Question about Plantronics CS530 Wireless Headset System Lifter
How to reset the CS530 headset
I cannot answer the phone directly from the headset - I have to punch the headset key on the 7965 phone
2 Suggested Answers
  • 92 Answers
SOURCE: how do I answer call with headset
just press the button on the side
Posted on May 20, 2009
Bad echo in ear piece while talking
You can try adjusting the volume and see if any results. Try to verify if it is a hardware defect by using a Bluetooth piece and if you get better results.
Nov 08, 2013 | Plantronics CS530 Wireless Headset System...
Registration key for power mp3player for nokia e63
I am sorry, but I can't answer your question. Our specialty is headsets, not phone or MP3 players.
Good luck from Headsets Direct!
Nov 19, 2011 | Nokia E63 Cell Phone
Unable to answer or hear thru bluetooth
First, remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Also you want to reset the headset. The attached user guide for the Plantronics Explorer 230 on page 7 will show you how to turn off / on the headset and on page 4 will walk you through the pairing process. Remember to remove any previous bluetooth connections from your phone.
Plantronics Explorer 230 User's Guide
Oct 03, 2011 | Plantronics Explorer 232 Bluetooth Headset
I have added cisco 7916 expansion module to 7965 cisco phone.Now when i started the phone,phone works but expansion module screen shows cisco logo and lights continuously flash.
I know it may be late (definitely late), but have you defined in the CallManager, that your phone has a "side card"? If CallManager does not know that it has to push an additional firmware to a particular phone, it will not work.
Good luck,
Mike ' CCNP, CCVP, CCSP, CCDP, MCSE, etc.
Headset Adapter Co.
Headset Adapters for office phone system
Mar 21, 2011 | Cisco Systems - Unified IP Phone...
How to reset my headset bluetooth CSR-b5?
To reset, power your Toshiba Bluetooth device off and then back on after approximately 5 seconds. This type of reset often resolves main issues. On most models, this is accomplished by holding in the multifunction key normally used for answering and ending calls, until the headset powers down. Hold the key in again until the device powers back on. Test for the resolution of the issues you are experiencing. If this proves to no avail, then remove the pairing between your headset and phone and repeat the previous steps. I hope this answers your question.
Mar 03, 2011 | Toshiba WIRELESS STEREO HEADSET BLUETOOTH...
I can't answer the phone from my headset and once i'm finished talking I can't disconnect I have to use my phone to answer and disconnect. It was working fine but I'm not sure what happened
It sounds like the wireless link between the phone and headset has been compromised. Remember that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again. Purge from the phone any pairing information for your Voyager Pro headset and pair it again to your phone, following carefully the instructions on the link below for the Plantronics Voyager Pro.
Plantronics Voyager Pro User's Guide
Jan 05, 2011 | Plantronics Voyager PRO Bluetooth Headset
BH105 is switched on, green light is blinking, but Nokia 5310 phone is not able to detected it.
U must RESET the Headset.
Switch OFF the Headset.
HOLD the answer/end key + power key (for about 5 second).
Red + Green indicators lights start to alternate.
Then Ur Headset is RESET.
Connect / Pair it with your Mobile as normal.
Nov 02, 2010 | Nokia Bluetooth Headset BH105
My nokia BH-215 is not pairing. The green light blinking continuously.
hello, clear setting or reset, to delete the pairing from the headset , press and hold the power key and the answer/end key (for about 5 seconds) until the red and green indicator lights start to alternate. to reset the headset if it stops functioning , even though it is charged connect the headset to charger while you press and hold the answer/end key , Ensure that your phone is on and the headset is off.press and hold the power key (for about 5 seconds until the green indicator lights start flash quickly. activate the bluetooth feature on thr phone, and set to search for bluetooth devices. select the headset from the list of found devices . enter the passcode 0000 to pair the phone. hope it works
regards
shaun
Oct 10, 2010 | Nokia Consumer Headset
Pairing my bluetooth with my chocolate
I wanted to answer this for anyone else who found this question using a web search. The answer is 0000 (four zeros) when asked for the pass code. It's the default code. And your lock code (until you change it) is by default, the last four digits of your phone number i.e. 555-444-5555 (5555 would be your code)
Jan 13, 2008 | Radio Communications
Plantronics CS530 Wireless Headset System Lifter Logo
433 people viewed this question
Top Plantronics Lands Phones Experts
Andrew Taylor
Andrew Taylor
Are you a Plantronics Lands Phone Expert? Answer questions, earn points and help others
