Question about Thule 668 Frontier ES Roof Box - LL Bean
How to repair a cracked roof box lid
Hi there, I've managed to crack the lid of my roof box (badly), there's some loose bits as well. What's the best way to repair?
  • jkmacdonald Jan 24, 2009
    did the same thing - backed out of my garage when the door wasn't quite open and SMASH! I'm going to try Goop Contact Adhesive to put the bits back together then seal 'er up with some fiberglass patches (the kind you'd fix a canoe with). I'll let you know how it turns out.
2 Suggested Answers
SOURCE: cracked thule box
www.recrepair.com is what Thule recommends you use to seal your crack :) -- it is an ABS patch kit and is waterproof as it is used for permanent canoe and kayak repairs. it is NASA designed.
I am using it on my Atlantis 1800.
Posted on Aug 25, 2009
How can i repair a crack in my hard case swiss cargo roof rack carrier?
I would use fiberglass (resin, hardener + cloth) on the inside after thoroughly scuffing (and if necessary drilling reinforcing holes) the carrier surface. If after doing that the exterior is not to your liking you could remove any loose material, fill any low areas with auto body filler, sand smooth, and paint. This type of repair will be watertight and likely stronger than the original piece. I have done similar repairs on fiberglass, plastic, carbon fiber, and wood. If the carrier is smooth plastic I would recommend drilling small holes along that crack to allow for a better bond. If it is fiberglass carbon fiber or another composite course scuffing should suffice.
Mar 21, 2016 | Cars & Trucks
How to repair crack between ceiling and wall
Hi simple way is to use some expansion foam from hardware shop squirt it in along the crack it will expand a good bit so no to much cut over spill back when dry then skim with plaster
Feb 05, 2014 | Drywall
How do you lubricate the Thule roof box hinge?
Racks and Cracks posted a good article on cargo box maintenance which included part lubrication with silicon spray. Attached here for your convenience.
Good luck.
thule racks
Jan 01, 2014 | Computers & Internet
How to repair cracks in concrete floors of house and how to make them waterproof
simply chip the conrete cracked maybe up to 3cm wide and 2-3 cm deep the whole way and clean thoroughlly with water and the best is to blow air after you wash with water to take away the loose debris then apply concrete epoxy arround the cracks with clean paint brush # 1-2 let it stay for about 30mins and you feel the epoxy is starting to set before then pour the conrete mix with fine sand that will do the trick.
Nov 05, 2013 | Hilti 378375 TE-YX 5/8" - 13" Concrete...
I have a 2001 Saab 9-3. The spoiler is cracked. I'd like to take it off to repair. Can't figure out how to get it off? Anybody know?
look under the trunk lid. if there isplastic covering the inside trunk lid look for screws to take it off. if there are no screws present then it will just pop off...
But if there is no plastic cover just look on the inside where the spoiler contacts the roof and you should see some screws or some nuts.
May 23, 2011 | 2008 Saab 9-3
Line crack of roof.
I have a solution for cracking of these Thules.
The stores that sell these, carry a patching kit. It's a 3x8" piece of the same material with adhesive on one side. You can take a heat gun and soften the patch and place it over the crack and shape to fit before it cools. I've had 2 Thules on the roof of my excursion with stress cracks at the anchor points. This stuff really does the job and it's really inexpensive.
I have them on both boxes at all stress points... It has solved this issue.
Aug 14, 2010 | Thule 668 Frontier ES Roof Box - LL Bean
Top section of Thule box(atlantis 1600)cracked
Try this link and scroll down to online live help and they might be able to provide you with parts:http://www.rei.com/help/feedback/feedback.html#_2
Nov 30, 2009 | Thule Atlantis 1200
I have cracks on my coleman pop camper rubber roof
Roll with a fibrous roof coating. make sure it has the fibers or else it will not adhere to the cracks or metal.
Jul 11, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Acer 3610 crack by hinges on monitor
Unfortunately the LCD back cover is not readily available but you can find it here http://www.computercare.ca/product.php?productid=18048&cat=1648&page=
I bought this part and replaced my back cover for LCD. be careful while replacing LCD inverter you might be needing a new one.
Aug 19, 2008 | Acer Aspire 3610 Notebook
Washer Stuck in Cycle
The timer is bad / shorted. Mine used to try to spin with the water in it... that was a sight to see!
Jan 11, 2008 | Whirlpool LSN1000LW Top Load Washer
Thule 668 Frontier ES Roof Box - LL Bean Logo
2,944 people viewed this question
Top Thule Winter Sports Experts
Cory Koby
Cory Koby
ray gallant
tau1618
Are you a Thule Winter Sport Expert? Answer questions, earn points and help others
