Question about Ovens
Rational self cooking center error 120
Hello everyone, i will put the problem first. in our kitchen we tried tu use the rational but it gives us this problem. it tries to do some prosses but it gets stuck on some part everytime Also we tried to see what the problem was and it fell some water, but the main problem is that we dont know what the error 120 means So what I ask is for the meaning of what error 120/ error service 120 means, and posible ways of solving it beforhand thanks
Powerman
  • 68 Answers
SOURCE: oven showing F2 fault
I concur with Catriver. F2 means that the oven temperature has exceeded a preset threshold. It could be for any of the following reasons: Welded relay contacts. Cooling fan stalled or blocked air flow to rear of unit. High resistance in oven sensor leads/high resistance in connectors especially at sensor in rear. There could be an open thermal switch in the yellow leads. The oven sensor would measure around 2650 ohms at the "clean temperature".
Posted on Apr 22, 2007
Powerman
  • 68 Answers
SOURCE: Kitchen Aid ovens - error codes
The F-3 error code typically means you have sensor problem. The sensor is usually mounted in the oven space up near the top of the unit. The first thing to do is turn off the circuit breaker to the oven. Do you have an ohm meter? I suggest if you don't to purchase one. They are relatively inexpensive. Maybe you can borrow one from a friend. Disconnect the sensor from the electronic control and measure the resistance. There should be a wiring diagram in the top of the unit that will help you to locate the sensor wires. Most sensors should read around 1100 ohms at room temperature. If sensor reads as an open circuit or has a very high resistance, it must be replaced. If instead it reads very low, then there is a short in the wiring. Some units have a fuse in series with the sensor. Check to see that the fuse has not blown.
Posted on May 03, 2007
SOURCE: F7 message with beeping
...and here it is without having to wade through that whole thread:
take off the faceplate, unhook the wide, flat ribbon cord and use a pencil eraser to clean the metal contact points. Put it back together and you're good to go for a few months. When it happens again, fix it again. It takes about 5 minutes and it's free, which, by the way, is cheaper than buying either of the parts (which I would venture to guess will have the same problem a while down the road anyway).
Posted on Jan 13, 2008
abhishek33
  • 1239 Answers
SOURCE: instruction manual
HI SIR
When you first use your Oven, the Oven will need to "settle". That is, it needs to burn off production residues and dust. The metal used in the Oven will also expand slightly when first used. You will experience some crackling and a strong smell. This is perfectly normal and we advice you anticipate this "settling" prior to use. Using an empty Oven, select Function 4 and set a temperature of 250°, allow the Oven to "settle" for hour, turn to function 3 and heat for a further 1/2 hour.
Multifunction Oven Function Selections
2. Defrost - This function activates the fan only, (no heat is used) to allow controlled and hygienic defrosting.
3. Conventional cooking - Normal or traditional cooking functions using the top and bottom elements. When using this function set the thermostat between 50 - 250°C. When the desired temperature is reached the yellow light will go out and then alternate between lit and unlit as the temperature is controlled.
4. Fan-Forced cooking - This selection is best for multilevel cooking as the heat generated by the central element is circulated around the Oven, creating an even heat environment. You will need to set the thermostat dial between 50-250°C for this function.
5. Center Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
6. Large Griller - For best results set the thermostat to MAX. The door may remain closed or completely open.
7. Fan Griller - This function combines the grill element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking. The thermostat dial should be set between 50-250°C for this function.
8. Fan-assisted Baking or Patisserie Setting
 - Combines the concealed bottom element with fan assistance and is used in conjunction with the thermostat. The Oven door must remain CLOSED during cooking.
top
Advanced Oven Features
Cavity Cooling
The Oven has an advanced cavity cooling system. A cylindrical fan is mounted on the rear outside frame of the Oven. This fan assists the movement of air through the Oven cavity keeping it cool. In addition to reducing the temperature in the Oven cavity, the air is blown out around the Oven door handle which keeps the door handle cool. The cooling fan is activated when the Oven light or any cooking function is selected and will switch off after all Oven functions have been turned off.
Triple Reflective Door Glazing
Some Ovens have two levels of removable door glass. The two inner layers are removable and are made of a reflective glass which, in effect, reflects heat back into the Oven and results in a significant reduction in the outside door surface temperature. To clean the door glass, use a coin or large screwdriver to remove the screws. Wipe both sides of the inner, middle and outer glass. Wipe the sealing gasket. Don't forget to replace the rubber sealing gasket around the centre glass layer before replacing the glass. Ensure the narrow air gap lies between the inner and centre glass layers and the wider gap lies between the centre and outside glass layers. Tighten each screw gradually, one then the other until firm. Do not overtighten.
Wipe Clean Enamel (Extra Optional)
Some models have easyclean blue enamel paint throughout the internal cavity walls. Other models have baking trays and grill pans finished in the soft grey super tough "wipe clean" enamel. This enamel is less porous than conventional, so that food does not adhere as easily. Simply wipe clean with a soapy cloth or creme cleanser when cooking is finished. For baked on residue, use a smooth scraper or if necessary a non-caustic Oven cleaner.
Drop Down Grill Element (Extra Optional)
The removal of a single screw at the front of the upper grill element in some models allows the element to drop down so that cleaning of the roof of the Oven is made easy. On completion of cleaning, simply replace the grill element and secure with the screw, finger-tight.
top
The Electronic Timer
Normal Baking
Function 3: Normal Oven baking using heat from both the upper element and concealed lower element.
To bake, place the Oven rack in the appropriate position according to the type of food to be cooked. Turn the Function Selector to Position 3 and the thermostat knob to the correct temperature, and allow the Oven to fully preheat for best results.
