Question about Microsoft Windows 2000 Professional for PC
Mount Mount 4 partion in 250 GB HDD and use Vs 2008 Net
Window 2000 professional do not mount 250 gb hardisk at setup and after setup. it mounts only 130gb . if my disk have 4 partion . it mounts only 120 gb and other space not mount as partition . i want to use visual studio 2008 net. please tell me about how is it possible ?
    Problem Solver:
  • 9 Answers
Probably BIOS limitations on the hard disk, perhaps an update would help.
As far as Im aware VS08 only works on Vista/XP
Posted on Feb 03, 2009
Can you take the hard disk out of this backup and put in an enclosure to get things off it?
Yes you can. Inside you will find a completly normal hdd. just unmount it from backup and mount on pc and you are ready to go. note: you must have a free slot and a free power cord to conect the hdd
Aug 27, 2012 | Iomega (33215) 250 GB Hard Drive
I can't find my Hitachi 250 external HDD in my computer.Although i can see it on the Devices and Printers,but also there is no option of open it or do anything on it. Goodluck
Your external hard drive has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
1. Press Win+R to open the Run command.
2. Type "Control" into the dialog box.
3. Double-click Administrative Tools.
4. Double-click Computer Management.
5. Select Disk Management under Storage.
6. Find the 250 GB External Hard drive in the right pane.
7. Right click on the drive and select "Create new partition".
8. After the partition is created you will need to format the partition.
9. Format the partition as NTFS unless you plan on booting off the hard drive, in which case format the partition as FAT32. You can also create multiple partitions if you want.
10. Enter My Computer and you will now see your external hdd.
Thanks for using FixYa.
Mar 09, 2011 | Hitachi SimpleDrive Mini 250GB USB 20...
Windows 7 does not recognized it
Your external hard drive likely has no partitions so Windows has no drive to mount. Follow these steps to create and format a partition for your external hard drive.
Good luck and thanks for using FixYa.
Dec 27, 2010 | Hitachi SimpleDrive Mini 250GB USB 20...
How to scan and rapair my maxtor ounetouch 4 Mini
sorry...my guess is ur HD is gone...
once it falls down and cannot be identified as a Hardware by the OS...most probably it's corrupt....
the HDD needs to be loaded / identified by the OS / mounted.... to be able to access it....scan will not work unless it's mounted by the OS....
take it to a tech shop a c if they can fix it...
May 04, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Hardisk cleaned why?
this may be a hdd physical failure, best to check this would be to connect disk to another computer for a minute and run full HDTACH tests, if it's not damaged, then boot record is damaged, and Partition magic or similar program is needed to delete partition and re-create it
Sep 19, 2009 | Western Digital 250GB MyBook External USB...
FW Lacie Porsche FW ext. HD 250GB light on case blinks and
conect your harddisk to computer whch has windows xp.
Then go to start emnu then type in run 'cmd"
then you can see command propmt.
Then go to your external drive letter like f:
then type 'chkdsk /r"
then pres "y'
then it fix error on hardisk.
Aslo you can format it .
Just take backup of data which you need then right clik on drive licon and format it.then it works fine.
Jun 23, 2009 | LaCie 250GB Ext/Firewire 7200 250 GB Hard...
ACOMDATA 250
I have the very same problem than the one posted by gyoung826 on Aug 14, 2008. My HD is an Acomdata 160 GB, HybriDrive 2,5
Aug 14, 2008 | Acomdata PHD060U2E-54 60 GB USB 2.0 Hard...
Microsoft Windows 2000 Professional for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
