Question about Mitsubishi WD-57731 57" Projection HDTV
Mitsubishi Dlp WD 65737 Green light flashing
Pressing the power button, the tv will power-up showing the mitsubishi logo. You can also hear the fan running. After about 10 seconds the screen goes blank and the status light will begin to blink green (rapidly) for about 10 seconds, after that the blinking stops and the green light turns off
  • 1694 Answers
SOURCE: Mitsubishi WS65513 with blinking green light
Download Chris@ChrisAndNat.com .........T.
Posted on Nov 09, 2007
premtech
  • 934 Answers
SOURCE: mitsubishi wd-62825 dlp
The WD62825 has a Digital Module located on the left side of the chassis looking at it from the rear of the set. It's housed in a metal box that can slide out of its holder after removing the trim screws.
The module has its own power supply board and there are a group of 16v/1000uf caps on that board which commonly fail causing the constant flashing standby light. Further back on the module is a small board about the size of a matchbook called the E2P module. Its SMT (Surface Mount Technology) caps also commonly fail which can cause the same symptoms. Techs can tell whether the E2P has failed by simply removing it, hooking the DM back up and trying to power the set. If it powers on the picture won't be much good - but at least you can tell what's keeping it down...
Back to the caps on the pwr board. If they've failed they usually will buldge visibly on top. And ESR is almost not necessary. In any event that's the nuts and bolts on this model.
Is it a job for a layman? Yes and no - you might strongly consider a tech if you don't feel comfortable removing all the connections that the DM has with the signal board. There are about six - multi-pin - wired connections to unplug and then sliding the DM out of the unit and carefully removing the screws and latching to take the DM top cover off...
Hope this helps.
Bill
Posted on Nov 10, 2007
  • 1153 Answers
SOURCE: Blinking Green Light on Mitsubishi DLP 52525
No problem, do self diagnosis test, read threads here or goto ctechnicians.com get error codes first and get back with me.
Posted on Dec 17, 2007
Slinteriors
  • 8617 Answers
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Posted on Sep 09, 2008
localwonder
  • 6784 Answers
SOURCE: Mitsubishi TV WD-62527 will not turn on
Hi there, this is most commonly known as power board failure in the industry. the capacitors are blown. if you are experienced in inspecting circuit boards this will be helpful. you will have to disassemble and pull the power board and preform a break point test. the bown capacitors are easily picked out. they will be swollen and discolored. If you are not comfortable with disassembling this set, i suggest a service call. just tell the tech you are experiencing a power board failure.
Posted on Mar 07, 2009
Mitsubishi wd-73738 turns itself back on
It sound like the remote is powering off the cable box but not the TV. The remote control may need to be reprogrammed to the TV. When you press power it may only power off the Cable box. At that point, try pressing the TV button on your remote and then Power. If it does not power off the tV after pressing the tV button, the remote may need to be reprogrammed to the tv. Cable companies usually have the codes needed to program their remotes to the TVs.
Jul 09, 2016 | Mitsubishi WD-73738 73" 3D Ready DLP HDTV...
Mitsubishi WD-65737 will not turn on
The tv is trash. It will cost more then its worth to fix it..Trust me. Get a new Flat screen and stay away from projections..My Mitsubishi 60" is laying in the shop on its back. They are trash.
Nov 07, 2013 | Mitsubishi WD-65737 65"" rear projection...
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filtercover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cablebetween FMT and Engine disconnected
May 30, 2012 | Mitsubishi WD Televison & Video
Mitsubishi WD-65737 DLP TV. TV powers on, green light starts blinking and blue screen shows up. TV then shuts down. I retrieved the error code and it shows "1-2". Any ideas? TV is less than a year old...
I had exactly the same thing happen..I contacted Mitsubishi and they said the software needs to be updated..they are going to send me the link to download the software.
Oct 24, 2010 | Mitsubishi WD65737 65" DLP TV
I have a WD-65737 Mitsubishi DLP TV . Last night it was working great and then this morning it didnt come on . I mean its like it isnt getting any power . The green light isnt even coming on . Please help
iI just had the sMe isuue. your tv needs a system upgrade. Contact Mitaubishi and they will email the upgrade link. You will need Aa thumb dri.ve upto 4gigs to downlaod...ensure its empty. They directions will guide u. thru.
Sep 30, 2010 | Mitsubishi WD65737 65" DLP TV
When i press power button green light comes on and then red light blinks 2 but the tv does not turn on
Question title shows it is Mitsubishi WD-65737 tv.
When did you replaced lamp in tv?
If lamp has not been replaced in last 2-3 years, please check lamp as it seems dead, that is why tv does not turn On.
Aug 26, 2010 | Mitsubishi WD65737 65" DLP TV
Problems with mitsubishi WD 65737 tv is locked. what do we do?
problem with mitsubishi wd65737. thought the bulb was bad, bought a new bulb replaced it and now the screen doesnt want to come on. light on the front of the tv turns green, you have sound but no picture then the tv turns off the light on the front is now steady red. resetting the sytem worked yesterday but not today.
Oct 20, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD-57731 57" Projection HDTV Logo
156 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
