Question about Nikon D40 Digital Camera with G-II 18-55mm Lens
Hi, I have a Nikon D60 and when I turn off the flash (because its too bright for my daughter so she always ends up squinting in the pictures) the pictures turn out very fuzzy. how can I fix this?
    Sergeant:
  • 321 Answers
Go to flash mode menu, off the TTL AND KEEP MANUAL 1/16 FLASH RATIO and then control ur pic.by setting ISO
Posted on Jan 11, 2013
akuss15
  • 9 Answers
SOURCE: I think my flash is too bright?
first check exposure compensastion. make sure its zero. After that set flash to i-TTL. Note that you must have some distance from the subject so that the light will have space to spread. D40 with kit lens cant do macro shot. Eventhough its on automatic mode, to near with subject can make the picture to bright.
Second, check your ISO. when condition is bright, use ISO 200 and lower. Its advised not to use fully auto mode, use P instead. P mode is also automatic mode with some fixed value like the ISO and white balance while automode, everything is automatic. this can make your camera confused with your needs.In P mode, the camera will adjust the shutter and aperture for you. Or try shot with A or S.
third. Use the right metering. Metering function is to supply information to the body on how to adjust the value. Its advised to point and half press shutter at the well balanced light part of the scene so that the picture will not over or underexposed. Use the AE-AL lock function to lock the setting. Try each metering.
bear in mind that internal flash fire direct flash to subject not same ad external lighting that you can bounce to the ceiling. Normally internal flash only use to fill-in the scene, which main lighting is supply from external flash.
Hope this help you.
Posted on Nov 05, 2008
Steve5
  • 423 Answers
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
Posted on May 30, 2009
HyeProfile
  • 35 Answers
SOURCE: Nikon D60 use of Display to take pictures rather than view finder
The Nikon D60 does not have "live view" capability, so you'll need to use the viewfinder to frame you shots. If you need "live view" capability, consider purchasing the D80 or D90 instead with offer the feature...
Posted on Jul 10, 2009
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Posted on Aug 24, 2009
  • 1566 Answers
SOURCE: Have a Nikon D60 and after I take a photo, I get
You need to press the Disp/Display button to remove the settings on the display.
Posted on Sep 22, 2009
Testimonial: "Also had to use the multi selector to get rid of it. I now understand the process. Thanks"
My flash on mt d60 camera is way to bright
Could have different causes. If you are using an Nikon flash, you should put it on TTL and your camera on automatic to check everything is working correct. Then you can change to all other modes and the camera should also tell the flash when to stop.
If you are using an other brand, or a wireless trigger, you have to adjust the camera settings yourself. Not knowing what flash you are using, and not knowing what settings you have dialed in on your D60, this is the first thing I can think of.
Perhaps if you keep having trouble, you give me some more details and I hope to be of any help then. Just a quick question. How is the light on the pictures when you shoot normal? (Without flash)
Dec 02, 2014 | Nikon Cameras
Hello. My built in flash on Nikon d60 wont fire. Its just a picture of a flash followed by a question mark. I tried all sorts of settings, M, A, S, P, Auto, etc. but still no flash. As I said, when i look...
Software glitch also ends up in similar problems, best bet is to go the service center, where they reload the software at a minimal cost, (If its on warrantty, free of cost)
Oct 22, 2010 | Nikon D60 Digital Camera
I have a Nikon D60 camera. Switched it on today and there is no image in the LED display when I try to take a picture, the screen is black.
That's normal for the D60. It works the same way SLRs have worked for half a century: you view and compose through the optical viewfinder, then snap the picture. The D60 lacks the Live View feature of more recent dSLRs; the LCD (not LED) display on the back is for menus, settings, and reviewing pictures after you've taken them. It is not for composing and framing your pictures.
Apr 01, 2010 | Nikon D60 Digital Camera
Nikon d60 When I try to take a picture with the
That is a problem that has to do with the Flash...make sure your flash settings are not turned on. If the flash can't find an image...it rotates and usually never finds the image. It's reading in a Flash mode.
Mar 25, 2010 | Nikon D60 Digital Camera
Photos are dark despite settings saying they're ok
Hi
It is possible that the EV control has been switched on. This will look like this +/- and is usally set to 0. Try that perhaps.
I am uncertain what you mean by MANUAL since if it is true manual control of exposure the whole point is that you can select the level of brightness you want.
Best of luck
marti
Sep 19, 2009 | Nikon D60 Digital Camera
Nikon D60 is taking very dark pictures!!
elis - did you ever solve this problem? the same thing is happening with my d60 and i don't know what to do!
Aug 14, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Nikon D40 Digital Camera with G-II 18-55mm Lens Logo
42 people viewed this question
Top Nikon Cameras Experts
Greg Cann
Greg Cann
Are you a Nikon Camera Expert? Answer questions, earn points and help others
