My dell inspiron m5010 doesn't turn on I've tried
    Problem Solver:
  • 16 Answers
You don't turn off a machine when updating the BIOS for any reason.
the system boots from the BIOS, and if the BIOS is corrupt due to an incomplete update. it's going to be very tricky to get it back on. contact Delly on the issue. best of luck Ram
Posted on Jan 03, 2013
  • Avinay Rama Jan 05, 2013
    Thanks but before I send it to dell I'll try to flash the bioa
  • 3940 Answers
SOURCE: Dell Inspiron 2200 Ram Upgrade Help
I have worked on several I2200s and never encountered the Plate you mentioned. The vented memory door: http://support.dell.com/support/edocs/systems/ins2200/en/SM/upgrades.htm#1084976
Should rotate away from the chassis and expose the memory slot.
Posted on Mar 12, 2010
rulds2008
  • 3866 Answers
SOURCE: my dell inspiron laptop 1000 screen turns dark
This is your back light on your lcd display, To prove that have a flash light handy when it goes dark point the flash light at the screen and you should see the screen and that would mean right there you got a back light going out or the inverter that powers it is going bad. Etherway if this is not your area of work you need to tech it to a computer tech local to have it repaired.
Thanks for being considerate with your ratings and feedback today.
Posted on May 04, 2010
SOURCE: I had a Dell Inspiron
Yes, that's correct, you must replace the RAM memory module; is very easy just get a small screwdriver and open the small compartment on the backof the laptop, there is no need to open the entire cap. Also you can test each module to find out which one is failing
Posted on Dec 08, 2010
mpcheeseman1
  • 1400 Answers
SOURCE: I get 7 short beeps
Try reflashing the bios.
Here is a linl to dell
http://support.dell.com/support/edocs/systems/ws530/en/ug/html/2codes.htm#1161268
Posted on May 10, 2011
Testimonial: "Thanks for the help! I'll try flashing the bios."
  • 6771 Answers
SOURCE: hey all, i bought a new HP dv 6 with 4 gb RAM, but i upgraded the RAM to 8 gb. From the first week the laptop used to corrupt when being shutdown and doesn't shutdown unless by force (powering off
Yes! install your old ram, if you still have trouble return it to the place of purchase.
Posted on May 10, 2012
Power Doesn't Turn The Computer On
Well if isn't the power supply or the motherboard, it's a boat anchor. You can still use the TX certified sound card in a new one.
Feb 10, 2013 | Dell Dimension 8200 PC Desktop
Dell Inspiron 15R 7 beeps of death
Your best bet is to contact DELL themselves. There may have been a silent recall for your product which you don't know about, and they might repair it at their cost, But with this kind of situation, always go to the manufacturer first.
-a.
Jun 16, 2012 | Dell Inspiron M501R Phenom II X3 N850...
Inspiron m5010 won't power on
Remove main battery and try again, next! have the power adapter checked for correct voltage, if okay! sub the ram memory one at a time and test, if nothing! the DC jack in the computer is a common issue, the laptop must be dismantled down to the motherboard level to address, at this point I recommend a professional to assess.
Apr 08, 2012 | Dell Inspiron Computers & Internet
M5010 - Tested DC Jack (PC wont turn on at all) and i noticed it shows 1.7V instead of 1.9V Is it bad?
The Dell Inspiron laptop mains adapter output voltage is 19 volts.
If your adapter has an output voltage of 1.7 volts then the adapter is faulty and you need to purchase a new one.
Feb 25, 2012 | Dell Inspiron 15R Notebook
My Dell D600 laptop stopped working today. Coincidentally, I had just turned it off to try running a test on the RAM because the PC had been slow and locking up for the past month or so. Anyway, when I...
try this:
1- deattach the RAM , run the laptop without (RAM) you must hear som beeps
2- put the ram back again in the same slot
if it doesn't work try other slot
Feb 07, 2012 | Dell Computers & Internet
Hp officejet j3640 not working on windows vista. I had the printer working and when disconnected when moved it doesn't work. I've tried uninstalling and reinstalling the driver several times....
first check your is working or not
then open control panel - administrative tools - services - printer spooler services - double click the services - click stop button - next click start button - choose automatic then give the print if not coming connect other pc to ur printer check printer
Oct 29, 2011 | Dell Inspiron 531 Athlon 64 X2 4400+...
I have a Dell inspiron M5010. I have had it for about 6 months.The problem started with the keypad. At first certain letters/numbers wouldnt work at all. Then the computer had been unplugged from the power...
Sounds like a hardware fault, try taking the battery out and plugging it into the mains and see if that will start your laptop up.
Failing that have a look at the underneath of the laptop for the RAM cover...If there is 2 sticks try with only one in and if that doesn't work try just the other RAM stick in.
Try these things and let me know how you got on.
Mar 20, 2011 | Computers & Internet
I had a Dell Inspiron 15R M5010 with 2.1Ghz and 3GB RAM; when I turn it on, the display is black and after a while I heard 4 beeps, according to the manual is for RAM read/write failure; how can it be fix?
Nov 28, 2010 | Dell Inspiron 1525 Notebook
Computers & Internet Logo
119 people viewed this question
David Payne
David Payne
