Problem with Canon PIXMA MP780 All-In-One InkJet Printer
Can't print in Black ink
I have this printer for a while and I was very happy with it. A couple of days ago the black ink stopped printing and now I can only print in color. I havent changed anything in the setting or in the printer it seems to happened without no reason. Did it happened to anyone else? is there a solution or do I have to buy a new printer???
Posted by avatar on Jun 26, 2007
    • By avatardonnad270 Dec 09, 2008
    • REPLACED THE CANNON 3EBK CARTRIDGE AND NOW IT WILL NOT WORK, WAS DOING FINE BEFORE THEN. WILL PRINT ALL THE OTHER COLORS. HAVE DONE DEEP CLEANING ETC.
      I GUESS I NEED TO ORDER NEW PRINT HEAD.....
    • By avatarGuest Sep 23, 2008
    • i can't print in black i got canon mp530
    • By avatarletsail Sep 06, 2008
    • I have a cannon mp530 which will not print in black text. It will print in color but not in black.
    • By avatarleagil Aug 28, 2008
    • We have a pixm 780 and was in the mddle of photocopying a school project 10 pages...on the 3rd page it stopped printing black. we have done numerous cleans and deep cleans. all the colours seem fine it's just the 3e black. I have read the comments below, how do you remove the head to try cleaning it? I know how to get the ink out (obviously) but not the head.
    • By avataral_bert_1 Aug 27, 2008
    • I have a HP printer and I want to print in black print only . My printer has six colors , one being black . I want to know how I can turn the colors on and off and use black only when I want to .
    • By avatarchilebeen Aug 04, 2008
    • I had the same problem. I went through all the cleaning cycles but it still wont print black and the auto head align fails repeatedly. I resolved this by spraying a little windex into the area where the black ink nozzles are resting. (that would be the printer head?).. anyhow, I let it sit for about 5 minutes, reinserted the black cartridges and then used the nozzle clean. This actually solved the problem and it is now happily printing black again.
      Hope this works for you too.
      Heidi
    • By avatarGuest Aug 04, 2008
    • I have the same problem. It will not print black. Went thru all the cleaning cycles but the auto head align fails repeatedly. I havent a clue how to get the print head out as it appears to be a clogged head. I did just spray a little windex down where the ink heads are positioned. Where is the print head and how do you remove it?
      thanks
    • By avatareasthamilton Jun 26, 2008
    • When photocopying, cannot print black copies, everything comes out pink (magenta).
      When I use the printer black works fine.
      I have filled both blacks 3 and 6.
    • By avatarLarhody Jun 17, 2008
    • Unbelievably, I, too, have the same situation.  I will try and use the Print Head cleaning with alcohol to salvage this printer.  Previously, it had worked quite well.  I only use for light duty and it should not be on "the blink" this soon.  Happy that the rest of you have also shared your comments.  Thanks!
    • By avatarGuest Jun 15, 2008
    • the following ink may have run out : black
    • By avatardasvater Feb 19, 2008
    • I have the weirdest bug with that printer. It was installed with an old computer running win98 and worked just fine. Then we bought a new computer running XP and suddenly the black ink stops printing. If I plug it back in the old computer it prints fine again. New computer, nothing! Ever heard of that one?
    • By avatarkbslats Dec 07, 2007
    • I have the same problem with the Mp780. I've wasted alot of ink trying to deep clean, but it doesn't seem to help. I'll try the alcohol and see if that works.
    • By avatarrosa1906 Dec 03, 2007
    • I have the same problem with a PIXMA MP 760. Have cleaned, deep cleaned and changed the cartridge. Still, the same probem.
    • By avatarcurly wurly Dec 02, 2007
    • i have a canon i470D the black ink started to miss sections of script out, so i changed the black cartridge for a new one. This has not worked as there is no ink coming out now. I've tried deep cleaning and every other maintenance on the maintenance page but nothing has done the trick, please can anyone help with any ideas.
Solutions (14)
Best Solution
I had the same problem I found this solution to be very effective:
* Buy alcohol solution (70% or more). You can find it in any drug store.
* Remove both cartridges from the printer head. Unplug the printer head from the printer body. Pour the alcohol into paper towel layer.
* put the printer head on the top of wet towel with the face of HEAD touching the towel.
