Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Moen shower faucet handle adapter is stuck.
Handle adapter
  • 171 Answers
SOURCE: Moen Bath Tub Faucet
Hi varn4620,
I'm Harvey the Master Plumber.
Your question is: You had to replace the faucet in the tub due to a broken plastic piece in valve stem. Bought a Moen ripped the wall out and put new faucet in. Went good untill we turned the water on and the shower rained on us. Tightened everything you could find to tighten .Every time the water is turned on the shower rains. Can this be fixed or is the faucet broken?
Is this new faudet a single handle? If so I"ve had this experience also. Most of the time it's because the guts were not lined up properly at the factory. You may have to play with it a bit.
Turn off the water and take the handle off and remove the sleave, remove and rotate the guts. Try 90' at a time. Turn water on to try it. Useually one of the other 3 positions will be right. The correct position is there, but it may take time to find it.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 21, 2008
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
  • 374 Answers
SOURCE: Bathroom Faucet Handle Fell Off
There is a small allen screw in the base of the handle- the part the stem screws into to turn the water to the on position. If you have lost the one for your handle call moen at 1-800-289-6636 in the US. Their hours are Mon-Fri 8-8 EST and Sat 8-18:30 or follow this link MOEN. In Canada 1-800-465-6130 and hours are Mon-Fri 7:30-17:00 EST.
Posted on Mar 13, 2009
jj505
  • 195 Answers
SOURCE: moen shower handle keeps turning it wont come to a stop
Yes it is fixable and easy.To save you time because I belive you will be needing a new part from Moen I am sending you this easy link to quickly resolve your issue. Just be sure to tell Moen you are original owner of faucet and all parts are lifetime free including shipping. Go Moen!!!
Thanks and Please Rate jj505
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
Posted on Apr 06, 2009
frcs68
  • 1605 Answers
SOURCE: hot and cold backwards on a moen shower faucet
tun off the water.
unscrew teh allen screw under neath the handle. pull out hteh handle. undo the wall plate and gain access to the cartridge in the handle body. turn the artridge around 180 degree and reisntall all parts.
Moen single shower handle won't come off even after set screw is removed
Sometimes the valve sticks to the handle, try spraying a little vinegar or delimer and let it sit a moment; then wiggle it loose.
May 03, 2013 | Moen & One Handle Tub & Shower Faucet
How to remove a stuck cartridge from the shower Moen
go buy the moen cartridge removal tool p.s. dont forget to remove the clip holding gart. in !!
Jan 01, 2013 | Moen & One Handle Tub & Shower Faucet
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
The shower control valve for my moen 2995 faucet is stuck in the shower position. how do i remove it?
Turn off water main. remove round cap on face of handle, remove screw and pull handle. After that everything else can be pulled off easily. When you get to the diverter you should be able to why its stuck.
Sep 27, 2009 | Moen 2995 Chateau Three Handle Tub and...
Need to replace handle adapter kit on a Moen monticello two handle lavatory faucet
Lowes might carry them but i know a plumbing supply house does for sure. Take center caps off hot and cold handls, then screws everything else should pull right off.
Sep 10, 2009 | Moen & Monticello& Two Handle Lavatory...
Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Jul 22, 2009 | Moen & One Handle Tub & Shower Faucet
Moen shower handle keeps turning it wont come to a stop
Mar 29, 2009 | Moen 2919 Chateau Two Handle Tub and...
My Moen Chateau model 2995 shower handle will not work, will not turn to shower postion. Handle seemed to have "frozen up".
Mar 25, 2009 | Moen 2995 Chateau Three Handle Tub and...
Hot water dribbles thru shower head when turned to hot
Replacing the cartridge should solve the problem, the balancing spool is stuck, replacing it will solve the problem. The valve should look like this http://www.moen.ca/shared/pdf/3170pt.pdf . I have unstuck the spools in the past, soaking it in white vinegar will help to remove build up.
Nov 17, 2008 | Moen 3175 Legend One Handle Shower Faucet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
813 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
