Question about Epson Stylus C84 InkJet Printer
Red light 4 paper & ink are both flashing. I have put in new refi
Epson 3 in 1 wont start.
  • 1 more comment
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi margaretloug
    It's very difficult to help you if you ignore our queries. Please respond to the queries from websnail and gwbm and we can then make some progress with your problem.
  • Martin Smallridge
    Martin Smallridge May 11, 2010
    It's also the wrong printer model which makes this more confusing..
    Margaretloug: Could you please provide the correct model information for your printer and as gwbm pointed out, more information about which lights are flashing and in what sort of order, way, etc...
    We'll be able to assist better then...
    Cheers
  • Gerry Millward
    Your post is a bit sparse on information. Are the lights flashing together or alternately?
  • 353 Answers
In view of margaretloug's lack of interest in pursuing this problem, I think we can declare it "solved by poster".
Posted on Mar 22, 2009
Epson Stylus Photo 2200
Hi there. I managed to find an excellent resource that should help you solve your problem. Try the suggestions given here http://www.fixyourownprinter.com/forums/inkjet/24337 i would start with "holding both paper and ink buttons then powering on untill the paper light flashes and then holding the ink button for 10 secs" Let me know if this helped. D.
Aug 02, 2007 | Epson Stylus 2200 InkJet Photo Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Hi, Epson Stylus c62 printer problem. Turn on printer runs through start up cycle power light and ink light (red) flash alternate. Not out of paper or ink. Help Please
The Epson website says that if both lights are blinking, "An unknows printer error has occurred." They say to turn off the printer and contact you dealer (whoever sold you the printer).
Before you contact the seller or EPSON tech support, I recommend going through all the basic troubleshooting procedures (if you haven't done so already):
1. Remove and reseat ink cartridges.
2. Turn off the printer
3. Turn it back on again and see if lights quit blinking.
4. If still not working, remove paper. Check thoroughly for jams (and remove, if necessary).
5. Turn power off and then back on again and if still not working...
6. Turn off again.
7. Unplug and replug all cables to ensure a good connection
8. Turn back on and if it's still not working, it's time to contact the vendor or manufacturer.
Hope this helps...
Steve G.
Nov 02, 2010 | Epson Stylus C62 InkJet Printer
Red light stays on and printer won't print
My C60 Epson Stylus printer is not printing. First of all the paper jammed, I pull the paper from the front and since then the catridge holder is not going to the middle to print. also the green light keepon flashing and the red light stays on. I need your help.
Jan 16, 2010 | Epson Stylus C60 InkJet Printer
My Epson is printing pages in code and will not stop and the green light is blinking and the red is staying on. We put in new ink cartridges today.
zark4, The green light flashing means you have print jobs waiting to be printed. Don't Turn Off The Printer When The Green Light Is Flashing ! If you have paper in the printer, the red light means you have an empty ink cartridge. Because both things are happening at the same time, here's what you need to do. First click start. Click printers and faxes. Double left click the Epson C-60 Icon. Left click Printer and click Cancel all documents and click yes, then exit. Remove and reinsert your new ink cartridges to make sure they are seated correctly. After you have done this and the printer finishes the automatic charging of the ink cartridges, the lights should be back to normal. Green light on.
Oct 22, 2009 | Epson Stylus C60 InkJet Printer
Epsom R200 printer - ink and paper lights flashing red.
theres a guide on how to manually reset the counter here
unless you replace or clean the waste pad from here on in regard your printer as a ticking ink bomb. put it on a tray with a lip just incase of an ink overflow and dont put it on the carpet.
Sep 25, 2009 | Epson Stylus Photo R200 InkJet Printer
Epson i880 Waste Ink pad location
try this plz dont for get to rate
1. Turn the printer off.
2. Hold down the ink and paper buttons, and turn the printer back on.
3. Within a few seconds, the paper light will start flashing quickly. When it does, let go of both buttons.
4. Within 3 seconds press (and hold) the ink button.
5. Hold it until all three red lights start flashing (about 10 seconds).
6. Let go of everything.
7. Turn the printer off, and back on.
Dec 07, 2008 | Epson Stylus 880 InkJet Color Printer
2 flashing red lights
The printer jams each time I try to print, and although I think it's clear, it still jams.
Mar 22, 2008 | Epson Stylus C86 InkJet Printer
Repairing
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
