Question about Simplex Kaba Ilco Unican 1000 keyless lock
Need to change the code on a trilogy dl2800 lock
I need an instruction to change combo code for Trilogy Alarm Lock T2 TRILOGY
You will find installation and instruction manuals on this web page:
http://www.alarmlock.com/tech_library_instruction_manuals.asp
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Good luck--and please provide feedback if this helps!
Nov 14, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
I have to change the code but i dont know how to change it and i dont have the factory instruccions
This is the website for Alarm Lock, the manufacturer:
If you are unable to view the instruction files, you will need to install Adobe Reader on your computer. You can get the free download here:
Good luck-please give feedback if this helps!
Aug 15, 2011 | Trilogy Alarm Lock T2 TRILOGY® Digital...
I need to change my lock code and cant read the quick reference card. What is the process
Here is the website for Alarm Lock, the manufacturer :
From here you will find technical documents and a link to customer service for further assistance.
Oct 15, 2010 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Lock remains unlocked at all times.
The lock is probably in passage mode, enter master code then press A5A this should bring the lock back to normal operating mode.
Jun 01, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Alarm Lock Trillogy DL2800 and DL Windows Program.
If you can load DL windows onto a laptop instead of a PC, you can program directly to each lock using a AL-PC12 cable which connects from a 9-pin serial com port on your computer, to the 2-pin banana plug on the lock.(be sure to observe polarity). Cable is available from Alarm Lock. Some very useful downloads and information is available on their website - www.alarmlock.com
I hope this helps!
Apr 24, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Changed factory code once and need to change it again
I really need the model no. of your lock to be sure I give you the right info, but you can go to www.alarmlock.com and click on "support" at top of home page, then scroll down to bottom of support page and click on "technical library". On the next page, scroll down to DL Programming Manuals and click on your model number. Tip: in the programming instructions, when they refer to the "A" or the "AL" key it is located where the # key is on a phone keypad (to the right of 0).
This key has the alarm lock logo on it. Hope this helps!
Apr 14, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Trilogy dl 2700 serries digital lock program managers code
First you need to know if you have a standard 2700 or the new enhanced version, it makes a big difference. Press any 2 buttons then star, if you get no response it is a standard version, if it beeps several times it is the new version. If it is the standard version, disconnect the battery and press any button. Now you are at factory default. Reprogram the master code, remember the master code and the operating code must b e the same length. 12345 A 1 A new master code A new master code. The master code is the only code that needs to be entered twice during it's programming. To set a manager code press; master code A2A new manager code, to set a new user code; enter master code or manager code A11A new user code. The programming must be done during the lock's unlock window so write down the procedure you intend to use to make things go quicker, if you need more time you can change the unlock window, it is probably set at the factoy 5 seconds. Press master code A45A4, this will give you a 20 second window to program the lock, when you are finished change the lock back to 5 seconds, press; master code A45A1, keep the open window short to conserve batteries.
Feb 18, 2009 | Trilogy Alarm Lock T2 TRILOGY® Digital...
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
Pamela Leach
Pamela Leach
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
