Question about Behringer MDX1600 Autocom Pro Expander Gate Compressor Peak Limiter
Show me how to connect a behringer autocom pro-xl mdx1600
2 Suggested Answers
  • 1138 Answers
SOURCE: how to connect behringer ultragain pro mic
Here is the manual:http://www.behringer.com/EN/downloads/pdf/MIC2200_P0054_M_ENG.pdf Plug your microphone into the input using a proper cable. Plug another balanced cable into the output on the back and plug it into a microphone input on the mixing board. If your mixing board already has phantom power, disable it for that input as the MIC2200 has phantom power. Read the manual carefully and take note of the directions for phantom power and balanced cables. Make sure you follow the directions carefully. If you need the manual in a different language look the MIC2200 up under products at Behringer.com and you can download in pdf format in many different languges.
Posted on Aug 28, 2009
I want to set up my behringer fbq1502
It sounds as if you are not running in series. I assume you are in an insert on the mic channel. The insert send should go to the first item in the chain, then from the output of that to the input on the next item and so on until the output of the final item in the chain goes back to the return on the insert. This is applicable to the type of equipment you have detailed, in some cases however you may be running effects in parallel. Your case is definitely a series situation.
Mar 08, 2014 | Behringer FBQ1502 Ultragraph Pro Dual...
Kenwood tk 3102 and autocom
moz-screenshot-1.jpgmoz-screenshot-2.jpgPlease use the link to get the manual:
http://inform3.kenwoodusa.com/Manuals/USA_LMR%5CTK-2100-3100_B62-0950-30.pdf
good luck......................
May 17, 2008 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Behringer Eurorack UB2442FX - PRO mic inputs are intermittent
Check the type of microphones connected and set the proper settings,
and connect it to other mic inputs .
May 21, 2012 | Behringer EURORACK UB2442FX PRO Mixer
My mdx 1600 compressor goes off on one channel. if you switch off then back on it comes on again
Make sure all your audio interconnects are either XLR or TRS cables to avoid noise that might cause this. Also make sure ALL and I do mean ALL interconnected sound equipment is powered from the SAME receptacle OR power conditioner module. Powering equipment from buillding receptacles at opposite ends of a room is asking for trouble.
Aug 02, 2011 | Behringer MDX1600 2 Channel...
Show me how to hook up the Behringer destroyer pro?
What are you going to hook up to?
Essentially you connect the power cord to power and connect outputs from say a mixer to the inputs using TRS balanced cables... and connect the outputs of the unit to your power amplifier.
Note taht there are MANY other possibilities using "inserts:on some devices.
Dec 02, 2010 | Behringer Dsp1124p Feedback Destroyer Pro...
How to connect behringer ultragain pro mic
Aug 27, 2009 | Behringer Ultragain Pro Mic2200 Microphone
User Guide required
Hi, just Google Behringer and this will give you the web page for the company. Select your product and click that, then download your user guide.
regards mistyman
Nov 21, 2007 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Behringer MDX1600 Autocom Pro Expander Gate Compressor Peak Limiter Logo
57 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
