you. Most machines have something like 4-5 wswitches, If 1 doesnt report right it will stiop the unit from running. But since some of them are closed it will accept the programing and try to operate. So a lot of times you get fan running and tray turning but no power to the secondary circuits. You will need to find out who does warranty for them or return it where you bought it as a defective unit.
Aug 14, 2017 | Haier Microwave Microwave Oven
All leds, timer, fan etc working but microwave will hot even heat water. Control panel, turntable and light inside oven works also.
The problem is one of three things, the magnetron is defective "common issue" or the high voltage capacitor and diode may be a factor, repairs could be close to a new microwave oven.
Feb 20, 2011 | Whirlpool MH6130XEB/Q Microwave Oven
I bought I microwave in the USA and I had it installed in my home in Brazil and appers working well but it doesn´t heat. What I could do to solve this problem?
Was it new? normaly when a microwave deos not heat it means the magnetron is dead (that's the part of the oven that produces the microwaves) or it could be a burned fuse, if it's a dead magnetron it is almost as expensive as a new oven.
Jan 04, 2011 | Samsung SMH9187ST Microwave Oven
Microoven model 860A is not getting heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101p][p[]p
Feb 25, 2010 | Daewoo KOR-860A Microwave Oven
Our microwave oven started making a loud sound and quit heating
heatman101==]-]=-
Feb 14, 2010 | Emerson MW8107WA Microwave Oven
Sparks coming from back of microwave
If you coffee container had any metallic logos or paint on it sparks will occur. Try to heat water in the glass container.
Dec 11, 2009 | Daewoo KOC-925T Microwave Oven
Burning smell and won't heat.
If it buzzes real loud it's probably the high volyage diode. However some times if it smells it's the transformer. Usually the diode is a cheap fix ~$10.00 but this model the diode is $50. It's number 50 on the link below. Let me know how it works out or you need anything else.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=JVM1440BH01&productCategoryId=0123370&brandId=0432&modelName=MICROWAVE&diagramPageId=00001&documentId=G0312014&pop=flush
Apr 19, 2009 | GE JVM1440 Microwave Oven
Product JVM1440WH04 - Heats but internal fan seems to not be working
GE Customer Service is at GE Customer Service is at http://www.geappliances.com/service_and_support/contact/
I recommend that you contact them to find a local GE-authorized servicer.
Apr 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
26 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jaime Hernandez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
