Philips SNU5600 wireless USB Adapter fails to install
I bought a "PHILIPS WIRELESS 54MBPS ADSL ROUTER AND USB DONGLE" for a friend as a package containing the "Philips CGA5722 ADSL Router" together with the "Philips SNU5600 wireless USB Adapter".
I installed the router without any problem. However, every attempt to install the "Philips SNU5600 wireless USB Adapter" failed...
When I'm installing the adapter, its drivers are installed successfully, then I'm asked to insert the adapter into the USB socket after which a windows pops-up informing me that:
"Cannot Install This Software
There was a problem installing this hardware:
Philips SNU 5600 Wireless USB Adapter 11b/g #3
An error occurred during the installation of the device
The system cannot find the file specified"
I ran a utility program to repair TCP/IP just in case... But the installation of the SNU5600 adapter still generated the same error.
To check if the adapter is not faulty I installed it successfully at work where I used the downloaded installation software from Philips' website this time as I didn't have the CD with me (Note that I always used the CD when the adater failed to install). So, the device is OK...
Any suggestions?
Thanks!
2 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Failed to install
Belkin drivers are a bit of a pain, uninstall the drivers again and remove the usb adapter, and follow exactly as per instructions, normally driver first, but ignore the pop up about the driver not being a signed windows if it does, just click install anyway. toward the end of the installation you should be prompted to connect the usb adapter, the hardware should be found and then the installation should complete. If driver installed ok but the adapter cant find the the driver plug it into a different usb port and again the found hardware should pop up then install driver popup should show and you should select install automatically.
Posted on Sep 10, 2007
Can i use connect dongle as wireless adapter
Yes definitely ,I think i need lots more information about router version, IEEE standard.
basically adapter that uses mobile phone networks to provide broadband as a WiFi Dongle while USB WiFi adapter can be used to connect your PC to and existing wirless network provided by a wireless router.
but first you should find out what kind of Internet router you are using and always purchase a Wi-Fi adapter that is compatible with the Wi-Fi standard of your wireless router.
read more information
for more http://www.ebay.co.uk/gds/Buying-a-USB-Wi-Fi-Adapter-Dongle-Can-Make-You-More-Mobile-/10000000177329841/g.html
If you still not able to solve follow us Linksys Router Support .
Apr 17, 2014 | Computers & Internet
Laptop toshiba can't find my wireless router realtek rtl8187b wireless 802.11b/g 54mbps usb 2.0 network adapter
Try checking your computer's driver. Right click on Computer. Go to Device Manager. The device drivers are listed in the device manager. Drivers are used to make your computer parts communicate with the operating system. If it has a problem, then the part won't work.
Check for your wireless driver - update it. If no go, then try turning off your wireless adapter in your computer and turn it on. Check = if no go. Try going to safe mode with networking.
To go to safe mode. Do the following:
1. Restart your computer. While it's starting or booting, keep tapping F8 until you see the options to go to safe mode with networking. Use the arrow keys to highlight safe mode with networking.
2. Let your computer start in safe mode. Check if wireless is working fine.
If you want to avoid this kind of problem in the future or if you want to make sure that your computer is running well, then install Radarsync.
Nov 26, 2012 | Realtek Semiconductor Realtek RTL8187B...
Can't connect to internet
just try to power down your router for a minute or two then fire it back up again...9times out of 10 this resolves the issue...failing that try re-installing the wireless adapter.... hope this helps
Dec 11, 2008 | Trendware TRENDnet TEW-435BRM 802.11g...
Adsl wireless n modem router
regard to G it can transfer signal up to 54mbps  and nano tech have even come to point now as its 130mbps more that ethernet cable but it depends on the factors such as heavy wall , and other interference such as sky , heavy speakers  microwave , bulgrar alarm so on with network booster like netgear it works 2 boost the wireless signal, regards 2 comparision 1 has advantage over the other
Oct 20, 2008 | Belkin N1 Wireless USB 2.0 Network Adapter...
Wifi Dongle
function PopupWindow(URL, WIDTH, HEIGHT){ var winleft=(screen.width-WIDTH)/2; var winright=(screen.height-HEIGHT)/2; day=new Date(); id=day.getTime(); eval("page"+id+" = window.open(URL,'"+id+"','toolbar=0,scrollbars=1,location=0,statusbar=1,menubar=0,resizable=1,width="+WIDTH+",height="+HEIGHT+",left="+winleft+",top="+winright+"');"); }
USB WiFi Dongle
Product reference: 11590 Here is some Technical data on your wireless adaptor. There is also a link at the bottom where you can download the driver for the operating system you are running.
" src="http://www.mobilefun.co.uk/graphics/rightarrow.gif" width="10" /> Description The USB WiFi Dongle easily connects your USB-equipped desktop or notebook computer to your wireless network for internet and file sharing. Desktop users can now join the network with the ease of a USB plug-in, without opening their PC cases, laptop users can enjoy the benefits of staying mobile-while connected to the internet.
By adhering to the 802.11g wireless standard, the USB WiFi Dongle is capable of streaming video and transferring large files across a wireless network. You will most likely need this if you have a bought a wireless ADSL or cable modem and wish to connect your PC to the internet or other PCs on the network wirelessly. The USB WiFi dongle is also compatible with all mobile phones and PDAs with WiFi connectivity.
Features:
  • Versatile use with Desktop PC or Laptop Computer
  • Portable, compact, pocket sized design
  • Compatible with IEEE 802.11b (11Mbps data rate).
  • Compatible with IEEE 802.11g (54Mps data rate).
  • Dynamic data rate scaling at 6,9,12,18,24,36,48 and 54Mbps for 802.11g.
  • Support wireless data encryption with 64/128 WEP for security.
  • Support infrastructure networks: Access point and ad-hoc network.
  • Supports WPA enhanced security.
  • Supports DFS/TPC for European operation.
  • Friendly user configuration and diagnostic utilities.
  • High speed USB 2.0 interface.
Technical data:
  • Chipset: SiS 163U.
  • Standards: IEEE 802.11b, IEEE 802.11g.
  • Frequency Band: 2.4GHz ~ 2.483GHz.
  • Data Rate: IEEE 802.11b, 1, 2, 5.5 & 11Mbps.
    IEEE 802.11g, 6, 9, 12, 18, 24, 36, 48 & 54Mbps.
  • Transmitter Power: 17 dBm.
  • Receive Sensitivity Operating at 11Mbps: -80 dBm @ 8% FER.
  • Operating Range: 100 - 400m, depending on environment.
  • Antenna: On board chip antenna.
  • Security: 64-bit or 128-bit WEP/WPA/TKIP.
  • I/O Interface: USB 2.0.
  • Size: 58 (L) x 23(W) x 9(H) mm.
  • Weight: 9g.
System Requirements:
  • Windows 98SE/ME/2000 and Windows XP.
  • Pentium 233 MHz or higher.
  • 32 Mb of RAM under 98, 98 SE, Millennium & NT 4.0 with Service Pack 5.
  • 64 Mb of RAM under Windows 2000 and Windows XP.
  • 100 Mb of disk space.
rightarrow.gifDriver Download To download the latest drivers for Windows 98 or higher click here.
Apr 14, 2008 | Computers & Internet
Dell wireless 1450 usb adapter
any wireless router will be ok, they are all the same standard normally 802.11G, but if your adapter is 54MBPS go for a 54G router, or if 108MBPS, go for the faster router.
Oct 02, 2007 | Dell 1450 (D1450U) Wireless Adapter
Computers & Internet Logo
797 people viewed this question
David Payne
David Payne
