Question about Health & Beauty
Philips 6827 shaver with batteries that will not recharge.
Can I remove the batteries and use it as a plug in only unit?
  • Gord Jan 03, 2013
    I guess I didn't explain properly? As the batteries are corroding to much power is being used to try and charge them causing the shaver to run slow. I would like to remove the batteries entirely, not replace them, and use the shaver as a plug in unit only. Manuals and support are useless as they only say to replace the batteries?
EwingElect
  • 276 Answers
SOURCE: PHILIPS SHAVER CABLE
If you're not in the US, refer to http://www.philips.com/ where there is a listing of countries, and you should be able to select "Contact and Support" option from the main page.
Posted on Mar 28, 2009
  • 10865 Answers
SOURCE: shaver has lost charge, won't recharge on station,
here is the link to the manual and the service center http://www.braun.com/us/home.html
Posted on Jun 23, 2009
brector3
  • 1602 Answers
SOURCE: The braun 5510 shaver.. rechargeable or not
If working properly, model 5510 will work either from the internal rechargeable batteries or directly from the cord. If your shaver no longer recharges, it needs to have the rechargeable batteries replaced.
Posted on Feb 04, 2010
brector3
  • 1602 Answers
SOURCE: How to open Philips shaver 7110X to replace batery
Remove 2 screws on the back to remove outer cover. Once removed, you will see 3 more screws that must be removed on the inner cover. Remove screws and cover to get to the battery.
When installing the battery, I suggest that you use a modified installation technique. This is to break the tabs off of the old batteries rather that removing them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can them solder the tabs from the new batteries to the old existing tabs
You will find a battery for your shaver at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-battery-aa-nimh-p-108.html
Posted on Feb 12, 2010
brector3
  • 1602 Answers
SOURCE: anyone know the specifcation of
It is a lithium ion battery specialized for your shaver. You will find a replacement at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-liion-battery-cell-for-select-models-p-380.html
Posted on Sep 04, 2010
Batteries for HQ 7390
RAZOR replacement battery 2000mAh for men electric shaver philips hq 7390 replacement parts.
Jan 22, 2012 | Philips HQ7390/17 Williams F1 Mains...
My philips 6849 rechargable razor will not hold the charge for very long ,how do I correct this problem,? I have had this razor for about three years
The problem is that the battery pack is worn out and need replaced. You will need to see if this unit has one or two batteries. You will find these batteries at shaveroutlet.com. See links below for these two types
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the item pages for helpful videos for dismantling and installing new batteries
Jun 16, 2011 | Philips Philishave HQ7782 Electric Shaver
Can I change a battery in my philips hq7300 shaver
Philips STRONGLY recommends you do not insert any other battery into the razor, whether it be a normal battery, or a rechargeable battery. If your product is still under warranty you may be able to get a replacement.
Mar 01, 2011 | Philips HQ7300 7300 Series Shaver Electric...
I recently purchased HQ 6940 is it equiped with rechargeable batteries
Model HQ6940 is a corded shaver and has no batteries. For more information about this model, see the link below from shaveroutlet.com
http://shaveroutlet.com/shavers/philips-norelco-6940-corded-shaver.html
Dec 26, 2010 | Philips Philishave Cool Skin HQ6740...
Rechargeable batterys need replacing
You will find the compatible replacement battery at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/batteries/shaver-battery-pack-for-most-shavers-p-211.html
Remove back of shaver by taking out 2 screws on the back near the bottom. With back removed, you can access battery. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Dec 01, 2010 | Philips Philishave HQ5812 Electric Shaver
I have a 3805 Philips shaver - no low battery indicator - how do i know when charged?
The 3805 has only a green charging indicator. This light will illuminate solidly when plugged in. Charging takes a full 8 hours. There is no indicator to tell you when to recharge. If the batteries are in good condition, you should be able to use the shaver for 7-10 days on a full charge
Mar 13, 2010 | Philips Health & Beauty
Battery needs replacement
Replacing the batteries is not an easy job. You need to have a special Torx screwdriver to undo the screws.
The batteries are soldered onto the Control Board (it's unfortunately not just a case of cracking open the case and putting in batteries in an instant)
It may be worth speaking to your local Philips Service Center (refer to www.philips.com)
Your shaver should also be a Mains shaver - if you plug it in and it works full power immediately you've got a workaround. I usually recommend if you're replacing a shaver to spend a little more $$'s to get one that is mains and rechargeable so that when the batteries die, the shaver is still useable.
Apr 26, 2009 | Norelco Quadra 6846 XL Electric Shaver
Health & Beauty Logo
32 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
