Question about Compaq Presario SR1000T (568657) PC Desktop
Starting proplem i have a starting problem on my computer , when i start my computer one beep sound will come and then the cpu inside fan also not work properly pls give me a good answer
    President:
  • 2,692 Answers
The one beep is normal . If the fan is not working on the CPU , replace the fan or oil it The CPU can go only a second or so without the fan working. Some models(BIOS )will not allow the computer to start if the fan is not working. Start there.Check out the link below:
http://www.computerhope.com/beep.htm
Posted on Jan 19, 2009
Trys to start but doesnt
The bios keeps track of all mechanical s pre-boot and post-boot. Beeps most generally mean a bad stick of ram or the ram is not seated firmly in the slot. The other issues are bad CPU or the CPU fan has stopped and the bios shuts the pc down in either case.
Apr 21, 2014 | Acer Computers & Internet
H57h-am2 beep never stop
A computer will alert you to trouble through beeps and other sounds. If you have a problem with the operating system, the computer gives you different beeps when you start up the computer. You hear the beeps in different scenarios, such as three long beeps or one long and one short beep. These beeps can mean different things depending on what computer model you have. A siren sound on a computer means the central processing unit is overheating. This is true for any computer. When the CPU gets hot, it makes a siren sound warning you that your computer is overheating. At that point, the computer should be turned off to prevent damage.
Open the computer and clean it if you notice a lot of dust inside. You can purchase canned air at most stores. Follow the instructions on the can. Check the instructions in the manual that came with your computer on how to clean the inside of it. If there is a lot of dust, that alone can cause the heat sink to overheat. Verify the CPU heat sink is properly installed and the power is connected. Consult the manufacturer's instructions on how to open your computer and find the heat sink. It should give you instructions on how to check that it is properly installed and connected. You should find it in the middle of the motherboard. Make sure the fan is working. Your CPU will overheat if the fan is not working properly. Refer to the manufacturer's instructions for your computer for instructions to check the fan. Replace it if it is malfunctioning.
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules make sure that your RAM modules and Cmos battery are securely seated on some motherboards Cmos batteries are soldered in Test all power and data leads that attach from motherboard to your hard drive IDE SATA make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40 pin ide it will be the first to fail check the graphics card is seated properly with no dust in the socket you might have to remove it to check for dust reinstall it restart your computer the found new hardware wizard should activate a computer needs power and data to travel through every working device and to its continue its cycle and to have and end to function make sure all leads that are attached to your drives dvd\cd and floppy drive have secure make sure the connections and are not faulty or just replace them they could be faulty a computer needs all electric current and computer data to travel to and through every working device and have an end to work properly so any faulty leads will end up with a computer error also check the keyboard for secure dust free connection ps2 and or usb Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
Mar 17, 2013 | HP Pavilion 7955 PC Desktop
My computer suddenly lost power and now it won't even turn on.
replace the power supply of your cpu check if the blower fan is spinning during power on it means that your power supply is good if not replace the power supply with a new one
Sep 12, 2011 | Dell Inspiron 537 MT Desktop Computer
I have a question regarding my cpu dell inspiron..Heres my problem: 1. when i start my pc sometime the fan is spinning then suddenly its stop adn run again and then I dont hear any beeps form the board. I...
There is a circuit on the motherboard that detects the ambient temperature of your computer. Your CPU fan has 2 speeds - if it detects the temperature inside your desktop getting hot, it will switch the CPU fan to hi-speed. If you removed the memory and powered on the computer and don't hear any Beep codes then you probably have a problem with the the motherboard and it needs to be replaced. disconnect cables to CD/DVDdrives. Look at the USB ports to see if any are damaged.
Aug 14, 2011 | Dell Inspiron 530s Desktop Computer
WHEN I TURN IT ON, THE COPUTER STARTS BEEPING
that sounds. are memory problem related :
Beeps Meaning 1 long, 2 short Video adapter error: Bad or improperly seated video card Repeating beeps Memory error: Bad or improperly seated RAM 1 long, 3 short Bad video RAM or video card not present High-frequency beeps Overheated CPU: Check fans Repeating high/low beeps CPU: Improperly seated or defective CPU
May 10, 2010 | Computers & Internet
I have a Lenovo A61 Thinkcentre that is about one year old. I am now hearing a fairly loud noise that comes and goes. When the system starts, the noise appears and lasts 10 - 20 minutes, then disappears....
Ok it still sounds like an fan. look for fans, one in power supply, one on cpu, one in case(frount or back), one on video card. before you start from cold unplug the fans that you can. and stop the one in power supply. then if there is no nosie you have to start pluging them back in till you hear the noise. **NOTE!!** don't run it long without fans!!( 40 secs) is long enough..
Feb 26, 2010 | Personal COMPUTER - LENOVO THINKCENTRE A61...
Computrer beeps several times when it starts
Depending on beep pattern it is trying to tell you that you have faulty memory or a graphics card problem.(normally)
If you have been inside your case / moved pc directly before this. Then suggest you gently reseat graphics card.
If you have added memory remove it, reseat original mem.
Dec 31, 2009 | Dell Computers & Internet
No signal to monitor , checked with another source to monitor it is working fine , not sure what to do next
Have you checked if the cable is well connected to the CPU and Monitor?
Also loose the CPU case and check the VGA card if it well fixed to the board.
If a CPU ram is not well fixed to the mother board, there would never be a display on the monitor.
Lastly, check if electric current is interring the CPU. You can know through the power pack fan at the back of the CPU. And check power cables and socket.
Best wishes.
Dec 28, 2009 | E-Machines T6414 (RBT6414) PC Desktop
The desktop won't reboot. The power light stays yellow. I hear a fan running, but the monitor says no signal.
If your fan runs and the hard drive spins up, then you have a video card problem.
I'd do this: Disconnect everything inside the case but the CPU, memory, and video. Now try to boot. Also observe the fan on the CPU--does it spin?
If this fails, then your video has probably gone bad. Also--does your computer usually give you a "beep" when it starts up? If so, is it giving you a beep now? If not, you're failing the hardware startup test (POST).
So, your problem may be the video card. If your video is part of the motherboard, then you need to replace the motherboard.
Oct 01, 2009 | Computers & Internet
Compaq Presario SR1000T (568657) PC Desktop Logo
Top Compaq Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Carlos L. Burgos
Carlos L. Burgos
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
