My snowblower was working fine and when I refilled it with the same mixture I had been using, it began emitting gray smoke and had very little power.
My name is Dane and I am going to try to help you solve your problem. Are you sure nothing is rubbing outside the engine creating the smoke? If this smoke is indeed coming from the exhaust, I would think that your problem has to be in your fuel. You may have mixed too much oil in the mixture or it has been contaminated with water. Remove your spark plug and make sure it isn't oil fouled. If you find it is, drain your fuel and either clean with a wire brush or replace the plug. Refill with properly mixed fuel and you should be good to go. It may smoke for a couple of minutes until the fuel in the lines works through the carb though. No harm done.
I hope I've helped. If you found this information useful, please leave feedback as deserved. Thank you! Dane
same thing . . . i noticed a little loss of power, but was still working fine. then about half way through the job i smelled the smoke and unpluged.
What type of snowblower and how big is your motor?