* clean the head with the towel and get rid of all the built-up ink on the head.
* Pour the alcohol into the printer head container (ink-receptacle area is where the ink cartridge normally sits, notice a small hole where the ink flow into the printer). Do not touch any electronic parts and let it dry over night.
* Do step 2-5 again if necessary.
* Install the cartridge back to the printer and run several head cleaning maintenance, print nozzle check, make sure to repeat this step until no more dead nozzle shown.
It worked for me :0)
The solution for this is simple. With respect to the canon iP4200 (and I suspect other printers of the same ilk) all you have to do is remove the printhead and clean the fine mesh screens in the bottom of the printhead with a Q-tip and water. Clean them until the Q-tips come away clean. Also moisten a paper towel with water and gently rub away the ink accumulated on the bottom of the printhead around the electronic contacts. NO need to leave the printhead out to air dry overnight or use isopropyl alcohol. Hope this helps someone out there.
I'm not the patient kind of guy, and I did this with my canon ip4000:
removed the ink tanks, got the print head out (easy!) and held it underneath running hot water (from the tap...). Shook it, let it dry a few minutes on toiletpaper and put it back in. Deep clean on all tanks and now it works perfectly.
Don't know if I should recommend this method though... :)
If the printer works fine hooked up to an older computer but does not print from a newer computer, the ink tank which doesn't print probably has a date chip which the newer computer is reading that the tank is "out of date" so won't print. You can check this out by changing the current date in the computer to several years earlier...then if it prints, that is your problem. Even brand new tanks can be out of date if they sat in the store too long! I don't know if new tanks for older printers have the date chip or not.
  • By Author imagemmv33 Dec 22, 2008
I found that I could remove the print head (after removing the ink cartridges). Then I used a q-tip and plain water to remove all the ink build up from the print head. It takes a few q-tips to get it all, but the printer now works fine.
we had the same problem with our MP780 it started with spitting ink all over the place, and then the black just quit. We were set to buy another printer. Took the print head out and it is totally gummed up with ink, Wife is cleaning it now with a pile of Q-tips. I am sure that this will solve the problem. Thanks for the solutions.
where's the nozzle area and electric contact are????
Have tried everything :( Soked in water many times, tried alchohol, still not printing black. Are there any cleaning kits out there that might work?
Oh my gosh... I could have saved myself so much grief - and ink - if I'd only looked here for a solution much earlier!
Elsewhere on this site I found advice on how to remove the print heads on my Pixma 780, then I used a handful of Q-Tips as recommended here. I did slightly wet a few of them and blotted excess water on a paper towel to get the more stubborn spots (it worked like magic). Then a couple of deep cleanings and in no time I had my printer working like new.
Thanks to everyone who took the time to help this technologically challenged mom get back on track!
If your print head needs replacing remove it and immerse nozzle area in a small ammount of very hot water (don't wet the electrical contact pad area) leave it to soak for a few minutes, change the water a few times then dab printhead nozzle area down onto kitchen tissue to remove remaining water.
I cant print in black how can i fix this problem on a ( lexmark X2400 )
I had a severely stopped up black on my Canon Pixma IP3000 printhead, I hadtried deep cleaning four or five times with no success, so I took an old empty tank and filled it with printhead cleaning solution cleaned it twice and put the original ink tank back in and printed, but still had skips so I repeated cleaning two more times and WALLA success. Now prints as good as new.
Bill85
  • By Author imageBill85 Aug 21, 2007
Buy an HP
  • By Author imageGuest Aug 12, 2008
First of all the print head is clogged just because you have tried to print repeatedly while some of the cartridges are empty. This results ink burn in the nozzle and clog. My recipe: Heat some drinking water in the kettle (70-80 C). Put the head in it and shake gently several times until ink is completely clean (10 minutes). Change the water do the same again. Change the water again (70-80 C) this time put a spoon full of apple vinegar (becomes a natural acidic solution very dilute) shake again, clean with cotton stick. I did it and started to love my mp800 again as much as I just bought it, all colours come back and started to print superior photos again...... Do not touch heads' copper poles and cartridges poles because of the static electric they may mulfunction and colours may becaome totally mixed for a short while...
Add Your Solution
See all Canon PIXMA MP780 All-In-One InkJet Printer Problems
