Braemar ducted air conditioning turns itself on and cannot turn off
The unit is the older model that doesn't have a remote. You have to press the button on the wall unit. Lately it started to turn itself on and then after a few minutes it turned itself off. But today it turned itself on and keep going. We tried to turn it off at the wall unit but it wouldn't work. We then turned off the main for a few minutes and turned it back on and it still automatically started running. Please help as we have had to turn on of the main switches off but that has also affected half the hours sockets. Thanks and much appreciated.
  • Samantha Jan 06, 2013
    We turned it back on and found no cool air so ! went up onto the roof to have a look the unit and it looks like the pump isn't working. I managed to find the switch to turn off the unit.
  • 95 Answers
SOURCE: Thru-the-wall air conditioner won't turn on
Check for power at the plug in, if it's got power take it back under warranty.
Posted on Jun 10, 2008
SOURCE: TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: MY AKAI LCT3201AD TURNS OFF BY ITSELF
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Posted on Jan 11, 2009
bobotfel
  • 236 Answers
SOURCE: LG Split unit turns itself off after a couple of seconds of opera
Check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Reset the unit by disconnecting the power supply for 10 sec. then "on" again and start the unit. If it wont work you need a qualified tech. to solve the problem.Some of your safety device might be defective.
Posted on Feb 16, 2009
SOURCE: Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
Posted on May 29, 2009
I have the door bell style wall button-how do I unlock the unit so the remotes can be synched? I have pressed green button on back of unit with remotes but they won't operate the door.
You don't unlock anything to program the opener for the remotes. If everything is working you do this:
Press and hold the button down on the remote while you press and immediately release the smart/learn button. Do this for each remote.
Jul 11, 2012 | Sears Craftsman LiftMaster Chamberlain...
Most of the buttons on the panel do not respond when pressed. incl;uding, convection, setup, rapid preheat
Are the oven doors locked as well, check if the front panel lock is active. Press and hold both the upper oven Cancel and Cook & Hold buttons for 3 seconds (or a bit longer). (Off should disappear from the display and the Lock indicator will flash.)
If that doesn't help, try pressing Cancel. Then try pressng the Cancel and Cook&Hold keypads together. If this doesn't help, then the control panel or the control itself is damaged and probably needs to be replaced. (Touch pads like this have electrical contacts on a membrane that is impossible to fix long term by cleaning the unit.)
For a parts list and prices see: http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Wall-oven-Parts/Model-JJW9130DDS/1266/0125300/M0603043/00001?blt=06&prst=&shdMod= or http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170052&diagram_id=28429593 . Specifically part 1A and 2 are suspect. The control panel is the more likely part to fail (much like a membrane keyboard).
Most Jenn-Air appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=JA_EN_US . Fill in Consumer and then the model number and press the right arrow button. The direct link to the manual is http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10176680.pdf .
I hope this helps.
Aug 11, 2011 | Jenn-Air JJW9130DDS Electric Single Oven
How do we reset our telstar air contioning wall unit remote model #HYK-07...we changed the batteries but now it doesn't work
Hi Diane,
Your remote control has a reset button in front just below the timer button key. Press it using a pointed material like a paper clip to make it functional reset.
Let me know if the remote control still not functioning to assist you further.
Jdvillanueva
Aug 04, 2011 | Televison & Video
Hello, my MW511 Fiisher and Paykel top loader washer is not working, the lid locked light keeps flashing before the spin cycle and it keeps beeping and never starts the spin cycle... what can be wrong? I...
Hi - you may have somehow put the machine into data mode - its either that or the door lock itself has malfunctioned - the only other logical one is thw controller module.
I'm assuming its a Phase 6 - try this - press/hold wash temp & power button until u get 2 beeps & lights up - release buttons...
NOW IMPORTANT - be careful you are in memory system of the controller -
1. press start/pause to unlock/lock & toggle that lid locked lights - check default is off.
2. I think its either advance or regular to turn pump on/off.
3. try a few buttons see what happens - THEN
turn off at the wall & try it again, if it still doesn't work then we may have a more sinister problem which will require correct testing of the components.
This will require a thorough knowledge of how to interpret the test results, to nail the culprit.
Sorry cannot help further...
Jun 30, 2011 | Fisher and Paykel Washing Machines
I cannot turn on my surround sound on my Philips MCD700 Stereo using the remote, any ideas???????
So are you saying the remote doesn't work or that the unit itself doesn't work? Walk over to it and press the power button.
Read this procedure to possibly fix the remote:
http://remotes.com/remotes/servlet/rs?a=Display&contents=help_deadremote&uuid=A12963989782821
They also sell replacement remotes.
Zoom in on the picture of the original remote provided on the site (or look at your own) and get the actual remote model number.
or check eBay: search for "(model of the device or the remote) remotes", check the 'include description' box. Usually cheaper than the vendors.
Jun 28, 2011 | Philips (MCD700) System
I have a craftsman 315mhz 1/2 hp opener and both remotes stopped working. The light on the base unit is solid. I tried reprogramming the remotes both from the wall unit and from the opener. The overhead...
Sounds like your receiver has quit working. To program the remotes do this: Press and hold the button on the remote while you press and immediately release the smart/learn button. Do this for each remote. If this doesn't work your logic board is bad.
Jun 24, 2011 | Sears Craftsman LiftMaster Chamberlain...
My Samsung 20" CRT model # TX-P2036 has power
May be you should press the channel button on the set itself or there is a problem with the eeprom of the set circuit.
Jun 15, 2011 | Samsung TXP2036 20" TV
My Champion garage door opener opens by itself and the light does not come on
Look at the LED light next to the SMART/LEARN button on rear of the motor unit. You may need to remove a light lens cover in order to see it. If the light is flashing rapidly this means you have a stuck button on one of your remote controls. Take the batteries out of each remote control. When you remove the batteries from the bad remote, the light will stop flashing. This remote needs to be replaced.
If one of your neighbors remote controls is inadvertently programmed into your receiver, you door will open when their remote is activated. If this happens you will need to clear out your receiver and reprogram your remote controls. Press and hold the smart/learn button for 6 seconds or until you see the small LED light near the button turn itself off. If the above steps have been followed and the symptoms continue, there may be an electronic short in either the wall control button or the receiver logic board. In this case, remove the wall control wires from terminals 1 and 2 on the motor unit. Should the symptoms persist after the wires are removed, replace the receiver logic board. If the symptoms stop with the wall control wires removed from the motor unit, replace the wall control button, and the wires leading to the wall control button.
May 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Light and lock buttons nonfunctional
There are certain models that had only a door bell type wall control and didn't have the lock and light functions. You may have one of these and someone has replaced the wall control with the three button model. If it did work in the past and has quit it is most certainly the logic board and is expensive to replace.
You say it is STILL stuck in the "lock" mode. If you cannot use your remotes you need to program it. Find the smart/learn button just to the left of all those white wires. Press and hold the button on a remote while you press and immediately release the smart/learn button. Do this for each remote.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
