Question about KitchenAid ProLine 600 Stand Mixer
The motor head on my kitchenaid 600 is loose.
The motor head on my mixer vibrates when in use. Any solutions?
  • jim
    jim Jan 05, 2013
    The mixer is not tilt mixer. When I turn it over and look from underneath, it looks like there should be a screw up in it, but I don''t see one. Should there be one?
    Novelist:
  • KitchenAid Expert
  • 185 Answers
Two. One easy one not so much. There are three screws underneath the motor on your mixer. any one of these screws coming loos will cause the moter compartment to vibrate and move about, easy fix remove motor and retightem. Really is an easy fix 15 mins. second solution; one of the motor mount screw positions have broken and the motor head is no longer fully attached to your support tower and it will have to be replace which means a full tear down and a new part ordered and installed. look at the bottom of the motor head where the power cord goes into the mixer and look for cracks in the metal. Let us know what you find. We can direct you to the proper sites for parts list and parts.
Posted on Jun 02, 2013
  • Slo Mover Jun 02, 2013
  • 143 Answers
SOURCE: My wife's kitchenaid classic 250 watt mixer wobbles on the base
It sounds like your mixer likes to take a beating, ive never dropped one and for good reason, they weigh quite a bit. first check to see if all the rubber legs on the bottom are still there. if they are the only possible solution to fix it after being bent or warped is to either re-shape the part using a tool strong enough to do the job, or to replace the parts needed. the hinge pin part number is 16910. is the base is bent the part number is 240151-1. If the lower portion of the mixer itself is bent or warped this is a serious problem and will require you to dissassemble the entire unit. part number for the lower gearcase is 240350-4 Please not that all the parts list are white in colour. hope this helps.
Thanks
Posted on Oct 12, 2009
hslincoln
  • 235 Answers
SOURCE: Kitchenaid mixer. Top is loose so it bounces when
Hi MJANKOW520. I?m going to assume your KA mixer is a ?Tilt-Head? mixer. You don?t say specifically. Based on your description of the symptoms you mixer exhibits, I would say that your head locking mechanism (or a component) of it is either broken, worn or loosened due to normal wear and tear and need to be readjusted (or repaired) for it to keep your mixer head stationery. The inspection and troubleshooting of the inside of your mixer is a DITY capability, particularly if your mixer is out of warranty. Just be sure to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home. Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case, try K45SSW, and select the file listed under Parts List (check to see it this matches your mixer model). This parts list manual provides an exploded view for the disassembly and reassembly of your mixer, along with all the part name and numbers. Turn to page3, titled: Base and Pedestal Unit. You?ll want to focus on Illus. #9, Link & Lever Latch assembly, which locks the mixer head to the pedestal when run your mixer. Check to see if something is just loose, exceedingly worn or broken. If something has broken, you can order replacement parts and install yourself. As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping. Once apart you can check for any other unseemly wear and tear on other mixer components. It can be messy but quite gratifying to diagnose and repair your mixer yourself. Finally, here's a link to an excellent site that details the disassembly and replacement of a mixer's grease, which might be helpful, too. http://www.foodonthefood.com/food_on_the_food/2009/04/how-to-repair-a-kitchenaid-mixer-yourself.html If you feel this is beyond your capabilities and would be too difficult to do yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer. KA Customer Care can provide you with the name and phone # of the closest authorized KA repair shop in your area or you can do a Online web search, but be sure to get at least three estimates before deciding to commit to one repair shop. Good luck. I hope this helps. Howard, Burke, VA If this solution has helped you, please rate it, thanks! - hslincoln
Posted on Dec 02, 2009
SOURCE: My kitchenaid mixer has a large amount of
If you tip the entire unit on it's side you'll find a screw holding the pin described above in place. Take a flat head screwdriver and tighten that baby up. You'll be all set.
Posted on Dec 27, 2009
  • 130 Answers
SOURCE: mixer head loose
Referring to the diagram on:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10157992.pdf
Remove the screw, item 22, to remove the trim band around the mixer. This will reveal 4 screws which hold the top cover on. Remove the screws and lift the top off. Find all the screws which hold the gearhead in place and tighten them all. If you want to make the fix a permanent one put some thread-loc compound on each screw and tighten it.
Posted on Mar 30, 2010
  • 53 Answers
Turn the mixer upside down and you'll see the screws up inside that hold the head to the base. You'll need a long screw driver.
Posted on May 31, 2010
Motor head on Kitchen Aid KSM150PSWW is loose when in operation.
Are you engaging the head lock during operation? if not that is why it is loose. If you are it is not uncommon for the head to move around a little under heavy loads, when I make bread the head is always trying to come up so I have to use the head lock switch whenever I use the mixer on bread. It is the only time I lock it down.
Sep 05, 2013 | KitchenAid Kitchen Aid KSM150PSWW -...
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
Feb 07, 2013 | KitchenAid Kitchen Aid KP26M1X 6 Quart...
On my Kitchenaid Artisan mixer the 3" silver rod fell out the back. How do I slide back in?
I an sorry but the only Rod in the back of a K45SS is the pivot hinge pin that holds the motor head onto the base. if it fell out then the answer is simple. Turn the mixer upside down and wiggle the base while sliding the pin back in. Once the pin is back in place, there is a set screw in the middle of the shaft that you can see while you are replacing the pin, turn this back down with a flat head screwdriver untill it is firmly against the hinge pin. The culprit of the problem is this set screw. It came loose and allowed your hinge pin to vibrate out and then fall down or fall out as you said. once the set screw is back in place you will be fine. To avoid this problem in the future you might remove the screw entirely and put a drop of "Lock-Tight" on it that will help hold the setscrew in place for a very long time.
Dec 11, 2012 | KitchenAid K45SS Classic Stand Mixer
Mixer head loose
May 15, 2010 | KitchenAid KL26M8XOB Stand Mixer
Mixer head loose
Mar 28, 2010 | KitchenAid KL26M8XOB Stand Mixer
I have a KitchenAid Artisan stand mixer (325 watts/model KSM150), about 5 years old. Lately, when mixing dough for bread or cookies, the motor head of the machine wobbles a bit from side to side. In...
the solution to this is to tighten the screw visible through the base that intersects the pin. Turn the machine upside down and using a long flat screwdriver tighten the screw.
Feb 20, 2010 | KitchenAid KSM150PS Artisan Series Stand...
My kitchenaid mixer has a large amount of vibration when used on speed 4. So much vibration that the head pin was vibrating out of place.
Nov 15, 2009 | KitchenAid Food Mixers
Head of mixer droops
I just fixed mine this moring!!
Solution:
1- Lift head. In the lifted position you will see the head of an adjusting screw. Turn it to the left say a half turn.
2- Lower head and see if it is still too low. If so, do it again.
I had to turn mine like two plus full turns.
I beleive it goes into a nylon insert so that the threads are cut as the screw is put in the first time. If the screw is too loose, it may be possible that over time the head could slowly drop because of vibration and the screw slowly moving inward again. If that happens, a new nylon insert may be needed (but that is a different story).
There is another screw that may be loose of the head moves too much right and left. I also had that issue. This screw will be seen if you lay the machine on its side and look up the shaft (pedestal) of the base (large empty area the head attaches to). You will see a small screw head (first item up the open part). That set screw holds the unit in position on the hinge pin to stop movement from right and left.
You will find a full service manual in pdf at:
http://www.mendingshed.com/kitaidparts.html
Hope this helps.
Ken
Jun 11, 2008 | KitchenAid KSM150PS Artisan Series Stand...
KitchenAid ProLine 600 Stand Mixer Logo
110 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
