Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
Lens cover cap broken
Hi there, my camera fell on the ground too! I'm lucky that it is still working but the little round cap that used to cover the objective lens is broken and now there is no protection on it. Do you know where I can buy another cap? Do you think it will be difficult to fix it once I got it? Assistance asked me 100 Euro just to give it a look.. Thanks for your help, if you need more info I will post it as soon as possible. Enrico
Plastic ...find some expoxy and cut some round plastic thin from a old container and glue on the inside..make sure its clean and sandpaper 80 grit both sides ..or heat on a solder iron ..heat staples from stapler..on top of staple itself tell it perces through and heat alittle more into the plastic some ...repeat about 3-6 times..now other side bend the staple over..then tape over with black electrical tape top side to hid it. when i do it u cant tell and its stronger. CrazyLarry
Posted on Jun 27, 2007
    Genius:
  • 2,985 Answers
There are no Spares for these I feel Canon Technical Support may have a solution or a little bit of imagination and a suitable bottle/jar top may serve- with a little piece of fine cord to loop around the camera body
Posted on Jun 26, 2007
How do i replace lense cover on a canon sx170 is?
Since I cannot see your pieces, I can recommend actual replacement. You can Google your camera's make/model with replace lens cover and pick from the listings. You can also go straight to Canon USA and search their store as they have replacement lens covers. I did this here for another customer as an example.
Lens Caps ' Canon Online Store shop.usa.canon.com/shop/en/catalog/.../ef-lens-accessories/lens-caps
Canon Tips & Tricks When using a lens with IS while on a tripod, ... Canon Tips & Tricks That hole in your battery cover has a purpose! ... Lens Cap 14mm f/2.8L II.
Jul 19, 2014 | Canon PowerShot SX170 IS 16 Megapixel...
Broken rear lens element on Nikkor Noct 58mm 1:1.2 lens
I recommend to call Barry Edmonds Nikon technician at Fixation UK LTD
44 20 7091 2550
All Best
Rafal
Jun 16, 2010 | Nikon Cameras
My D80 fell from a foot n half above the ground level well packed in a good quality carry case few days back.uv filter attached to 18-135 Nikor lens cracked & lens cap was jammed. After carefully...
Hi, allow me to suggest using another lens to see if you still see the dark patches in the top corners. If not it is the lens, if so it is the camera. Either way it sounds as though something is maladjusted. Call Nikon digital 1-800-645-6689.
May 14, 2010 | Nikon D80 Digital Camera with 18-135mm...
My camera fell and the lens is stuck!
Hi there, after fall in the floor , your camera's lens guider is broken & thats why its not able to came out fully & not doing proper focusing. Replace the lens guide pin. After that it will work fine like before. Thanks.
Feb 25, 2010 | Casio Exilim EX-S500 Digital Camera
Lens Error
Hi there.
Sometimes when cameras are left for a while the lens can become stuck and you end up with an error message.
The best way to deal with it is face the camera towards the ground and tap it on the back firmly while turning it on, in most cases this method works, but in some cases a little WD-40 does the trick.
If none of this works it has to be taken to a service center for repair.
Please post back with the results and more help if needed, good luck and thanks for using FixYa!!
May 20, 2009 | HP Photosmart M425 Digital Camera
Dropped my canon powershot sd400, now it won't work fine
Hi there, there is two possibilities. The first one is to check the lens barrier covers at the front of the lens are opening correctly. If the front cap is dented in any way it may prevent them from opening fully when switching the camera on. If this is the case, you may be able to manually assist the cover by gently pushing them open with something soft like a cotton tip. This wont fix the problem but may temporarily allow you to use the camera. The other possibility, is that the shutter assembly inside of the lens has been damaged. If you gently shake the camera you may be able to see something shifting across the image on the screen or even when looking through the front of the lens itself. If this is the case you would need to have a service centre replace the lens for you. The same applies for the front barrier however that repair would be much cheaper. Best of luck!
Apr 14, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Lens error/system error
I have successfully fixed the same error on a Nikon 2100 by dissasembling the camera and removing grit from the gears that drive the lens. However, if the camera has been dropped, I suspect that something has got dented or bent. It may be worth taking the camera apart to see if a gear has got dislodged.
I would warn you to be very careful not to get a shock off the flash capacitor inside the camera though. Also, it took me quite a while to put it all back together. It's not the easiest device to work on, a result of the very compact body (for its time!)
May 29, 2007 | Nikon COOLPIX Cameras
Casio EXILIM ZOOM EX-Z850 Zoom button doesnt work
You have to send it in to repairs. You're lucky that the lens even still comes out.
Apr 14, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
133 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
