Question about Razor E300 Scooter
New batteries but wont go
Put in two new batteries ,power light on so its getting juice ,but wont move,what to check next
    Genius:
  • Razor Master
  • 1,508 Answers
Use a multimeter and check that you are getting power to the motor
Posted on Jan 04, 2013
Toshiba Satellite X200-LC3 no power. i bought new AC adapter but the laptop is not taking juice. no flashing lights. is battery fried that it wont take juice? motherboard issue? please help. This comp
It's either the adapter connection or the MOBO itself.
Anyhow try removing the battery and adapter press and hold the power button for 10 to 20 sec plug the adapter with out the battery and restart. Hope this works if not check the MOBO for jack problem
if battery is already charged try with battery alone. Also be sure adapter is compatible the right voltage IE 19.00, 18.00
Mar 11, 2014 | Toshiba Satellite X200-AA3 Notebook
Battery charger wont charge
If you chair is dead the charger will not turn on. Does your chair turn on? If not there is not enough juice to turn the charger on. You need at least 6v to get the charger on. Plus all chargers have lights on the if its got power and its not turning on its a bad charger. Call your vendor they will get you a new one or put new batteries in your chair.
Jun 05, 2012 | Health & Beauty
1994 Mazda 929, wont start. Car was operational but not started for about 6-7 months. It had a new battery installed previously. Tried to Jump it, but the battery is charged. When key is in ignition,...
Thanks for choosing FixYa and welcome. If you have no lights inside, you are not getting power. Clean the terminals and the battery post. Take them off and scrub them with a metal brush. Make sure when you put them back that they are tight. Make sure the terminals are not damaged. Check your ignition fuse also. Since you have no power, you have a bad connection or a bad battery. You need to check your alternator also. It may be bad and cause similar issues. Once you have power inside, you have a good connection and it should start.
May 13, 2011 | 1994 Mazda 929
The trunk light won't go off. And its reading that the trunk( lift gate) is still open. I took the sensor out so I won't lose juice in my battery. But now my door light wont go off when the door is closed....
That sensor you took out is an input to the power liftgate module
What color wire's go to it ? There is five different switches , sensors for the liftgate . The sensor you took out ,the liftgate module isn't see a return signal . So it sends a message on the data network to the BCM which tell's the insturment cluster to light the light .
Sep 12, 2017 | 2007 Cadillac SRX
2001 suburban wont crank,clicks under steering column,battery is good,lights stay on,been doin off and on,but been 4 days.wont crank
Check battery conection first. Both posts on the battery terminal must be free of any debris or acid build up. Clean with baking soda and water. If it is the original battery then there is a chance that it may be going bad. You would still have lights but just not enough juice to start your truck. If the battery is new then the next thing would be your starter. Go in that order, cheapest first.
Feb 16, 2010 | 2001 Chevrolet Suburban
I put a new radio in my car and now it wont start 1190 toyota
Did you in stall it your self ? if so make sure you didnt blow fuses and check the connections make sure you are getting power and if you put subs and power amp and stuff like that make sure you have enough battery power to power everything if not the car wont even turn at all cuz the juice is working on its own to start the radio. check also you didnt cut any wires while doing so and if you didnt install it your self and took it in then take it back something went wrong maybe....
Dec 02, 2009 | 2001 Chevrolet Venture
96 Mazda Protege is dead and has no power, wont turn over!
check all your fuses sometime when giving a jump start
a surge of power a cures and blows out the main fuse
Nov 14, 2009 | 1996 Mazda Protege
2007 chevy impala wont crank. ran fine turned off, went in house came back out, nothing, doorlocks sound like they are locking and unlocking but arent goin up and down, then you cant get the key out, wait...
Could be the battery. The lights take very little power to run but other things such as doors locking takes more juice. Keyswitch unsure unless you have security system built into the car. Batteries can work one minute and then not the next. I would check battery first.
Jul 28, 2009 | 2007 Chevrolet Impala LS Sedan New Cars
2004 A 8L won"t start
starter wont click because there's not enough "juice" to turn it over. this isnt because of the battery as you have just replaced it. it is due to a bad alternator recharging the battery as you drive. if it were only a fuse it would be the solenoid in the starter. but if it had started after you installed the battery then its not the solenoid. solution: buy a refurbished alternator and
Apr 24, 2009 | 2004 Audi A8
Razor E300 Scooter Logo
245 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
