Question about Enlight Interactive Scrapland for Windows
I am trying to play Scrapland for the PC and am running on Windows Vista. At first it would not load due to Vista, however I was advised to install a No CD Crack. After doing this I ran the game and got a black screen with sound playing. The game then failed to respond. Any help is appreciated
  • malini314 Mar 28, 2009
    I have kinda the same problem.
    Due I haven't gotten through the error which appears when the game is installed and I press the icon.
    You mention a "NO CD Crack", what is that and how can i make my game work(or atleast try to)?
  • 30 Answers
Try to run in the lowest visual settings possable.
To do this right click the icon and got to properties and change to the lowest setting.
Posted on Jan 21, 2009
Freezing,glitches,wont play you tube videos
There might be many reasons due to this. you might want to install updates for windows vista if you havent already youtube plays Html 5 so it should run perfectly fine unless your graphics card is having hiccups. I also suggest that you re install vista if you can you should backup your information and due a clean install and that will most certainly help you with your problem
Feb 27, 2011 | Microsoft Windows Vista Home Basic Edition...
Windows vista isn't starting up due to corrupted file. How do I log in/
If windows Vista OS isnt loading then your Operating System ( OS ) is corrupted. Try running the installation disk and repairing your system. If this fails you will need to do a FULL operating system re-installation.
May 20, 2010 | Dell Inspiron 1525 Notebook
Scrapland and XP blue screen error - any solution?
it will be your memory(ram) problem .. check ur ram requirement of game...nd upgrade or replace the faulty ram
Aug 24, 2009 | Enlight Interactive Scrapland for Windows
Scrapland Problem
i deleted videos...i played gamme without it...
Aug 21, 2009 | Enlight Interactive Scrapland for Windows
Cannot load game images - Windows Vista
This may be due to that your graphic driver isnt installed properly. Install your video drivers and try the games.
Thank you!
Sabharish
Jun 03, 2009 | Dell Inspiron 530 Desktop Computer
How do i delete saved data on scrapland PC
navigate under the hardrive you installed it. locate the install folder and trace it back to saves, save, saved games etc. Erase all content in folder. If you are using Vista it may be located under games folder instead.
Jun 03, 2009 | Enlight Interactive Scrapland for Windows
Blackscreen in scrapland
I got it to work by disabling ffdshow.
In Vista go to start.
In the search box type in ffdshow.
Click ffdshow video decoder.
ffdshow video decoder config will open.
In the left pane click direct show control.
On the right make sure the box next to "dont use ffdshow in:" is checked.
add Scrap.exe;Scrapland.exe; to the text field
click ok
game should work after that
Apr 17, 2009 | Enlight Interactive Scrapland for Windows
Cant install vista from oem disks
Was there any other OS loaded prior to your attempting to load Vista? If so you heed to do a clean install of Vista. The problem with Vista is that it does not accept any drivers other than those already present in its driver database. First check if the component is Vista compatible, if not install a software to run the device(separate). First of all confirm that ur PC is compatible with Vista OS. These diagnostics are available at microsoft "vista upgrade adviser" site.......sodeep
Apr 04, 2009 | Computers & Internet
Scrapland and vista, error starting game - solution?
my friend you can go to launcher.exe and
1 right click and properties .
2 compatibility and then select mode windows XP/nt
click on the other icons try it works.
reply about the result.
Mar 28, 2009 | Enlight Interactive Scrapland for Windows
Enlight Interactive Scrapland for Windows Logo
559 people viewed this question
Top Enlight Interactive Video Game Consoles & Games Experts
James Wishart
Are you an Enlight Interactive Video Game Console and Game Expert? Answer questions, earn points and help others
