Question about U.S. Robotics USR8200 (USR808200) Firewall
Am trying to browse but i get this error Login
US.Robotics
usr8200 firewall /vpn/nas
How can i enter to the facebook?
cause i cant they have blocked it
we have a firewall here on the server
Posted on Jan 20, 2009
I am traveling in the UAE and would like to access blocked sites
You may be able to use a vpn service if they aren't blocking that also. I have used the free version of http://proxpn.com but not out of the us. Basically you tunnel your internet browsing to another country so it goes from where ever the vpn pops out to the website and there is no uae firewall inbetween.
Oct 28, 2012 | Nokia IP 350 Firewall
Hello. It appears my router is blocking VPN access to the office server. I can connect using the ethernet cable so have isolated the problem to the router firewall. How do I get around this? Thanks
Hi
I will make a couple of assumptions on you setup. First, you have some type of highspeed internet. You have a retail type router/firewall plugged into your internet modem. You are using a VPN Client software installed on a PC or Laptop. By stating that when you connected using your Ethernet cable, you were plugged directly into the Internet modem.
Basically, what you have here is a configuration issue with your Router/Firewall. I use the Cisco VPN Client Software from home. This software uses UDP over TCP port 10000. Your VPN Client will use something along this line as well. So, you need to do one of two things here. Determine what Protocol and Port your VPN software uses. Login into you Router/Firewall and add that to your outbound allowed traffic. Or login into your Router/Firewall and configure it to allow all outbound traffic.
If you are not sure how to do this, the documentation that came with your Router should contain a Tech Support number to call. They can walk you through this in short order. Otherwise, post your EXACT make and model of your Router/Firewall and I will try to get the information for you.
Hope this helps.
Brian
Jun 30, 2010 | Linksys Computers & Internet
How to login netgear prosafe vpn firewall
U can login to the prosafe vpn firewall using
http://192.168.1.1
And for further Queries u can read the documentation :
ftp://downloads.netgear.com/files/FVS338_RM_28Feb09.pdf
Jan 02, 2010 | NetGear ProSafe FVS338 (FVS338NA) Firewall
Login errors occur when trying to use new networks
log in errors problems comes on the solution is the net work ip address is not matched plz find and given correct ip address
Jun 14, 2009 | Check Point VPN-1 Accelerator Card...
I cant login into my space my school has it blocked
Multiple solutions:
-Log into the computer as an administrator. The admin account possibly does not have the same policy.
-Install VPN software on the computer at school, also install VPN software on your home computer. Login to your home computer through the VPN software at school and browse the myspace pages.
-Long shot but give it a try, change it back if it doesn't work -
Open Internet explorer, Select tools from the menu list, select Internet Options from the bottom of the drop down list, Select the Connections Tab, Click the LAN Settings box torwards the bottom. Deselect "use proxy settings", select "Automatically detect settings". Restart IE. If you get nothing, change it back.
-Get myspace IM on your cell phone
Apr 14, 2009 | MySpace Social Network
Vpn connection
That error means it was unable to connect. Can't find vpn server or security was wrong. Are you running a firewall? If so, open port 1723 and try again or shut it down while testing.
Mar 12, 2009 | U.S. Robotics (9107) Router (USR9107A)
DI 524 Router Not able to connect to office VPN on Wireless
I have the same model router at home, just checked the settings, you should be able to pass through the router with a normal vpn connection.
If you use a special VPN client, like a CheckPoint Secure VPN client, the router might block it. Also you might want to ask your office's sys admin if you are not blocked by the firewall or something similar. Your office's sys admin will prolly solve your problem since he knows your work network's configuration and setup and how to connect to it.
Nov 08, 2007 | D-Link AirPlus DI-524 Wireless Router
Vpn pass through problem with us robotics model 5461
login to the router and check these things
IPSec Passthrough: Enable Disable               PPTP Passthrough: Enable Disable               L2TP Passthrough: Enable Disable
Oct 29, 2007 | U.S. Robotics MAXg USR5461 (738168036790)...
Open Questions:
See all U.S. Robotics USR8200 (USR808200) Firewall Questions
U.S. Robotics USR8200 (USR808200) Firewall Logo
71 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
