Netflix comes through tv audio which i cannot then hear through reciever. (all other connections work fine, ie: satellite, game, dvd player, etc.) Just need tv audio itself to be read by receiver directly. What do I do?
If your TV doesn't support audio return channel (ARC, which is your TV audio routed back to the receiver through the same HDMI cable), you then need to connect your television audio-out to your Onkyo TV audio input, using a digital cable or an analog one according to the connections on the back of your TV. If you use a digital connection (optical or coaxial), make sure you have the proper digital port assigned to TV on the onkyo I/O assign menu/digital inputs.
In case your TV does support ARC, you need to activate it in the Onkyo's hardware/HDMI setup menu, either by turning on HDMI control (tv or receiver control each other via cable), or by turning ARC on (you'd probably need to activate ARC on your TV as well).
Hope this help,
M G
SOURCE: Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
SOURCE: have a new sony video/dvd recorder RDR-VX535 - cannot get sound thru the receiver
WHEN RUNNING TV OR DVD THROUGH RECEIVER YOUR AUDIO CABLES NEED TO RUN FROM "AUDIO OUT" ON TV OR DVD TO "AUDIO IN" ON RECEIVER.
SOURCE: Audio Problems
See www.avforums.com/forums/onkyo-owners-forum/696423-faq-setting-up-ps3-onkyo-amp.html
This should give you the info to set up the ps3.
SOURCE: I have a Sony BlueRay
alot of times , you need to go into the bluray menue under audio, and make sure audio output is set to hdmi, and not componant
