Question about Miele Touchtronic W1213 Front Load Washer
Remove drip pan on miele w1213 - Miele Touchtronic W1213 Front Load Washer
3 Suggested Answers
SOURCE: How to fix a Miele
check drain pump is not blocked if so clean out
Posted on Mar 15, 2008
  • 177 Answers
SOURCE: No Power lights, anything, on a Miele W1213
make sure the door is closed properly and push it hard as this completes the light circuit on the display and then allows the unit to work.
Posted on Aug 18, 2010
Miele washer leaking from soap tray (on rinse cycle). Can't figure out what's the problem. Please help.
Remove and clean fully soap tray. if persists could be machine leveling or water pressure too high going in so fast to tray that its unable to cope, in which case try reducing the water pressure. good luck
Feb 10, 2011 | Miele Touchtronic W1213 Front Load Washer
Fridge drip tray removal
remove toe kick on bottom of fridge, should be some screws on both sides. tray slides out, maybe not all the way dont force, there is a float mechanism that will stop it from coming out all the way, use some paper towels or rags to soak up the stagnant water, this pan should have a heater hooked up to it to evaporate the water, the installer should have hooked this up on installation, they dont hook it up at the factory to get a better EER out the factory door, just trace back to the pan and hook up any unplugged wires going to it, good luck
Oct 31, 2009 | Miele KF7642S Bottom Freezer Refrigerator
Miele coffee machine shows"watersystem fault"
Hello Wiesiek1,
The water system fault means that there is too much water on the bottom drip pan and it has tripped the sensor at the bottom of the machine. Usually removing the bottom grate where the cups sit and taking some paper towels and soaking up the water/spillage will fix this problem
Aug 29, 2009 | Miele CVA4070 Coffee Maker
Rinse light flashing on miele novomatic washing machine
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
Sep 02, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele 2104 Washing Machine
If your model is displaying the same symptoms as the W1930 that I repaired, then the cure is to replace or check the brushes on the main drive motor ($17) and check or replace the bearings ($12). This is much easier on the pocket book. I was able to confirm the presence of drive voltage (25VDC) to the motor terminals prior to the removal.
May 25, 2008 | Miele Touchtronic W1213 Front Load Washer
Miele Touchtronic W1213 Front Load Washer Logo
27 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
