Question about Maytag Dishwashers
Remove lower spray arm on mdb7130aww
Jetclean eq plus
SOURCE: Maytag jetclean EQ plus dishwasher
I had the exact same problem. When the service tech came to look, my husband watched him. There was a disconnected wire to the motherboard which my husband asked can't the tech just reconnect it. The tech stated no, we needed a new motherboard. My husband reconnected the wire using tape for now & the dishwasher is working perfect. My husband is going to get somekind of calk/glue that will work permanently. This should save us from replacing the motherboard for a while. The dishwasher is only about 5 years old! My previous dishwasher was over 20 years old with no repair problems the over 10 years that I owned & used it.
I am looking for the self check test, does anyone know where I can find the instructions how to do it myself? Thank you
Posted on Jan 12, 2009
  • 236 Answers
SOURCE: Maytag Jetclean Dishwasher EQ Plus MDB7100AWB
the door seal has gone better change the door surround seal also. check for case damage and obstructions aswell.
Posted on Mar 14, 2009
  • 583 Answers
SOURCE: Lower spray arm does not spin on my bosch dishwasher
How to Check the Spray Arms Home > How To > Appliance > Dishwasher >Check 1x1.gif Caution: Please read our safety information before attempting any testing or repairs.
The pump/motor assembly pumps water up through the spray arms. The force of the water cause the arms to spin and spray the water and detergent mixture into the dish and glass racks. Some dishwashers have just one spray arm at the bottom in the tub, others have a second spray arm under or over the glass rack. Some dishwashers also have a spray tower that rises up out of the lower spray arm to concentrate an additional blast of water.
To access the bottom spray arm, remove the bottom dish rack. Reach in and spin the spray arms. They should spin freely. Lift up the spray arm from the end. There should some play in the arm allowing you to wobble it up and down. Inspect the seams of the arms for splits. If water sprays out of a seam, the dishes will not receive an adequate spray for proper cleansing and the force of the water directed at the door may cause leakage.
The lower spray arm may also have a spray tower. If it does, pull up the center part of it as far as it will extend and let it drop. It should lift and drop smoothly. You can also unscrew the tower by hand to inspect the interior for foreign objects that might clog it.
Remove the upper glass rack as necessary to access the upper spray arm. Repeat the steps above for the lower spray arm. The upper arm may not have as much wobble as the lower arm.
The water source for upper spray arm on some dishwashers may be through a tube which mates with the spray arm when the rack is pushed all the way back. Make sure that the rack is properly aligned with the water supply tube.
If necessary, the spray arm can be removed for cleaning or replacement. Unscrew the spray tower (if any) by hand and remove the bolt (if any) in the center of the spray arm. Otherwise lift and rock the spray arm until it comes off. Keep any washers in the same order as they are removed. To clean, soak it in warm water and rinse with a vigorous spray.
Posted on Mar 20, 2009
Maytag317
  • 1136 Answers
SOURCE: clogged filter
Hi, The mesh does not open. You will need to GENTLY clean each section with running water. Are you using powder or liquid soap?
The most common thing that plugs them is food particles. This unit is best served by pre-rinsing the dishes. The mess gets plugged to easily.
I hope this helps.
Vic
Posted on May 30, 2009
SOURCE: Maytag jetclean eq plus dishwasher: soap problem
This could be due to 2 problems: not enough water or water is not being pumped hard enough through the system. The 'not enough water' is easy to check - open the door in the middle of a wash cycle. If you have enough water (about 1" or more) then that is probably ok. The 'not pumping hard enough' could be as simple as plugged up filters and holes in the spray arms. Remove the racks and disassemble the lower spray arm and the filter assembly all the way down past the screen. Clean the arm holes, throughly clean the screen, clean everything. Pull the top spray arm and throughly clean the spray holes there. Put it all together and run a cycle. You should see a pronounced increase in the sound of the water spraying around. This should fix your problem - it did for me.
Posted on Jul 15, 2009
Maytag jetclean dependable quiet plus doesn't clean dishes
It sounds like you have a faulty float switch. It's cutting off the water inlet before the tub is full.
May 26, 2012 | Maytag Dishwashers
Maytag Jetclean Dishwasher EQ Plus, Model MD87100AWW making grinding noises 20 minutes into wash cycle.
You have debris down in the pump area. To get to the problem you will work from inside the dish washer and start by removing the spray arm and then using torx driver you will need to remove upper components of the pump/motro assembly to get to the debris. good luck
Feb 28, 2010 | Maytag Dishwashers
Mar 14, 2009 | Maytag MDB7100AWB Dishwasher
Dishes not clean. Lower spray arm possibly not moving.
Remove the lower basket so you can access the lower arm.
Does it spin freely? If not, remove and clean the rotating point. Make sure the spray nozzles are not clogged and there as no chunks of stuff inside the spray arm.
Jan 24, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Mar 11, 2008 | Dishwashers
Maytag jet clean dishwasher model# dwc7400aaw
Normally when you have low water pressure and/or cleaning issues, this an indication of a clog in your main wash pump. You will need to remove the lower spray arm and the coarse screen to get to the main wash pump sump. Inspect the impeller area of the pump. This area is usually where accumulations of debris collect and keep the pump from pulling enough water. Things like orange seeds, lemon seeds, bottle cap liners, chicken bones, and jar labels are just a few of the items I have personally found. Although, dishwashers do a good job at removing most food particles, they are not garbage disposals. I bet you will find a clog in the sump somewhere. Let me know if this helps.
Jul 31, 2007 | Jet Tech Systems STEALTH Dishwasher
Maytag Jetclean Super Quite Plus II Dishwasher
open the door when working and check the spray arms are rotating. if not, the jets in the spray arms may be blocked. very fiddly to clear but doable
Apr 07, 2007 | Maytag 24 in. MDB5600A Jetclean II...
Dishwashers Logo
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
