Question about Dymo LabelPOINT 350 Printer
Dymo LabelPoint 350 has Tape Problems - even with a new label Cassette
The Tape doesn't move at all
SOURCE: changing ink?
I had the same problem. I just put in new batteries and it is printing fine. Are your batteries low?
Posted on Apr 29, 2009
  • 30 Answers
SOURCE: My Dymo Label Manager 350 wont feed the labels
Here is some great printer solution by Some FIXYA EXPERT. Get any kinds of printer solution from bellow.
akddij10
Posted on Sep 07, 2009
  • 7 Answers
SOURCE: I took out the tape D1 label cassette for the DYMO
I know this is too late for the psalter29, but here it is for others with the question. This piece is a cleaning tool. It is stored in the lid to the tape door. There is a small bar in the lid. The slot on the tool slides over the bar in the lid. The soft yellow pad should push down on the tape when the lid is closed. It is a cleaning tool for the print head. The user guide says "gently wipe the pad across the print head". The device should still work without the tool.
Posted on Dec 23, 2009
  • 14 Answers
SOURCE: Hi I'm wondering if the Dymo pocket will take a
The Dymo label printer capable of printing iron on tape is the Dymo Letratag. There are a couple of model printers
Dymo Letratag - handheld model
Dymo Letratag - desktop model with qwerty keyboard
and the Dymo 18771 Letratag iron on tape is the tape cartridge available.
Posted on May 06, 2010
SOURCE: Our Dymo labelmanager 350 keeps
how do i make the font bigger in size?
Posted on Jul 02, 2011
Have unit hooked up, but cannot get the vhs casset tape e to remain in player, keeps ejecting.
Typically a VHS tape has a button on the underside that unlocks when pressed inside the VHS player. The wheels unlock and move the tape in the VHS. If this doesn’t happen, the tape will eject.
Oct 26, 2017 | Televison & Video
I need to find a cartridge , Black on White for the labelpoint 150
http://www.suppliesoutlet.com/Dymo-LabelPOINT-150-Label-Tape-Cartridge-s/29083.htm
Dec 28, 2015 | Dymo LabelPOINT Office Equipment &...
Why am igetting no pressure reading on my gauge
Robert,
Assuming the pressure gauge is on a pool filter. These may be dumb or obvious questions but will start with them. Is the pump running? Is there water entering the pump and exiting the filter and returning back into the pool? Is the filter valve in the \'filter\' position? If the answer to all of these questions is yes then likely your gauge is bad. Try tapping it lightly and see if the needle moves. If needle doesn\'t move then gauge is bad. Easy to replace, use teflon tape on the threads.
Gary
Oct 17, 2014 | Pool & Spa
My dymo Labelpoint 100 won't print
Check the rubber wheel in the cassette compartment to see if there is any debris there. To manually re-set your printer, remove the batteries and press On/Off 20 times. If no avail, give us a call (contacts are on dymo.com).
DYMO help desk
Jan 29, 2013 | Dymo LabelPOINT 100 Thermal Printer
The DVD works fine but the VCR doesn't play, rewind or forward tape.
l would have a look inside to see if when a tape is inserted it loads and will ff and rew, if the transport that moves the tape has failed it will account for what is happening.
Aug 27, 2012 | Zenith XBV442 DVD Player/VCR
The PLAY function of my Cassette desk doesn't work anymore
Well two things have to happen to make tape move in a cassette deck. One is the Capstan shaft has to rotate and that is usually a belt link to a motor through a pulley. The second thing is you must have take-up torque. If the tape moves but the take-up reel does not pull it onto the take-up reel then you either have a eaten tape or the deck will shut off. in your complaint it could be any of these items- maybe a bad Idler from the reel motor or the capstan belt is old and stretched.
Aug 10, 2012 | Kenwood Audio Players & Recorders
1989 buick riviera tape cassette doesn't work
sling it its had its day,most likely its a drive belt broke but its also possible that the mechanism that turn it on inside the tape player has got a plastic clip /switch broke off with age .
Sep 22, 2017 | 1989 Buick Riviera
Will not reverse play on deck 2-just goes very fast on this
This condition, regardless of which way the tape is moving, is caused by the failure of a rubber pinch-roller to trap the tape between capstan and the passive roller.The speed is then caused by the part of the drive driven by a small belt and a clutch that should only keep a small amount of tension on the tape in ensure clean rewinding of the tape after it has passed the head.
Lubricant in part of the transport's moving parts or a dried-out rubber roller may be causing this.If you want to try to clean the pinch roller, don't use alcohol since this can further harden the robber.Use a clean fiber-free cloth or paper towel wetted with a LITTLE naphtha and turn the roller on the wetted area. If you get some dark smudging, the treatment is working.
Nov 23, 2011 | Sony TC-WE475 Single Cassette Deck
Cd in macbook wont ejec
This can be a problem. First try rebooting the machine, and holding the eject button when you hear the startup tone. Hopefully, that will force-eject it.
If that doesn't work, you'll need to get creative. Get a playing card or something similar, and put some rolled-over tape on one side close to the edge, so there's a sticky side out. Turn the computer off, and try to get the playing card into the CD drive, with the tape making contact with the stuck CD. Reboot, holding the eject button when you hear the eject button again, and pulling the card out. Hopefully, the CD will come out with the card. If it doesn't work, just keep trying, and you'll get it out eventually.
Generally what causes this is keeping CDs in the computer for an extended period of time, especially while the computer is powered off. Make sure you remove all CDs before moving or turning off your computer.
Sep 07, 2011 | Apple MacBook Laptop Computer Mac...
I have a used Marantz PDM510 dual cassette deck. Both decks seem to be doing what they're supposed to (tape is moving fine) except no sound is showing on the indicators and no sound is coming through...
I have a Marantz PMD511 which is almost identical. I'm not certain exactly what the difference is, but I don't think it would be anything that would make this problem not apply to either.
It's hard to imagine that both decks would go bad at the same time, but, of course, it is possible.
I'm guessing you problem is on playback. Of course, the very first thing to do is make certain that there is something recorded on the tape. Even if you think there is, make sure by playing the tape in another player...any player. One time a friend of mine laid a cassette tape down on a high-powered speaker laying in my studio, and the magnetism wiped the tape clean. So...make sure. A clean tape would be the most likely reason for your problem as you have described it.
Next, I'm thinking you've tried both decks, which remember, are totally independent.
Of course, if neither set of meters are showing a signal from either deck (A or B), it doesn't look good. Again, re-check the tape itself.
Good luck, Tom
Aug 07, 2011 | Audio Players & Recorders
Dymo LabelPOINT 350 Printer Logo
94 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Jax Planet
Jax Planet
jdthefixer
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
