Question about Water Heaters
I need to replace the lower element on my Bradford White Electric Water Heater. Where can I find the element and directions to replace it?
  • Water Heaters Master
  • 5,245 Answers
1) Copy following link for testing steps, and clear steps how to replace water heater element on residential water heater.
http://waterheatertimer.org/How-to-replace-water-heater-element.html
http://waterheatertimer.org/images/element-wrench-on-element.jpg
2) Your Bradford White most likely uses screw-in type element
Older models use flat flange type element.
3) Buy elements at local hardware.
Match wattage of new element to wattage that shows on label on side of tank
Posted on Jan 03, 2013
2 Suggested Answers
SOURCE: I need an upper element for my Bradford White
Go to your local hardware store, i perfer lowes or ferguson's
Posted on Oct 08, 2009
No hot water
First check the power make sure that is working if it is replace one or both elements. makes sure you match up the watts and voltage
Dec 13, 2013 | Bradford White M250t6ds-1ncww 50 Gallon...
We have changed the element and is still not working.
What water heater do you have? Question posted under BW 120V 6 gallon electric.
Element is found on electric water heater.
Igniter is found on gas water heater.
So now it get's confusing what water heater you have.... for example some 6 gallon RV water heaters have both electric and gas. And troubleshoot for that is different than electric water heater.
Copy following link for electric water heater troubleshoot resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Does tank have 2 elements or 1? Which element did you change... why did you change element before replacing thermostat? What symptoms were you experiencing before changing element?
Is this a new heater? Was tank full of water before power turned ON?
Add a comment and describe problem in detail.
Gene
Jul 29, 2013 | Bradford White M16u6ss 6 Gallon 120v 1500w...
Too much hot water, how to adjust water temperature
1) Copy following links:
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) if you have electric water heater, and too much hot water, then thermostat may be bad, or element is shorted and needs replacement. Test elements first, and if they're ok then replace both thermostats.
Jan 22, 2013 | Bradford White M240s6ds-1ncww 40 Gallon...
Burnt out element
Are you sure its burnt out? Most of the time its the thermostat. If its burnt out then just change the element. To do that all ya do is shut off the power to the heater drain the tank unhook the two wires on the element and unscrew the element and replace it with a new one. You can get new ones at lowes or home depot. Its usually the bottom that goes out first.
Jan 11, 2013 | Bradford White MS80R6SS 80 Gallon - Solar...
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
I need the basics for replacing a thermostat on a water heater...Bradford/White brand, model M250S6DS2 50 Gal, 4500 watt per element 240 voltage 50/60 hz. It keeps over heating even at lowest setting
Copy following link for replacing thermostat.
Suggest you might also want to test the elements while power is turned off, just in case the problem is element shorted to ground across metal tank to ground wire.
At least you know the 240volt power to water heater and the circuit breaker are good.
Sep 30, 2012 | Bradford White Water Heaters
Reset button triping on bradford white electric water heater
replace upper thermostat, and hi temp limit, usually made in one piece, also make sure the new stat is pushed up tight to the tank when you install it.
Dec 05, 2009 | RTO Bradford White M-1-20U6SS 19 Gallon...
Oct 08, 2009 | Water Heaters
I have an electric Bradford white water heater model MI40S6DS13 i need to know how to turn it on as my water is not heating up and the heater is has stopped working
You need to check the electric elements they are under removable covers on the front of the heater and check the fuse/breaker. May need to replace upper and lower elelments
Sep 13, 2009 | Water Heaters
Water Heaters Logo
155 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
