Question about Lands Phones
My cs6619 vtech phone is failing to register what do i do
It keeps failing everytime it says see manual to register hs on screen then when i pick the phone up after 16 hours of charge it says no battery so when put it back on base it says registering for 10 seconds and the phone screen says failed
4 Suggested Answers
SOURCE: Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Posted on Jun 01, 2007
SOURCE: Not Registered Problem
This worked for the 7100, hopefully it works for other models:
When the handset says "not registered", it should still have a "menu" option. Select that, then the only choice is "register", select Ok. Now it says "searching for base", press and *hold down* the "locate handset" button on the base until the handset beeps and wakes up. Docs say this could take up to 30 seconds (it was about 17 for mine).
Posted on Jul 01, 2009
  • 4 Answers
SOURCE: How to I reset the base for a Vtech VT-2431
This worked for me after lots of digging....If you have already tryed reregistering your handsets and can only get two-or three to work try this and deregister them and re-register. If your base model number is vt2431: Take the handset out of the base, press **335782 on the dial pad of the base. (do not have the line active or anything , just put the (2) stars and 335782 in (no spaces) on the base unit. This will de-register all of the handsets at one time.
Posted on Aug 16, 2009
How to register hs
It would help to have the model number of the base ( found on a sticker on the bottom of the base ) and the handset (under the battery) but the following works for many models: Press and hold the "Find Handset" button until the "in use" lamp comes on. Press the
"#" key on the handset, then place it on the base... if it is going to work, in a minute or less it will chirp and announce "handset registered". If it shows "registration failed", the base may be "fully populated" and cannot accept another handset: many models are limited to only 5 handsets. To start over by clearing the base registry, press the "Find Handset" button until the "in use" lamp
lights, then continue to hold "Find Handset" until "in use" begins to
blink. Release, then press again the "Find Handset" button for a moment. The base should chirp, and be ready to register handsets again... try again as above until the maximum is reached. Good luck!
Apr 06, 2016 | Vtech DECT 6.0 Cordless Phone with Digital...
I have a vetch base of cs6619 and have ordered and received a new hand set Cs 6609 and can not get it registered although it has been charging foe 2 days. Please advise.
Sometimes you have to start from scratch. Remove the battery from all the portable units (including the one at the base station). Then start by setting up the base station.
You might try less drastic steps that are similar if you don't want to lose your directories.
Mar 05, 2015 | Vtech DECT 6.0 Digital Cordless Phone
My vtech phone say not registered and see manual #cs6114
General - Product Troubleshooting - VTech® Cordless Phones
www.vtechphones.com/support/.../35/178
VTech Communications Inc.My handset displays Not Registered. ... If PRESS FIND HS 4 SEC ON BASE does not appear on the screen after a few seconds, lift up handset and recradle it in ...
My vtech phone says not registered and not sure why ... - Fixya
www.fixya.com/support/t10092346-vtech_phone_says_not
Aug 13, 2011 - my vtech phone says not registered and not sure why and how come? can ... See page 26 of the manual for detailed instructions on HOW TO ...
My vtech dect 6.0 phone says not registered how do i fix it ...
www.fixya.com/.../t7993579-vtech_dect_6_0_phone_says_not_registere...
Jan 26, 2011 - my vtech dect 6.0 phone says not registered how do i fix it - VtechDECT 6.0 ... If you click on the above it will take you through to the manual, hope i`ve helped .... See all Vtech DECT 6.0 Digital Cordless Phone Questions ...
vtech cordless handset, how to register - YouTube
? 3:21
https://www.youtube.com/watch?v=dV9rZ_cYcks
Feb 22, 2015 - Uploaded by Brian Williams
My phone says no line plz help me. Been without a ... VTechuser manual had no instructions to set up an ...
[PDF]User's manual - Vtp-media.com
Feb 10, 2015 | VTech Communications CS6114 - cordless...
My vtech cordless phone says see manual to register what to do
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual.
Jun 28, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
How do I change the number of rings before answering machine picks up Vtech cs6619
The CS6619 isn't an answering machine. It will ring until you answer, an answering machine picks up, or the caller hangs up. To change the ring count on an answering machine, please refer to the documentation for that machine. If you require further assistance, please add a comment to this question and identify the answering machine.
Feb 17, 2014 | Vtech DECT 6.0 Cordless Phone with Digital...
How do i get answering machine on my vtech cs6619-2
The CS6619-2 isn't an answering machine. Please refer to the documentation for whatever answering machine you want to connect to your phone line.
Feb 09, 2013 | Vtech 5.8GHz Analog Cordless Phone
How do I change the number or rings on my vtech cs6619-2
The CS6619-2 isn't an answering machine. It will continue to ring until someone or something picks up, or the caller hangs up.
To change the number of rings before your answering machine picks up, please consult the documentation for your answering machine.
Dec 05, 2012 | Vtech DECT 6.0 Digital Cordless Phone
I cannot get my Vtech LS6204 to register. I have tried everything and the screen always reads registration failed.
I have a 2-handset VTech CS6419 that I had been using w/o problems for months. Both HS were always plugged in and charged. One day I found the base HS would not ring and the screen had the message that I needed to register the HS. Pressing the "find HS" button to start the process only made the accessory HS, not the malfunctioning base one, ring. I solved the problem by 1) unplugging the base, 2) pulling the batteries from BOTH handsets, then 3) replugging in the base and reattaching the battery for ONLY the malfunctioning HS. 4) I then did the registration process again (press the "Find HS" button on the base for 4 seconds, then press the # button on the HS and wait.) The malfunctioning HS then registered! I then reattached the battery to the accessory HS and returned it to its' base. Problem solved!
Jan 01, 2011 | Vtech LS6204 1.9 GHz 1-Line Cordless...
Lands Phones Logo
258 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
