Question about Exercise & Fitness
Proactive fitness cardio trainer treadmill will not start
I have a proactive fitness cardio trainer, Switched it on from the plug socket and the lights came on but when I went to press the start button all the lights turned off. I thought I had blown the fuse so changed it but still the lights did not come on. However the main light at the front of the treadmill is on. Any ideas how to get it to work..? Thanks
SUPERMAN_B_1
  • 294 Answers
SOURCE: total blackout...neither motor or display
IS THE SAFTY CARD INSTALLED ? MOST TREDMILLS HAVE A SAFTY LOCK OR CARD THAT HAS TO BE IN OR READING FOR THE SYSTEM TO START
Posted on Apr 12, 2009
  • 16 Answers
SOURCE: I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Posted on Apr 14, 2009
maxtreadmill
  • 832 Answers
SOURCE: treadmill is plugged, lights are on but does not work
The standard calibration procedure to calibrate an Icon treadmill is done by holding down the speed up and stop keys while inserting the safety key or putting the key in place (if magnetic). If your keypad is not responding, because your treadmill keypad has failed or the console computer has failed. In these cases, the keypad can be replaced in limited instances or the console has to be replaced.
Now if you are able to get in calibration mode then Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, This means that it passes the EPROM test. If it shows ff or 2f your upper console will need to be replace.
Next step if eprom passes: Press either incline key and the incline will calibrate automatically.
DO NOT STAND ON THE WALKING BELT.Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). if you get the the number to 85 and the belt does not move , on the lower board you will see a like flicker that would be the speed control this tells you that the upper console and terminal cable is good ,but lower board defective.
Posted on May 20, 2010
  • 34 Answers
SOURCE: will my ifit treadmill card work in an incline
Technically, the Incline Trainer and the treadmill are two different type of machines. The incline trainer raises much higher so the card that is designed for the treadmill will not work on the incline trainer unfortunately.
Posted on May 24, 2010
  • 5370 Answers
SOURCE: Horizon Fitness Treadmill - Quantum
Check the treadmill "continuity" , the treadmill connections correctly grounded. If that is checked ok then either the outlet itself is bad .Try plugging the treadmill on another stronger outlet, such as a kitchen outlet..But if its still shorting out and blowing the fuse then its internal motor problem.The motor or its wiring is got weak,so when you press the start button the motor starts and treadmill turns off and blow fuse.--------- This should help.Thanks.Helpmech.
Posted on Jan 23, 2011
When running get error message your pressing on the board too hard?
RUN the software calibration for easy diagnostic and fix it. Read you owner manual and follow the steps.
God bless you
Nov 13, 2013 | Life Fitness Lifefitness 9100 Hr Treadmill...
Proactive fitness trainer lost all power fuse ok
see the video and proceed according. God bless you
and see the block diagram. attached.
Dec 12, 2012 | Exercise & Fitness
In what way is an elliptical trainer different from a treadmill?
Treadmills have a moving belt while elliptical trainers have two foot pedals guiding movement - making it more controlled and safer. Elliptical trainers also have handles, in which the user has the option to move their arms in opposition to their legs to better control movement.
Aug 02, 2012 | Exercise & Fitness
What is an elliptical trainer?
An elliptical trainer is a stationary machine used to stimulate the action of running, stair climbing, or walking. It puts barely any pressure on your joints giving you a great non-impact cardio workout that can vary in intensity levels.
What is ''Cardio Trainer'?
Using the Cardio Trainer application for your smartphone, you can map your run, hike, bike, or walk in real-time. This free application uses GPS to map your coordinates and speed, and you can upload this information to your Facebook page by installing the Cardio Trainer Facebook app. The instantly available information, easy tracking, and ability to set time and distance goals means that you can challenge yourself to go further and faster, and share your successes with your friends on Facebook.
Sep 20, 2010 | Facebook Apps
Landice L7 motor voltage in wet conditions
What do you think--what changes when something happens???
Sep 19, 2017 | Landice L8 LTD Cardio Trainer Treadmill
Apr 13, 2009 | Exercise & Fitness
Landice L8 Cardio trainer giving messages on readout P4 and L5
I've definitely never seen "P4" on a Landice before so I'm not entirely sure on that one. The other issues seem like they might be associated with stuck keys on the console. It's a very common problem if you have it in a humid area and/or it gets sweat on it during the work out. Being that it's a Landice, you should have a part warranty on it. Have you contacted them?
Jun 15, 2017 | Landice L 7 Club Cardio Trainer Treadmill
Exercise & Fitness Logo
233 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
