Question about Cameras
Is there a way to retrieve my pictures from the internal memory on a Pantech Ease
  • Cameras Master
  • 32,281 Answers
ALTERNATE WAY TO TRANSFER PHOTOS TO COMPUTER
If your photos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
Posted on Jan 04, 2013
onyeobike
  • 70 Answers
SOURCE: internal memory
If your camera is a digital set then use the USB cable to connect it to your PC.
The digital camera application suite would enable connectivity between your camera and your PC where you can access virtuall all the memories in your camera
Posted on May 22, 2009
  • 3 Answers
SOURCE: finepix a610 fuji -howdo i
The other answer doesn't work. I tried it. Okay, this is straight from the manual AND I tried it and it worked:
Press Play/playback to view pics.
Press Menu. Under playback menu, scroll down to COPY. Hit OK. Press OK for or scroll to & then hit OK for "Internal Memory -> Card" and press OK. Press Frame or All Frames. Press OK. Done! :)
God Bless. John 3:16
Posted on Mar 09, 2010
  • 241 Answers
You can only access the internal memory, when there is no card in the camera. So, turn off the camera, remove the card, connect to the computer and save the images to the computer. After checking that images are saved, you can delete the images in the internal memory, before inserting the card again.
Posted on May 10, 2010
  • 9 Answers
SOURCE: Recover pictures from iinternal memory
You may need to try some photo recovery software to rescue the pictures, here are some for your option.
Photo Recovery (for Windows)
Photo Recovery for Mac
Note: Before your files are recovered, do not attempt to save more files to the camera.
Posted on Dec 09, 2010
  • 102366 Answers
SOURCE: how do i retrieve pictures from internal memory,
You can copy pictures from internal memory to a memory card, then download them from the card.
Press the Review button. Press the Menu button, then use left/right to highlight the Review tab. Use up/down to highlight Copy, then press the OK button.
Once the card is plugged in to a card reader, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Feb 12, 2011
Recover deleted pictures
I don't believe they can be recovered after a format.
May 02, 2013 | Pantech Ease P2020 AT&T
While trying in vain to get my Pantech AT&T phone to use it's memory chip for saving camera picture I thought that maybe the problem was that the phone was set to ''EASY'. So I cha
from home screen, choose "Menu" at bottom right; swipe your finger across from right to left twice until you see the "Settings" icon. press and then choose "Phone Mode". choose "Easy Mode" and Save
Jan 08, 2013 | Pantech Ease P2020 AT&T
How can I remove battery cover on pantech ease
The back cover on the Pantech Ease is difficult but not impossible to remove. This is what works for me: First turn the phone off (for 2 reasons). Most importantly the phone should be off before you remove or replace the battery, memory card or sim card. The other reason if because it is almost impossible to remove back cover without accidentally pressing any buttons and/or the touch screen (I accidentally called someone once). Next remember The Trick is All Thumbs. On my Pantech Ease it is almost impossible to open the back cover without using Both Thumbs Pressing Down while simultaneously using Both Thumbs to Slide the cover off. It also seems to work better if you hold the phone sideways so when you are pressing and sliding the cover if sliding off to one side or the other. The bright side of having a cover like this is that the cover does not easily pop off when you don't want it like other phones I have owned in the past. Hope this solution is helpful.
Jun 26, 2012 | Pantech Ease P2020 AT&T
The phone is locked
Pantech Ease and PANTECH P2020 Is different Phones.They not same Phones,So you need to Unlock it means You can get the Code from here
Onlinegsmunlock and Unlock Your Pantech P2020 and Ease.
Jul 25, 2011 | Pantech Ease P2020 AT&T
My pantech ease won't send pictures.
There are 3 things you need to do. (1st) you need to download Pantech PC Suite from http://pantechusa.com/support/ease - Save PC Suite to Program Files on your computer. You need this software before you will be able to connect with your phone. (2nd) after you download this software you need to go to and open the Program Files folder on your computer. Then open the Pantech folder. Next open the Pantech PC Suite folder. Now open the P2020 folder. Finally open the USBDriver folder. This folder should contain something that looks like PTQH_V1_1_4583_1215_SETUP - Click on it and install it on your computer. This is a special driver that is required for your computer to be able to communicate with your phone. (3rd) you need to a USB data cord (this is different for a charge cord). I purchased a data/charger cord for mine. It is able to charge or transfer data/charge at the same time. It is as simple as that :C Note: After you install and run Pantech PC Suite the program will give you the option of connecting to your phone with Bluetooth. However, if you don't know it already - anytime you use Bluetooth on the Pantech Ease it will really drain you phone battery and battery life on this phone is not very good to begin with. Hope this helps
Jan 10, 2011 | Cell Phones
My pantech ease says that the memory is full and to delete messages, but I deleted all my messages. How do i fix it?
This phone easily records conversations. Check in your audio then go to voice recordings. I guarantee you have accidently recorded a conversation and it wiped out your memory. I had this problem and finally figured out what was causing this. Just delete it the recorded conversation and you will be fine!
Oct 08, 2010 | Pantech Cell Phones
Unlock pantech c3 rogers
can you help me unlock my pantech c3 cell phone. I dont have the master code.Pls. Thank you
May 28, 2008 | Pantech C3 Cellular Phone
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
