Air con will go on for problem approximately 5 minutes then 6 Green lights will come on then Aircon will turn off can iFixit and how much thanks
    Genius:
  • 1,669 Answers
Aw, come mon! How do you expect anyone to help you without the name of the air conditioner, the model and more details?
Posted on Jan 03, 2013
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
skrbin
  • 121 Answers
SOURCE: samsung aircon turns in 5 sec. lights green/yellow flashing
check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Posted on Feb 16, 2009
  • 10865 Answers
SOURCE: unable to turn on aircon with remote control and no manaul on button on the air con unit
I recommend putting new batteries in the remote. If that alone solves your problem great. If not, get back and let me know
Posted on May 25, 2009
  • 68 Answers
SOURCE: I have a Danby DPAC 8020-5 air con unit. Air con
is there a flashing light on the unit? If so it will correspond to a needed repair. check your manual to match the number of flashes to the warning it is giving you.
Posted on Aug 03, 2009
  • 6 Answers
SOURCE: Water dripping from air con use
If the unit is mounted on an outside wall check the condensate drain that comes out with the line-set to the outdoor unit. If the pipping goes up into the attic than you have a small condensate pump that may have failed. The float in the pump may have stuck in the down position not allowing the pump to come on.
Posted on Nov 08, 2009
Fujiaire air con operation green light blinking
Most likely logic fault - shut power 100% off at breaker box for 5 minute and turn back on.
Nov 06, 2016 | Heating & Cooling
Not cooling and shutting off, indicator light flashes
the outdoor indictor light on my lg split comes on after some minutes on the one inside and the cooling has reduced please can any1 tell me what the problem is
Jan 18, 2013 | LG LSC121PMA Split System Air Conditioner
My mazda 6 v6 2004 smell oil when starting ventilation
The smell is typical of older Mazda aircon.
Purchase an aircon cleaning spray which is discharged into the aircon system by selecting recirc , cloing the windows for 5 minutes . This cleanses the system which is probably contaminated with bacteria.
Recharging your air con will help as well. The smell is due to evaporate condensed water mixed with sludge and bacteria .
Sep 20, 2011 | 2004 Mazda 6
After I changed the battery of the remote the AC will not respond. I have to turn on the AC manually. T
dear sir
please turn off the switch of air con and after two minut turn on, your main electric soures for reset the settings then it will show to you on it,s display Green light. it is sign of power supply after that you can use your remote control with your air con,
hope answer the question
thank you
please vote!
Sep 25, 2010 | Fujitsu 24C1 Air Conditioner
Jaguar xk8 air con light flashes then turns off but air con is on
this is most often caused by a slightly low charge of refridgerent, as the engine heats the system the gas expands and the light goes out.
Apr 08, 2009 | 1999 Jaguar XK8
Samsung aircon cuts off. lights green/yellow flashing
Feb 11, 2009 | Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
Feb 11, 2009 | Samsung Heating & Cooling
Bmw 318i air con switch
the light should be on when air con is working. only works when the blower is on ,ie heater blower switch on=air con light lit up = aircon working.
Oct 16, 2008 | 1997 BMW 318
2001 Audi A6 air con
The econ button allows you to set the heating manually, With this button pressed only manual heating is on and aircon is off.if you want heating and aircon off press the OFFbutton
Jul 01, 2008 | 2001 Audi A6
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
