Question about Panasonic CT-24SL13 24" TV
What is cost of yoke for panasonic ct tv?
Width of picture is cut to 1inch from both left and ri8 sides, the techinician says as change yoke as 110v(use new yoke ), is the ri8 way to get full screen? gopichand458@gmail.com
    Top Expert:
  • Panasonic Master
  • 75,417 Answers
You're discussing about the width problem to picture. If yoke have a short in between its wingdings [even a single winding short], will cause the failure of horizontal output transistor. As per you report here, the set has a raster, but problem is with the picture width.
There possibliliites for this fault are.
1. Lack of voltage from the SMPS power supply output.
2. Horizontal width capacitor.
3. Horizontal output capacitor.
Check the output voltage from the SMPS section first, and confirm that it is OK.
Posted on Jan 03, 2013
4 Suggested Answers
  • 205 Answers
SOURCE: picture in picture problem
When you use the Time Warner Digital box, you're using the tuner inside that box rather than the tuner inside your TV to select a channel. Picture in picture TV's have two tuner's inside so you can view two channels, but they can only tune the analog channels from your cable company, and only if it's hooked up in a manner that will permit this to happen.
So you only have one digital tuner (the Time Warner Box) so you can only view one channel at a time even though your TV supports Picture in Picture.
It MAY be possible to have limited use of the PIP if you connect your TV in a different way. Your Time Warner box is most likely connected to your TV set with composite cables, those are the Yellow, Red, White cables. If you buy a coaxial cable splitter and split the cable before it goes into the Time Warner box you can then run a coax cable into both the Time Warner box and the coax input on your TV. This would allow you to tune the analog Time Warner channels with both of your TV's tuners. In my area I think the first 60 channels or so are still available in analog, but there is no way to watch any of the higher premium channels without the Time Warner box.
If you go through these steps and you select the coax input on your TV your PIP will work on the lower channels. It MAY be possible to tell your TV to display the input from the composite cables on one of the PIP screens and the input from the coax on the other, but I kind of doubt it.
I know this sounds complicated and if you're not familiar with the way all this works it is complicated. The reason lots of people won't respond to this kind of question on this site is because there is no easy fix and by trying to help I run the risk of getting a bad rating. I don't get paid for this, I just like trying to help, so if I have not explained this in a way that's helpful to you please ask some additional questions before you give me a bad rating. Thanks.
Posted on Jan 01, 2008
SkinWill
  • 148 Answers
SOURCE: Ct-36g23
In older CRT televisions the horizontal power supply can start to degrade causing the picture to shrink.
Take it to a qualified repair man to have him replace the particular components that are starting to die. This repair will require identifying the particular component and replacing it.
Often times just finding the bad component can take hours of troubleshooting by a skilled technician.
Tho, before you take it in try ruling out one simple issue like bad mains voltage. Try plugging it into a different outlet in a different part of the house.
Posted on May 01, 2008
  • 17 Answers
SOURCE: Dead TV Panasonic CT 36HL42CF
have a visitation and bury the next day.
Posted on Jul 15, 2009
My tv yoke coil shorted.then i replaced it.old coil number is 6150z9243a.new coil is 6150s.so i cant get full screen in H side.i try to increrse using service menu.but cant.plz tell me the method
You have to adjust the capacitance value of the capacitor connected to yoke. The capacitor bypasses the scan output signal to yoke. It can be located at the main board. Connected to the collector of the horizontal output to deflection yoke. Decreasing its capacitance value will decrease the width of the picture, and increasing will do vice versa.
Refer any circuit diagram to horizontal scan section to locate this capacitor on board.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Apr 10, 2015 | Televison & Video
How can I make a buttonhole that's bigger than my buttonhole foot will allow
Measure the button, mark the size of hole you want with a pin at each end. sew 6 full width very close zigzag stitches at one end ending on left side , then sew down to the other end with needle in left position with #2 width stitches, at other end again sew 6 full width zigzag stitches finishing on right side, turn work right around and sew back to other end again with #2 width stitches.
you should now have a rectangle of very close stitches with a very narrow gap between them down the middle. carefully cut between the stitches and you have a button hole.
Feb 25, 2014 | Sewing Machines
I have 2 black spaces on each side of my screen
The width of the picture is less than normal. It can be adjusted by entering in to its service menu options. But, entering service menu options and adjusting data values there is a skilled task. It will be best to contact any expereinced service techinician ot do this. Or Visit the site named 'Electro-help' for more details. Check this link and select the site. View it in 'Flip card' option, which can be selected from the drop down box menu at the left top corner or the display window. It will make search easy. If you are confident that you can do this, just proceed. If not, do not tamper the TV.
