Question about Hitachi 32PD5200 32 in. HD-Ready Plasma Television
There is no power to tv after being transported but i dont no where the internal fuse would be in tv. to check it please help
I have got the remote either but i can get it as this tv was my mums. there is no red power lights when plugged in
    Top Expert:
  • Hitachi Master
  • 75,320 Answers
Actually this is not a user reparable work. If you are aware in electronics, and know how a Plasma TV works, you can repair this set. Otherwise, it will be better to get it repaired by any experienced service technician.
Normally fuse will come at different stages in the plasma TV circuits. If you want to now more about its circuit boards, and other functions, check this. There are details about the lay outs. Never attempt to repair it, if you're not qualified to do the work.
Posted on Jan 03, 2013
2 Suggested Answers
  • 4 Answers
SOURCE: I have no power to my Hitachi TV. It is plugged
try turning off main switch and unplug set then replug in wait 30 sec turn on main power and repeat then try if it works great if not power supply bad. i also suggest a ups universal power supply newer tvs sensitive to surges and brownouts also never turn tv off n on in short period of time will cause surge that trips protection circuit
Posted on Jan 24, 2010
GE TV. Will not power on with remote, or button on front of TV
check the circuit breaker in your main fuse box
check the fuse in the powerplug
check any internal fuses the tv may have
If none of these is faulty then you can call in a technician to diagnose what is probably a component fault
Jul 11, 2015 | GE Televison & Video
I got a sony tv model kv-eg25m20 and it just went off and now it wont switch on again. No red light nothing. Please help.
Start with basic checks like plug fuse any damage to its mains cable mains socket or any adapters (some have fuses people forget about). Check remote batteries and remote hide it from TV (I have seen a sick remote fire signals unknown to anyone and cause shutdown)
Unplug for an hour turn off its power switch then try again,if all these ideas fail, you are into a service call out because there is possibly an internal fault which will require an engineer.
Sorry for limited ideas.....
Mar 05, 2015 | Sony Televison & Video
Hi my tv will not switch on after power cut it's a wharfedale l22t11w-a can anyone help
Check for power at the wall outlet, check for a manual switch/circuit breaker/fuse on the back. Check the battery in the remote, is it good.
The internal switchmode power supply usually has a power disconnect fuse, it may have operated. Internal components are difficult to service unless your a trained tech with the correct tools to disassemble the TV. Suggest you take the TV to a repair shop.
Apr 07, 2014 | Televison & Video
Hitachi P50A402 wont turn on
Could be an open internal fuse or power supply failure. Bet the "tech" didn't check either before trying to sell you replacement boards.
Dec 08, 2017 | Hitachi P50A402 50 in. Plasma TV
Hello my name is chris. i recently moved into a friends house and i transported my tv to his house. lg sl80. well when i get in there i plug it in and the red power light doesnt come on. any suggestions on...
Hello Chris.
I would double check the power lead (and fuse if in UK).
Check also the socket is working or try another power socket.
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | LG 47SL8000 47 in. HDTV-Ready LED TV
Tv wont turn on
Check the ff:
1. Power plug - for open internal wire due to frequent bending,pulling.
2. Try to power by remote - if power up by remote then you have a faulty tack switch.
3. Replace Internal Fuse - sometimes because of power surge the fuse fail. However if the fuse blew again this is an indication of shorts.
Next step is not Diy because of the ff reason
3. Voltage regulator - might be open or shorted.
4. H-out transistor - shorted
5. Open fusible resistor in line with the B+.
6.Dry joints
Thanks for using fixya.
Pls rate my help.
Jan 25, 2011 | Hitachi Televison & Video
Could the front contol panel be bad if my T.V. dont turn on
More likely no power to set; either no AC from plug outlet, or internal fuse in power supply.
Apr 19, 2010 | Mitsubishi VS-45607 45" Rear Projection...
Had power outage while tv was on. When power restored I turned on tv with remote. TV sounded like it went on but no picture. Only timer light lashing. Sony Wega older model 27" Please help, thanks
next time dont leave your tv pluged on power, the power supply got burnt, check your power supply on the following components
fuse, power transistor, zener diodes,also rectifier diodes
if you can manage do it at home
or take it to a w/shop
Apr 17, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
I have a goodman LD3755HD TV tonight we had a power cut while the tv was on . now the power is back I cannot get the tv to turn on. Tried fuse, batteries in remote, all the usual. is there a reset button...
It could have blown the internal glass fuse/s on the power supply otherwise its a component on the power supply board. Failing that it would have to be in fornt of me lol. Good luck.
Sep 29, 2008 | Televison & Video
Hitachi 32PD5200 32 in. HD-Ready Plasma Television Logo
51 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
