Question about Nikon Coolpix L11 Digital Camera
Battery hatch broke
The hatch that holds the batterys in is broke an the batterys keep falling out (nikon coolpix L11)
  • USABOB Jan 28, 2009
    SAME PROBLEM HERE.. CAMERA STORE WANTS $ 24.00 FOR THE PART AND $ 55.00 LABOR.. NIKON SHOULD HAVE A RECALL ON
    THIS POOR DESIGN.. TAKES GREAT PICS.. BUT I FEAR THE BATTERY DOOR WILL BREAK AGAIN.. NEED A BETTER SOLUTION HERE..
  • 423 Answers
Well, your are going to have to become McGuiver if you want to fix it yourself, or else pay a pro to do it. I don't see any other way around your problem. Duct Tape...or a pro.
Posted on Feb 18, 2009
My nikon coolpix L11 camera keeps turning off
Sounds like a bad battery, when the battery gets old, it turns the camera off....
Mar 16, 2010 | Nikon Coolpix L11 Digital Camera
The latch on the battery door of my Nikon Coolpix
You can get that replaced or repaired thru the list of Nikon Authorized service centers near you area. Just click the link::
http://www.nikonusa.com/Service-And-Support/Nikon-Authorized-Repair-List.page
Hope this helps.
Dec 29, 2009 | Nikon Coolpix L11 Digital Camera
My Nikon coolpix L11 battery door does not close properly, or, the battery compartment is faulty. The camera has no dc power. Help!
Try using a dc adapter and pressing on the battery cover if it is loose. If it is loose go to bocaphoto.com for replacement door.
Sep 26, 2009 | Nikon Coolpix L11 Digital Camera
Keep putting new batteries in Nikon Coolpix L11 but keep saying low battery???
Check if the charger is working. If yes Firstly, make absolutely sure that you have a pair of fresh HIGH QUALITY batteries, in fact go and buy a couple of duracells. Digital cameras are notoriously power hungry and it is very possible that a pair of cheap standard batteries will not be able to run it for more than a few minutes. Check that the terminals of the batteries and the camera are clean. If none of this works, and you did have fresh alkalines or equiv. then it will have to be returned for repair.
Thanks.
Jun 18, 2009 | Nikon Coolpix L11 Digital Camera
EVERYTIME I CUT MY CAMERA ON IT CUTS RIGHT BACK OFF
Your camera continually shutting off (added with the fact that the battery cover is broken) probably means that your batteries are not making good contact with the hatch lid. You need to strap that battery cover down tight after your sure the batteries are installed correctly. Keep in mind, your going to have to strap that puppy back down every time you change batts. Let me know if this will help you.
Feb 04, 2009 | Nikon Coolpix L11 Digital Camera
Power going away..
Have you tried stretching the contacts upward to hold the battery more securely?
Jul 23, 2008 | Nikon Coolpix L11 Digital Camera
Lens error
Hello!!
please remove your batteries and press the power button for few seconds and replace the batteries now and try switching on ...
Regards
Smilemaker
Jul 19, 2008 | Nikon Coolpix L11 Digital Camera
Batteries wont work on my Nikon L11
Hello
i have used Digipower AA rechargable and Everready AA rechargable batteries without a problem lasting a long time in this model.
you may have a problem with the battery charger itself.
batteries i am using are rated at 2400-2500 ma
in the menu button, select shooting menu - set up - scroll all the way down to battery type, select the battery type you are using and press ok in the center of the button.
you can use the coolpix nimh selection for other rechargable brands.
May 31, 2008 | Nikon Coolpix L11 Digital Camera
Nikon cool pix L11lens error
Remove the battery, wait a couple of minutes, replace battery. (assuming the battery is fully charged. Check there is nothing jammed in the mech. if it still stays stuck.
Dec 30, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix L11 Digital Camera Logo
76 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
