Question about 2000RS-M Remote Starters Manual Transmission with Two 5-Butto
How to use REMOTE CAR STARTER OMEGA 342-02?
Bought used car with Omega 342-02 remote car starter installed, but with no manual.
Car stays running with omega mars #343-02 car starter
if you know how to get in to programming, That is programmable feature, You can change that to 10, 20, 30 minutes, I think yours is 30 minutes. This is the link for the owners manual,
http://www.caralarm.com/manuals/MARS/MARS-10&11.pdf
Jul 31, 2013 | Omega MARS-22 Remote Vehicle Starter with...
I'm not really clear on how this remote start works. It seems as though I have to stop the remote start (cut car off) in order to unlock the doors. I have a separate keyless entry and having issues as to...
It is a common problem with factory remote keyless entry (RKE) systems when a remote start system is installed. Many RKEs will not operate when the ignition is powered as the case when engine is running under the control of the remote starter. There is no easy solution to get around this safety feature if you insist on using the factory remote to operate the door locks. The best option is to use the MARS-22 to control you door locks.
Jan 23, 2011 | Omega MARS-22 Remote Vehicle Starter with...
Do the mars remote starters shut off your vehicles fuel pump?
ive installed many remote starters. ive never seen any that are wired into the fuel pump. they tap into your starter wire from the ignition.
Feb 16, 2010 | Omega MARS-22 Remote Vehicle Starter with...
Car starts but shuts off after 15 seconds
Here is the link to get the manual. http://www.caralarm.com/manuals/MARS/MARS-22.pdf
See pages 20 & 21 ( see picture) With the engine running you will turn either the Smart Start or Tach Wire adjust screw, depending on which setting your box is set on. You will turn one or the other until the LED LIGHT blinks consistently.
Feb 10, 2010 | Omega MARS-22 Remote Vehicle Starter with...
My boyfriend has an Omega car starter in his Chevy 1500. Recently he had to replace the battery and now he doesn't know how to reset the car starter. And of course we can't find the manual!! Help!!
There will be a few step you will need to do. First we will need the model number of the Omega car starter Also the year of the truck. I would need to see if there is a bypass module and if so what kind of module. The module might need to be reprogrammed.
Nov 06, 2009 | OEM Systems Vehicle Parts & Accessories
2000RS-M Remote Starters Manual Transmission with Two 5-Butto Logo
621 people viewed this question
Top Scytek Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Scytek Vehicle Part and Accessory Expert? Answer questions, earn points and help others