Aug 05, 2012 | RCA F27450 27" TV
How shrink picture size in AKAI 14" portable TV
Less power output from the internal SMPS; usually 110v, may less. Horizontal output capacitor may leaky. Horizontal output transistor fault may occur. In rare cases deflection yoke assembley fault.
If the picture is stamped size; suspect the power supply. If the picture is less in width, suspect the above said capacitor, and the lenearity coil fitted on the main board.
Oct 13, 2010 | Akai LCT0510 5 in. Portable TV
Horizontal alignment ok, but right half not printing.
One of two situations exists:
1. If the printing stops with clear stopping edge, then the PRINT WIDTH setting has been changed from the default full width setting of 104mm.
Check this by pressing MENU and then the NEXT button until you see a setting for MAX WIDTH. It should be set to full width of 104mm. Anything less will stop printing beyond whatever the setting is. Change it back to the full width setting.
2. If the printing stops by fading away to the right side, then that is caused by a pressure imbalance across the printhead. There is more pressure on the left side than the right side. There are two toggles that press down on the printhead and the pressure can be adjusted by moving the right toggle to the right so that more pressure falls on that side of the printhead.
Hope that helps !
Jul 20, 2010 | Zebra 140XiIII Plus Thermal Label Printer
The picture on my TV has changed to a cone shaped, with the RGB variations separated. This happened suddenly, after an afternoon of watching TV and it working perfectly.
yoke coil has gone in ur tv .the yoke coil will be around picture tube which controls horizontal $ vertical width deflection. take the help of service person to change it with same type.
Mar 21, 2010 | Samsung TXM2790F 27" TV
LG 47'' LCD HDTV 120Hz - Incorrect Picture Width
I just had this problem and got it solved. The issue is that your cable box is likely set to the wrong aspect ratio, so your tv will not be able to display the picture properly without this setting changed. On my cable box(Pace), you need to turn the power off to the cable box using the remote. Then hit the menu button on the remote and a new menu will appear on the screen. Change the aspect ratio to 16:9 and you should be all set. Hope this works for you too.
Feb 22, 2010 | LG 47LC7DF 47 in. LCD HDTV
Width problem , front panel all switch working properly , but picture cut off 1'' inch bothside from horizontaly. please detaily explane.
HORIZONTAL WIDTH PROBLEMS COME FROM COMPONENT FAILURE OR BAD CONNECTIONS IN THE DEFLECTION CIRCUIT. FIRST CHECK THE POWER B+ SOURCE AND MAKE SURE IT IS UP TO NORMAL, SHOULD BE 130VOLTS THEN RESOLDER THE DEFLECTION CIRCUIT, YOKE RETURN CAPS AND DRIVER CIRCUIT. IF NOT SOLVED THE CAP IS BAD OR A SHORTED COIL IN THE RETURN CIRCUIT.
Dec 26, 2009 | Televison & Video
I need to find the pincushion circuit on my RCA F32632SB TV to check a problem with the TV displaying an hour glass picture. Where can I find a picture of this or a manual to guide me to the circuit?
The pincushion it intimately related to the horizontal circuits,the electron beam must travel farther to reach the corners of the crt and it does to the middle and so without pincushion circuits the raster would be bowed in on the sides on crts 27 inches are larger.Pincushion corrections straightens the raster by modulating the horizontal yoke current at a vertical rate.In an RCA tv the pincushion circuits are usually numbered 4800and the pin amp will probably be numbered 4801,its drive transistor should be Q4802,R4802 will be the width control,and R4805 the e/w pin amplitude. its inputs from the vertical should be Q4801 (subtractor) Q4803 (buffer) you should have a parabola waveform at 4801,yoke current can be modulated here without effecting high voltage.when Q4802 conducts voltage should decrease across Q4801 and the voltage drop across the yoke increases. The east west pin amp control 4805 controls how much of the vertical parabola is input to U4801 to compensate for changes in width caused by variations in beam current.By varying the e/w control resistor you can know if the circuit fault is in the input or output,if the picture varies in size the fault is in the input to U4801,if it does not vary check the output or U4801......hope that helps
Jan 15, 2009 | RCA F32632SB 32" TV
Problem with vertical
Is the left side normal? Side(s) cut-off,out of view might be a HV
width problem or a regulation trouble.Vertical adjustments will
not help---Horizontal width might----be sure to put the value back to what it was if change does not help.
Oct 12, 2007 | Toshiba 46H83 46" Rear Projection...
Panasonic CT-24SL13 24" TV Logo
85 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
