Question about Mitsubishi HC900 Multimedia Projector
Replace mirror if HC900
My HC900's mirrors is damaged . where i could buy another to replace?
    Champion:
  • Mitsubishi Expert
  • 225 Answers
How do i remove the mirror on the hp laserjet 1200
Not required to remove mirror to avoid abnormal sound. The mirror is a part in Laser scanner assembly to reflect the image on OPC drum in various angles depends on model. In your series 1200 having single mirrored scanner assembly mounted on top area. To remove this you need to remove right,left back & top covers.. The laser scanner protect with four screws & two connectors. Remove all take out the unit. For removing the bonnet single screw protection remove this screw, take out cover. Inside you can observe a motor with four faced reflector. While motor got the energy it will rotate, if motor lubes are dried up it will make noise, remove motor head gently,(to remove take out entire motor unit with PCB which protects three screws, you cab observe black 'U' shaped plastic lock unlock it & pull motor up, apply lube to rotor & refix it back, ref see the drawing, you want to clean the mirror? ear bud you can clean surface of the mirror gently..
But it is no so easy, bare hands you cannot handle the mirrors, If mirror disturbed its factory fitted angle its very difficulty to back its own position. Removing the motor also difficulty,motor head carrying 4D reflector, while removing any scratches, or finger prints will damage the quality of prints some times scanner error appears.. 9_5_2012_11_07_49_am.gif
Sep 04, 2012 | HP Office Equipment & Supplies
Need to replace manual LH side mirror control bezel.
You do not need a part number
You go to a dealers parts counter &
buy what you need
Jul 17, 2012 | 2003 Chevrolet Malibu
Driver side mirror replacement
Instructions1.
    • 1
Remove thedoor panel. Refer to your Honda Accord repair manual for theinstructions in removing the door panel. Unhook the rods and connectors on theinside of the door panel and set it on the floor.
    • 2
Remove thefilm covering the access to the side mirror. It's difficult to avoid damaging thefilm while removing it so you will need to purchase a new piece of filmcovering when you buy a new side view mirror.
    • 3
Reachthrough the service hole into the mirror housing with a screwdriver. Loosen thescrew that holds the mirror. Twist the screw out with your hand.
    • 4
Reacharound the door and support the mirror with your other hand. Continue to twistthe screw out, then catch the mirror as it drops out when you remove the screwcompletely. Put the screw in a safe place so you don't lose it.
    • 5
Installthe new side view mirror by positioning it where the old mirror was. Insert thescrew you took out in Step 4 and twist it in with your hand. Insert ascrewdriver into the service hole to tighten the screw.
    • 6
Replacethe film covering that was damaged when you took out the old mirror. Push itinto place in the indentation on the door.
    • 7
Sit in thecar seat and adjust the mirror so you can use it properly.
Jul 06, 2012 | 2005 Honda Accord
Tried flexing my driver side mirror Fri & the connector at base of the mirror broke. Had to hold onto it all the way home! Friend says, [?] unplug it, replace it w/ a temporary mirror, look for a...
I would let someone duct tape it to the car temporarily. Tape & glue can be removed with cleaner later on and you need to operate the vehicle. That will give you time to get information from all sources and make the correct decision.
Gary
Sep 04, 2011 | Car Audio & Video
1999 Pontiac Montana DRIVER SIDE mirror attachment broken.
The most inexpensive cure is to replace it entirely. I've gone to dealers to buy small parts & paid more for the small parts than the entire item costs elsewhere.
I didn't of course call & verify the exact price since I can't see the damage so I'm going on years of replacing mirrors others have broken off & asked me to repair.
You can see the part in it's entirety on eBay at a reasonable price for heated & power, see item #
110440973578 priced at 48.00 incl. S&H.
good luck
Feb 15, 2010 | 1999 Pontiac Montana
How to I replace an electric drivers side mirror on a Ford Focus
Go to a breakers yard or ford, you will have to unscrew & pull off the interior cap on the insde to udo the mirror whole unit & pop the glass out of the old unit by pulling carefully, then disconnect the motor & wiring, then re-fit as dismantled.
Hope this helps, If you can't do it yourself then buy the mirror & take it to a decent garage as they are not hard to replace & the dealership will charge twice as much !
Hope this helps !
Sep 22, 2009 | 2005 Ford Focus
Oldsmobile silouhette passenger side mirror glass broken
u can buy just the mirror element, they snap in and out (this assumes no other damage but mirror), when u get the new mirror u will see how it is installed, 5 min job max. the peel and stick won't fit right
Apr 08, 2009 | 2003 Oldsmobile Silhouette
My passenger side mirror was damaged by a tree falling on it. (just missed my car thankfully) the mirror is intact but the casing is cracked. Do I have to replace the whole casing with mirror?
The mirror will pull out. There are two power control arms behind the mirror and in the center is sort of a ball and joint connection. Pull firmly and the mirror will come off. However you can buy a mirror assembly from a salvage yard and have the mirror already attached. I recently replaced one on my Excursion. I have a casing with no mirror.
Mar 28, 2009 | 2001 Ford Excursion
Replacement of rear view mirror S60
We own a 2004 XC 70 Volvo AWD. The interior rear view mirror decided to die. There is a discolored patch (bubble type) in the middle section of the mirror. A new one will set us back a cool grand! Does anyone out there know how to fix it?
Volvo dealer says:
  • It cannot be replaced with a used one.
  • It's software operated.
  • A similar one from a similar car will not work, It will play havoc with other components, ie: sun roof, electric windows, etc.
All I needed was a new battery. They installed a new one, and I think that's waht caused the rear view mirror to go bad. They probably shorted the system as they were installing the battery.
Thanks
Feb 19, 2009 | 2002 Volvo S60
Broken driver side mirror
You can buy replacement stick on mirrors at most auto stores... different sizes or you actually cut it to the size you want.... cut out a peice of cardboard to make a template till it fits right on the mirror on the car and use that to get the replacement mirror you need or cut the replacement mirror to size.... peel off the paper on the back... then line up the mirror and push firmly starting in the center of the mirror working outward to make sure the sticky side sticks.
Robert
Sep 23, 2008 | 2008 Chevrolet Cobalt
Mitsubishi HC900 Multimedia Projector Logo
44 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
