Question about Ingersoll Rand Air Tools & Compressors
SSR-EP25SE T1 SENSOR - Ingersoll Rand Air Tools & Compressors
2 Suggested Answers
ollie reece
  • 1167 Answers
SOURCE: We have a SSR 20 screw compressor belt driven
are you in the uk bud
Posted on Nov 03, 2009
How do I find where the cranckshaft sensor is located
Hello there!
Sorry to hear you are having problems with your ssr!
Correct me if I assume incorrectly, but the 2005 ssr was equipped with an LS2 6.0l v8.
On those engines (as well as many other SBC) the Crankshaft position sensor or CKP is mounted on the passengers side of the engine block, at the very back of the engine. You may have to remove the starter to gain full access to it , but it should be visible w/o doing so.
here are a few pictures to assist in the process(although not taken specifically of an ssr) in the diagram the CKP is number 6.
*images borrowed for technical reference from;
Ls1tech.com
pirate4x4.com
streetrodderweb.com e9bb9986-9ff7-4a89-941c-1f4cccafc6ea.jpg f5e93e07-030c-4e95-8084-bed8495afac9.jpg cb78f23f-900e-469f-b5c2-97e6d3bf6f16.jpg
Jun 07, 2014 | 2005 Chevrolet SSR
Tip
ERROR codes Canon 6650
Canon 6650 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E500 An error is identified in the communication between the sorter and the copier E510 The clock signal from the motor is absent for 250ms or more E510 Sorter motor drive E513 The clock signal from the motor is absent for 250 ms or more E530 Sorter home sensor E530 The home position sensor (P17) fails to go OFF when an equivalent of 2560 pulses of the motor drive command has been generated E531 The stapler unit swing sensor (MS9) fails to go ON within 500 ms after the motor drive command has been generated. MS9 fails to go back OFF within 1000 ms after it has gone on E531 Stapler swing sensor E540 The lead cam home position sensor (P12) fails to go OFF within 2000 ms after the motor drive command has been generated. P12 fails to go back ON within 2000 ms after it has gone OFF E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
on Jan 19, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
My ssr engine will start but immediately within 2 seconds it shuts off
Chek for Fuel Filter and Pump.... Vacumm lost. and Idle sensor for contact lost during engine run Possibility gas line interuption
due to Fuel Pompe Damage
Sep 29, 2010 | 2005 Chevrolet SSR
Tip
ERROR codes Canon 3825
Canon 3825 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
on Jan 18, 2010 | Office Equipment & Supplies
Tip
ERROR codes Canon 3325
Canon 3325 E000 Low fuser temperature. Heat lamp, thermoswitch, thermofuse, thermistor, SSR E001 High fuser temperature. Thermistor, SSR, pinched wire E002 Low fuser temperature. Same as E002 E003 Same as E000/E001 E010 Same as E002 E022 Motor drive problem E030 Counter E202 Scan motor, sensor E204 Scan motor, sensor E210 Lens motor, sensor E220 Exposure lamp E240 DC controller (main board) E401 Pickup drive problem (might be Doc. Feeder) E402 Document belt drive problem E404 Exit motor (document feeder) E411 Document sensor (document feeder) E500 Sorter/machine communication problem E510 Sorter drive problem E530 Sorter home sensor E531 Stapler unit swing sensor E540 Sorter cam sensor E541 Sorter cam sensor E710 DC controller (main board) E712 DC controller or document feeder board
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
Sony T1 lines/pink photos
This is a CCD sensor fault and it has to be replaced . Fortunately Sony carries out this particular repair under warranty so contact them ( fault is completely a component failure see enclosed pic and lens assambly to understand what I am talking about . The sensor is the small device to the right )0dc6cc8.jpg
Dec 23, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
Air Tools & Compressors Logo
42 people viewed this question
Top Ingersoll Rand Air Tools & Compressors Experts
elunsford
Joe Garcia
Joe Garcia
Eddie Tucker
Level 1 Expert
Are you an Ingersoll Rand Air Tool and Compressor Expert? Answer questions, earn points and help others
