Question about Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator
Frigidaire icemaker not despensing ice
Makes ice, everything turns flapper on door opens but doesn't despense
  • Official Brand Answer
  • 4,342 Answers
Hello jgamewell - Sounds like the dispenser could possibly have a broken or frozen door dispenser sealed. Contact a professional to move forward accurately to properly repair/reinstall part.
Posted on Jan 08, 2013
  • 183 Answers
SOURCE: Frigidaire GLRS237ZA Side by Side Refrigerator
Faulty ice maker unit. Regards Advisor
Posted on Aug 23, 2007
SOURCE: FRS22ZRF side by side Frigidaire
I'm having the same problem and I've identified that the ice auger is no longer being turned by the rear drive coupling b/c the rear drive coupling is slipping on its axis or axel. There is a nut and some sort of metal clip there but I haven't figure out how to removed it yet. The water not coming from the door dispenser may be linked to the electronic valve in the bottom rear access panel area or possibly a blocked line. ID the valve by actuating the water dispenser and listen if you can hear the valve selenoid. You can remove the water lines at the valve to trouble shoot if the valve is opening. that way you can determine if it is a blocked line or just the valve or something else. ken.wrenn@verizon.net
Posted on Oct 03, 2007
  • 833 Answers
SOURCE: Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Posted on Dec 24, 2007
tborn6
  • 700 Answers
SOURCE: Frigidaire Side by Side Gallery Model Refrigerator
yes where thr water go\es into the ice maker is where the problem lies, take the ice maker out and then you'll see the tuding where the water goes into the ice maker. Then take a hair drier or a shop vac reversed and thae out the utde and the water will flow after it is thawed.
Posted on Jan 30, 2009
mastatech
  • 478 Answers
SOURCE: Icemaker makes ice, but will not dispense ice via door.
The auger arm in the back of the freezer should be rotating to test this hold the door switch in and push the dispise button down. If it does not even try it could be the control switch on the door. the auger motor is a 120v motor and relatively strong. You can test to see if you can manually turn the arm it should trurn stiffly. Its alsoi a chance you don't have the been in place correctly.
Posted on Jan 10, 2010
Fridgidaire gallery refrigerator ice maker Ice maker seems to freeze up and won't drop the ice.
Hi, The ice is clogging up the despenser. You need to open it and free it up.. Good luck.
Jun 28, 2011 | Frigidaire Refrigerators
It despense water, but does not make ice
Either the water valve is bad or the icemaker is bad, assuming it is turned on.
Check the valve with the wires off with an ohmmeter.
If it shows continuity, the icemaker is bad.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Ice maker4 issue
Sounds like the optics are bad part # 4389102 this model(if we have the right model#)has two optics boards one receiver one emitter on either side of the door opening which shoot a beam from one to the other through the opening in each side of the bin,as long as nothing blocks that beam and the freezer is cold enough to chill the thermostat to temp in the icemaker,then it should be dumping ice.
Sep 13, 2009 | Whirlpool GS6NBEXR Side by Side...
The door ice despenser is not working. It makes
Make sure that the bucket is pushed in all the way. If the motor is running the screw should be turning. I would also take the bucket out and try to turn the auger by hand to make sure it is turning free.
Please rate solution if helpful. Thanks
Aug 19, 2009 | Kenmore 22.0 cu. ft. Side-By-Side...
Icemaker makes ice but wan't despense, also water wan't despense
i have model mfi2067aeb . the ice maker won't dump the ice. the arm is up that tells when the tray is full. can't get it down.
Jul 16, 2009 | Maytag MFI2067AES Stainless Steel Bottom...
Ice maker stopped working
Did you ever get a solution? Ours just did the same thing. One day working, then just stopped making ice. Water is on and working fine.
May 07, 2009 | Maytag MFI2568AE Side by Side French Door...
Ice dispenser chute
most flaps have a solinard that opens and closes the flap,if you can replace or get in there to lube it you should me ok,let me know more-mike
Sep 29, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice despenser not working
use a hair dryer, it will thaw the ice and not damage the plastic
Apr 26, 2008 | Kenmore 50522 / 50524 Side by Side...
Ice despenser
will it still dispense the whole cube?theres a brass rod under yourice bucket, remove bucket and check that rod, should be spring loaded and have a little bit of action(youll see it move a flap in front of bucket as its twisted, if so make sure the bucket is being reinstlled correctly, try the dispensor w/o the bucket installed at all, open the door trip the switch with one hand and depress the plunger for both crushed and cubed and check for the motor to turn
Feb 22, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Frigidaire FGHB2844L (27.8 cu. ft.) French Door Refrigerator Logo
116 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