Ideal for cooking casseroles, soufflés, roast, meats, and other items which require a slow method of cooking.
top
Fan Forced Baking
Function 4: Fan-forced central element cooking requires slightly different timing techniques than normal cooking. The fan draws the air in and over the central element which is positioned around the fan and then circulates it back around the Oven cavity. The even distributor of heat allows foods to rise and cook simultaneously regardless of shelf level. Lower cooking temperatures and in some cases less cooking time is another advantage of this feature.
Turn the Function Selector to Position 4 and turn the thermostat to the desired temperature. Pre heating takes much less time than a normal bake Oven.
Note: When cooking meats, for best results always preheat the Oven to ensure the meat surface is sealed to lock-in juices for a moist and tender result.
Fan forced cooking is ideal for multilevel cooking e.g.. patty cakes. Another advantage of fan forced cooking is that different types of food may be cooked simultaneously without mixing the aromas or flavours. When using the Oven in this way, ensure that all the foods require the same cooking temperature and check the finish times of each dish for best results.
Please note that fan-forced cooking is faster than conventional methods, so take care not to burn your food when you first start using this method.
top
Grilling
Function 5 & 6: During grilling the door may remain closed or completely open.
This function offers the traditional grilling method necessary to achieve proper browning without overcooking the interior of the foods.
Position 5 activates the centre section of the upper grill element only, which is ideal for browning smaller portions or thinner cuts of meat.
Position 6 activates the entire upper element for the grilling of large quantities or thick cuts of meat.
Allow the griller to pre-heat for approx. 2 minutes before sliding the tray into position.
Place the grill tray into the roasting pan and arrange food according to the function you have selected, either in the centre of the tray or spread across the full width of the tray. Position the tray at the correct grilling level and turn the thermostat control to MAX for best results.
As the temperature is set to MAX you may need to adjust your grilling shelf height to suit the desired cooking result. If the tray is too close to the element, the food will be exposed to the full effect of the element and may burn and create smoke.
Posted on Sep 11, 2008
  • 272 Answers
SOURCE: kitchen aid oven is'nt working and giving code
Here is a page with all of the error codes for your oven.
http://www.appliancetimers.com/index.php?page=failure_code_page&manufacturer=ka&type=r
Your code is 2 parts, F2 is oven temp is too high, and the E0 wants you to test the relay contact operation. In simpler language make sure the connections are tight.
Posted on May 09, 2009
My rational selfcooking center says service34-2- no function please help
You really need a specialist repairer to resolve this but this generally relates to a main fan motor defect or a failure elsewhere in the bus circuit.
Sep 03, 2011 | Ovens
We have a frigidaire self cleaning oven . It made a bang and now there there is no power to my oven. Clock does not work , Burners on stove still work.
According to your symptoms, it appears that you will need a new electronic oven control board. If nothing on the range heats, you could have a tripped breaker on the 120 volt L2 leg of 240 volt power. This would prevent the cook top burners and the oven elements from heating.
Jan 21, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
It takes forever to cook anything in the oven I set the temp. the buzzer goes off and I put in the dish in. but it takes too long to cook.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 04, 2011 | Whirlpool 30" Self-Cleaning Freestanding...
F2 and F3 messages - shuts itself off. Any idea of what it is and how to fix it?
Hi
F2/F3 error message relates to the oven temperature sensor or thermostat faults.
The fix is normally to replace it.
This link may help if you want to do it yourself
www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Hope you get it fixed.
Dec 16, 2010 | GE JKP15 Electric Single Oven
Shutting off
Hi, you need to have your control board rebuilt or replaced (if it's stll available). Here's an article I wrote on this failure last year if you want to read the details. http://appliancejunk.com/blog/2009/10/24/oven-failure-after-self-clean-and-f1-errors/
Aug 01, 2010 | GE JKS05 Electric Single Oven
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
What does the error code F1 indicate, on a Wolf Oven?
I had the same problem with a Wolf L-Series double wall oven (Model DO30) and called for service (under extended warranty contract). The tech told me that the F1 error is a latch problem (you know the one that grabs and locks the door during self-clean cycles). He cleared the error using a series of "secret" button presses on the control panel and the problem cleared. Now, when it happens (which isn't very frequently), I do the same thing he did ... press "0" and "Temperature" for the oven causing the problem and hold them for about 5 seconds. The oven will ding and the display will show some diagnostics, including the error event. Press "Cook Time" and "Stop Time" while in this diagnostic mode to clear the error register, then press "Off". I've also tried to keep the area across the top of the oven opening clean (with a little degreaser), especially around the latch, and I've sprayed a bit of WD-40 into the latch periodically for lubrication and cleaning.
Mar 24, 2009 | Ovens
Whirlpool Oven Model RF365PXGN getting a error of F1 and E2
HELLO, I HAD THE SAME PROBLEM. ALL YOU HAVE TO DO IS FIND YOUR CIRCUIT BREAKER BOX AND LOOK IN IT FOR THE BUTTON THAT SAYS KITCHEN. TURN THE KITCHEN POWER OFF FOR 30 MINUTES THEN TURN IT BACK ON. ONCE YOU TURN IT BACK ON THE OVEN SHOULD RESET ITS SELF. TRY THAT AND IT SHOULD HELP.
Oct 31, 2008 | Ovens
1990 Kenmore Self Cleaning 24in Elec Double Oven - Top Oven door does not open
hit cancel or stop clear see if that helps if that doesnt work start self clean then stop it
Jul 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
1,181 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
