Question about HP Pavilion F1703 17" LCD Monitor
My computer is only 2 years old. I recently moved and hooked my computer back up yesterday. I turned it on and the monitor says no service input and automatcily goes into sleep mode. What do you think is wrong?
    Sergeant:
  • 306 Answers
The monitor is not detecting that it connected to a video card. You did not specify which computer model but if there is only one then you must ensure that the connectors are seated properly. If there is a built-in connector and a add-on video card connector also then make sure that the monitor is connected to the correct connector. When the computer is off there will be a yellow light indicator on the monitor and when the computer is booted it will turn green normally.
If you have another computer, even a laptop you can connect the monitor to that to ensure that the monitor is working and the cable has no bent pins at the connector therefore verifying whether the trouble is at the computer end or monitor. Please repost if you try these steps and still need help.
Posted on Jan 19, 2009
My Acer S200hl monitor suddenly has horizontal white lines on the screen. It gradually fades from very severe lines on the right side to virtually unnoticalbe lines on the left. Any ideas?
It's dying. Pretty much simply that, something electrical or electronic (connections from panel to panel edge connectors, connection to circuit board, or internal to a panel matrix chip). Very likely unserviceable, if under warranty, take it back for service. Only other thing, check connector under back of monitor (if it has a connector at both ends). It's an Acer monitor, they aren't terribly durable, so if it's more than 2 or 3 years old, it's probably on it's way to deadville.
Dec 04, 2013 | Acer S200hl Abd 20" Class Widescreen Led...
Monitor is about 2 1/2 years old, so its out of warranty. Display comes on for about 2 seconds then shuts off. When display shuts off, power light also turns off. When its on, display also seems dimmer...
Look for bad caps with bulging top in the power supply first, two years is about the right time for bad caps, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see so we can guide you further.
Feb 14, 2010 | Hannstar I-Inc TW-191D Monitor
Acer AL1916W about 2 years old. Turned on this
Bad caps in the power supply, common problems with 2-year old monitors, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Jan 25, 2010 | Acer AL1916W 19" LCD Monitor
External monitor on Laptop not receiving a signal
When you start your computer, keep hitting the F8 key. you will get a menu that comes up.. Choose the VGA mode.. this will stop the computer from loading video drivers and will allow you to install the new monitor.
Give that a try.. Hope it helps... let me know
May 31, 2009 | Fujitsu Siemens AMILO D-7830 Notebook
Bought Samsung 2233BW Monitor, hooked the two plugs, power and DV1 cord started computer and switched on monitor, NOTHING HAPPENED. Silly thing just unhooked Samsung and hooked back up the AOC monitor no...
You might need to go into the monitor's setup menu and select the digital input. (That's DVI, by the way, for Digital Video Input, and not DV1.) Some monitors automatically detect the input but not all of them. Obviously, this doesn't apply if the Samsung has only a DVI input. It might also be necessary to tell the video card to turn on the DVI output. You can do this with your old AOC connected and use the video setting utility supplied with the video card.
May 22, 2009 | Computers & Internet
No signal
mine did the same thing...it was on rgb...didn't have ability to plug in computer to tv as suggested previously and I kept trying to hit input button on side of tv after turning tv on..didn't work but when I pushed input button before turning on tv when i turned on tv input screen was up and was able to move input to hdmi...everything works now.
Jan 04, 2009 | Vizio L32 32 in. LCD HDTV
I have a HP pavilion mx70 monitor which is about 7 years old. Suddenly when I switch it on the screen keeps turning a 'rose' color. It occassionally goes back to normal but will constantly turn pink again....
Its the monitor. first I highly suggest upgradeing your computer. But the problem is that over time the connection port in the monitor that hooks the wire up to the computer gets worn down and the solder begins to weaken. And eventully a connection becomes loose or breaks and when the cable is at a certain angle or is moved around the screen can change colors. So if you have this problem jiggle the cable a bit or try to find a position you can put the cable in so that it doesent move around too mutch.
Jun 05, 2008 | HP Computers & Internet
Signal Cable Problem
Check the monitor plug that goes to the computer for bent pins. or try another monitor/or cable .
Jan 12, 2008 | Computers & Internet
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
HP Pavilion F1703 17" LCD Monitor Logo
61 people viewed this question
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
