Question about Belkin (F5D9230-4) Wireless Router (F5D92304)
Wireless modem not connecting to everything on the network
I recently bought a new laptop to support the home computer and decided to buy a 'Belkin ADSL2+Modem with Wireless G Plus MIMO router' to network them together. The network worked fine untill i decided to also add an xbox360 to the network through the microsoft wireless adapter. All the computers -xbox included- can find the wireless network all the time but when trying to connect either the laptop or the xbox can only connect to the internet when the other is allready on. The problem seems to switch between the two depending on which one was last connected to the internet. Resetting the router allows them to connect again but only untill they are turned off. Belkin tech support dont know what is cuasing this. Can anyone else help.
    President:
  • 2,961 Answers
This sounds as if either the router is not set at enable DHCP which gives your pc's and x box an automatic assigned ip address, so check in the routers settings via your web browser that DHCP is enabled, also go to your wireless network card and go to the properties, select the TCP/IP line, click properties again and make sure automatically obtain ip address is ticked, ok and close window. Do the same with the Xbox in the network settings and make sure that automatically obtain ip address is highlighted and automatic DNS is set. Lastly make sure non of the pc's network setup is set in a way that other pc's connect to the internet through this computer type set up, they should all be set up using the network wizard using the 'this computer connects to the internet through a gateway' setup, which is your router, but if your laptop is Vista, then everything should have set up automatically when a connection to your router was found. Lokk in the routers DHCP clients and look to see if all your pc's and the Xbox is listed and given IP addresses.
Posted on Jun 26, 2007
SOURCE:
I just bought a Belkin Router Model # F5D8236-4. I have everything wired correctly, but the wireless light does not come on. I can't get the internet to come on to the computer I want to connect to? What...
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Jan 21, 2010 | Belkin (F5D8231-4) Wireless Router...
Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Mar 01, 2009 | Arris Touchstone 450a (CM450) Modem
Cannot connect Belkin F5D8233-4 Router to Mac Laptop
If you tell me the version number of your Belkin wireless router , i can fix this issue.Any Routers issue contact me,, i can help you out. copy and paste this address to Browse,Mentioned below http://techhobbies.blogspot.com
Jan 26, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
Trouble connecting new laptop to the internet
when you put the mouse over the network icon in your taskbar, it will say access: Local & Internet or local only.
if Local & internet you have a connection to the internet, if local only then open internet explorer, tools, internet options, connections and check that there is no default connection, it should be never dial a conection thats ticked or greyed out.
Aug 31, 2008 | Gateway Belkin 54g Wireless DSL/Cable...
Trouble setting up work laptop to use Internet thru home computer
Do you have any firewall installed on your computer?
If so, try disabling it. If it doesnt work, keep going.
does your modem have a green light on the "internet" or "activity" status? if not, you have a problem in your modem.
hope it helps.
Aug 07, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
Belkin wireless router installation with a laptop that has an internal modem
Depending on the operating system that you are running, and if you have the appropriate wireless cards, you should be able to do this either with or without the modem. If you have the modem connected to one computer, and wireless cards on both computers, then your best option would be to just connect directly from one computer to the next. If you can tell me the answers to these few questions, I can help you get on the right path.
What operating system are you running? Windows XP? Vista? Macintosh?
Do both of your computers have wireless network cards? If not, then which computers have the wireless network, and which computer has the modem?
Feb 02, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Belkin usb adaptor not connecting with computer
how new is it?
did you recently bought it? i think you have to plug one dsl cable from the modem to that thing...
Dec 11, 2007 | Belkin (F5D7050) 802.11a/g/b Wireless...
Losing internet connection when I try to connect laptop to wireless router
Your cloning the mac address - thats the problem. It should use it's own mac address to connect to the modem. You need to power down the modem, then repower after a minute or so to let it connect to the new mac address. The problem you are seeing is due to network collisions betweenj the desktop and the router with the modem.
Nov 29, 2007 | Belkin (F5D7230-4) Router (587009)
Network problem- Router setup cd cannot get past stage 1- No access to router
Do you have DHCP enabled on your PC? Sounds like you are not getting the IP address.
Oct 05, 2007 | Belkin (F5D8231-4) Wireless Router...
Belkin (F5D9230-4) Wireless Router (F5D92304) Logo
167 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
