Question about Coffee Makers & Espresso Machines
Siemens TK54001/001 coffee machine does not turn on, nothing but blinking lights (red green in the buttons)
I have replaced the drive of the machine by a new original part supplied by Siemens, as the problem started when too much coffee was inserted in the ground coffee insertion hole. However, there seems to either be a fault in the control module or it needs to be reset, and this I have no clue about.... Does anyone know how to reset the control module in one of these machines?
  • Denis C Jan 05, 2013
    I wonder if I should change the control module or the electric power transformer
3 Suggested Answers
espressonist
  • 1711 Answers
SOURCE: I own the Saeco Vienna
You have not mention anything about the group. Did you try to take it out and put back again. If the problem insist this mean from your description that the clunk is from group motor gears or even the motor gear it self.
In this case the machine must be desasemble in order to find out which part brocken.
If you can remove group and put back again and nothing happents then switch it of and proceed as above since it might just one gear and by replace it the machine will be ok again. However if you try something more then their is a chance to burn the motor also and the cost for repairing it will high and it will be better to thing about a replacement since spare parts are very high compare to a complete machine that might get it from special offers.
You revice all above and if you need any further asistant you can coment back.
ood luck
Posted on Sep 02, 2010
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
problem is overheating at a single point in the bottom of the milk container. Try cleaning the milk residue after each time you use it and the flashing red light disappears. This is a design fault. Nespresso are happy to keep marketing the Citiz but there is no fix - so the Nespresso "mess free" coffee machine is a bunch of flannel - good coffee all the same!
Posted on Sep 05, 2010
Green power light only on trevi exclusive
When power is turned on, the coffee selection button should blink during warming up. If it is not blinking then the following i possible:
1- The electronic sensor is bad. It is clamp mounted on the boiler to sense temperature and send message to control board to turn the heating off when it is ready to make espresso. The blinking light will be fixed to display this.
2- The heating element on the boiler is bad and not heating. The electronic sensor cannot relay any temperature as it is.not sensing the heating.
3- The electronic control board is bad and not sensing the temperature.
The machine should be opened up to test the sensor or the neating elements, and replace what is bad..
Aug 31, 2014 | Spidem Trevi Automatic Espresso Machine
Saeco vienna plus red solid light cannot prime water line
Make certain the line from the water resource is cleaned and not obstructed. If the pump fails to move the water from the reservoir to the heating tank, then the pump needs to be replaced.
Mar 25, 2014 | Saeco Vienna Espresso Machine
Saeco Eclipse stopped functioning
Have you solve your problem with Odea. Mine is new out of the box and not working at all. Red light blinking, manually prime it and so far only tree cups of coffee. After priming it the green light was solid and could make 3 cups then stopped. Any advise greatly appreciated.
Dec 12, 2011 | Saeco Odea Go
I have the Vienna Superautomatica. It turns on, the green "on" light ilights the red light blinks on and off. The grind button has no effect. Nothing is clogging the grinder - sometimes there...
Hi
Blinki9ng red light usually something is not in place. The water tank empty. grinder empty or cloged, the brew unit not seated, dredge drawer not in place, or the usual cluprit is the drip tray. There can be something behind the drip tray that is keeping it from seating ( it has to lock into the 2 holes in the bottom of the base) Try to push the drip tray in and down and see if it will work.
May 16, 2011 | Saeco Vienna SuperAutomatica Coffee...
My mr coffee esspresso machine has to lights red and green they are both blinking and i cant make coffee please help
This is actually a fairly common problem with many coffee or espresso makers. When both lights are blinking just shut the machine off, wait about 5 seconds and turn it back on. It should work fine. If not, give another shout out.
Feb 19, 2011 | Mr. Coffee ECMP40 Espresso Machine
Flashing lights on my saeco italia espresso machine
I had the same problem, two green flashing lights with one red (water) all 3 would just keep flashing and not turn solid. No coffee can be made or hot water. I could not pump prime. The problem was the steam wand was blocked with old milk residue. It needs unblocking or you will never pump prime. I could not unscrew the steam wand...so I let it sink in a glass full of hot water for a few minutes and then turned the water knob counter clockwise to push out the softened residue. After that, everything was good. When water started flowing out of the steam wand, the red light turned off and the green lights turned solid. The obvious answer to why you can't pump prime is there is a blockage somewhere and best to start with the steam wand. --Mabada
Feb 22, 2010 | Starbucks Saeco Italia Digital Barista...
Put in water turn on green light is on nothing happens
The green light is used for setting an automatic brew time. Turn the brew button until its red and your coffee will begin brewing.
Oct 24, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Status light is red
Hi, Based on your post/description, the Siemens AP/Router is at fault. This could have been brought about by lightning, power surge, plain hardware failure or system/software error. The red status light - on indicates an error (on the firmware)(blinking during start-up or when firmware is being downloaded/updated); WAN light blinking green - data transmission to/from your ISP (it is also possible that the router is trying to download corrective software or firmware update). Suggest you let it run for sometime just in case it is really downloading/upgrading firmware. If full reset of the router doesn't correct the problem, you may have to replace the unit. Good luck and kind regards.
Aug 26, 2007 | Siemens SpeedStream 2624 (SS2624) Wireless...
Coffee Makers & Espresso Machines Logo
95 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
