Our new tv does not have a scart socket. This is necessary for a deaf person's loop. Whatnismthe solution
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Your TV might have and AV In connection. If so, buy one AV to SCART connector socket from local electronic spare part shop. Thus you can convert the AV in to SCART.
Posted on Jan 03, 2013
3 Suggested Answers
SOURCE: cant use scart socket
Press the "TV/AV/PC" button to display the choice of input sources, move to the required choice (SCART in your case) using the channel up/down buttons, then press the volume + or - button to selectyour choice.
Posted on Aug 19, 2010
SOURCE: Sharp LC-32D12E (A) need wireless e/phones & amp. I am going deaf
A lot of low-cost TVs do not offer the option for parallel (let alone separately controlled) output for headphones and main speakers. In fact a lot of low-cost TVs do not have any audio output whatsoever. If you have a headphone socket you can consider yourself lucky in this regard. And if you do I am not sure what your problem is. You want to have both running at the same time? This can be arranged with a little effort, but it would be inconvenient and risky as both will be commanded from the same place which means that any time the person listening to the TV speakers wants to change volume the person with the headphones will be affected as well.
Posted on Oct 01, 2012
How do I connect a dvd player to tv with no scart connection
Make and model of TV would help.
Very odd TV with no SCART and only a single HDMI. You sure it's not a computer monitor? happy.gif
If the TV really does not have any sort of analogue input you will either need to buy a disk player with HDMI or an analogue to digital converter (the former may well be cheaper!), And if there is only a single HDMI you can but switches to expand the number of HDMI inputs if necessary.
User manual here
http://documents.knowhow.com/TV-Home...nal_120524.pdf
Refer to page 15 which states:
"Use a included SCART adapter cable to connect
between the TV's SCART input socket and a SCART
cable to an external AV device's SCART output socket."
Dec 12, 2014 | Televison & Video
Can't tune Alba 7395 VCR into a Goodmans GDB12XIT Freeview box
Has the box got a scart socket? If it has connect the VCR to that via a scart lead. If the alba has two scart sockets then use the second one. When recording set the channel as AV1 or AV2.
If you don't have enough scart sockets to connect your TV, VCR and Box, then get one of these Scart Switching Box from places such as Amazon or Argos.
Jan 14, 2013 | Televison & Video
Connecting Alba DVD to Toshiba TV
If the TV has the red, white and yellow sockets on it you can use an adapter. It's a scart plug on one end (for the DVD player) and 3 little round sockets on the other, usually red, white and yellow, sometimes red, black and yellow, like this:Amazon.
Then you need an audio/video lead with red, white and yellow plugs on both ends like this:Amazon
Or one of these:Amazon
You could also use a multi socket scart adapter to add more scarts to your TV:Amazon
Jan 23, 2012 | Toshiba Televison & Video
Directions for plugging your 4head hi fi stereo ito your tv
You don't really say what make or model is the TV or VCR. However if you have a TV with a scart socket you can get a scart lead and connect the VCR via that. If the VCR has two scarts connect it via AV1 sometimes black whereas the other might be blue. If the TV has more than one you will have to try each one, unless it says VCR on the scart socket, till you get the best picture.
Dec 09, 2011 | Televison & Video
Can I hook up a copying device to my LG 26LV2500
Such as a DVD recorder?
Yes, conventionally a recorder takes the feed from aerial or box befiore the TV but recording whatever you're watching can also be done mostly by using one of the Scart sockets usually on the back of a TV usually identified as Scart 1 AV in/out which should be connected to Scart In on a recorder.
If there are digital output sockets - and digital input sockets on a recorder - you'll get higher image and sound quality than you'll get from Scart.
Sep 23, 2011 | LG 26 26LV2500 26 LCD TV
When i plug my new tv into the sky box via a scart, the tv picture is distorted and a major buzzing noise is coming from the tv. sky have checked and said the box is fine. when u connect to another tv it...
Have you tried another scart lead? Also tried all of the tv scart sockets? Don't try and cure this by using an expensive upmarket scart lead, you'll just be wasting your money. The cheapest leads work just as well when the function correctly.
You could also try reversing your current lead by swapping the tv end to the Sky box and vice-versa, as there are many leads which cause feedback issues, and also a lot of "cut" leads (designed to prevent feedback looping) which must be fitted the correct way around. A "cut" lead is one where the wire to pin 19 at the tv end and to pin 20 at the video/Sky box end has been cut.
Note that scart leads MUST be fitted with the tv and Sky box switched off to avoid damage. Most people (including professional installers) regularly ignore this precaution though.
If all else fails then take the tv back and exchange it under the Sale of Goods Act; it's certainly not uncommon for new tv's to have faulty scart sockets.
If I've solved your problem then please take a moment to rate my answer. If not, then please report back with the make and model of TV and I'll try a more specific answer.
Jan 14, 2010 | Televison & Video
Similar problem as you helped me solve before.
OK, I think I see the problem there.
The aerial lead from the DVDR to TV should be removed.
You should have it setup the same as the other Freeview - VCR - TV
Nutshell time:
Main aerial to Freeview input.
Loop aerial from freeview output to DVDR areial input (all this does is allow you to watch freeview, or standard both out of the DVDR)
So..
Scart from Freeview to DVDR input
Scart from DVDR output to TV
Set DVDR to AV input mode.
Set TV to AV (whatever number you need for that..you now won't get anything on screen unless you have the right input selected)
If you can now see the Freeview picture on the TV and change the channels with the Freeview remote then you should be set for recording.
Having the aerial and a scart lead both going to the TV is not needed.
Apr 14, 2008 | Philips VR550 VHS VCR
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Jan 08, 2008 | Televison & Video
Sony shows a split screen when DVD plays
If the new player you hooked up is causing the spit screen then you have to go into the set up menu in the DVD player and take it out of prograssive scan.. Its in the wrong fornmat for your TV set. good Luck PS please dont forget to rate this.
Oct 16, 2006 | Sony KV-32S25 32" TV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
