Question about HP Officejet 6310 All-In-One InkJet Printer
HP Officejet 6310 scans once but then says scanner failure
I've uninstalled all the HP software and reinstalled. Rebooted in between. Scanner scanned once but fails with message scanner failure. Also dialog pops up saying communication error. Any ideas?
  • jennifer_epp Jan 19, 2009
    I should add, we are using Winxp. We've tried scanning with the Scan To button on the printer as well as from software applications. Going through the Windows Scanner wizard, and using the HP Solution Software to scan. All result in the same failure message.
    Scholar:
  • 97 Answers
that error message is nothing to do with the software part, it actaully hardware issue try the following,
1) unplug the machine and connect it to wall outlet directly,
2) unplug the power cord from the printer and press and hold ON for 1 min and release the ON button and plug it back..
3) Disconnect the power cord from the product.Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons and if printer turns off, turn it back ON and wait until it cmopletes its instialization and if still persists, it a hardware failure...............
regards,  raj_p5983
Posted on Jan 22, 2009
Hp All in one 6310 Unable to Scan no computer connection
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer ONLY WHEN PROMPTED, to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken. Use the priint to calibrate the scanner and check if detected. If not there is issues on the motherboard.
Oct 26, 2011 | HP Officejet 6310 All-In-One InkJet...
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
Aug 12, 2011 | HP ScanJet 3570C Flatbed Scanner
Hey. I have a HP Officejet d135 All i One, and running Win7 on my computor. The scan function on the device does not work. The display on the printer/scanner reads "Scanner Failure. The scan function...
Go into Device Manager and double click on USB Print Support. In Driver tab, click uninstall. After uninstall, power reset the computer. Once computer turns back on, it should automatically start the re-installation process of the printer. Then you select let windows do automatic search for the proper driver.
Mar 01, 2011 | HP OfficeJet D135 All-In-One InkJet...
Can't scan- Refer to device documentation to
Try using widows paint. Look in windows accessories off the start program menu. If you open windows paint, look for open file from "Scanner or Camera". Most likely you can get the scanner to work again in Vista. Otherwise...try Vuescan scanner software. I think you can get a free trial period online and it should also work. You'll have to pay for that if you like it.
May 19, 2010 | HP OfficeJet 6310 All-in-One Printer...
How do I get my HP 6310 to scan---free download etc?
To scan using your HP Officejet 6310, you need to install the full feature driver software.
Full feature driver software can be downloaded from the following web link:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1119598&lc=en&cc=uk&dlc=en&lang=en&cc=uk
Also please perform the following steps to scan using your unit:
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_rule=31271&tmp_task=useCategory&lc=en&dlc=en&cc=uk&lang=en&product=1119598
:) Dr Tony
Apr 17, 2010 | HP OfficeJet 6310 All-in-One Printer...
I have hp officejet 6310 all in one, but the
Please visit- http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=2093&lc=en&dlc=en&cc=us&product=1119598 and download the full feature drivers and save it on your computer.
2. Uninstall the existing driver from program and features under control panel.
* To search for progam and features, Click on start or the windows vista logo on left bottom, click on control panel, clck on program and features and then unistall the printer driver.
3. Power off the printer and unplug it from computer.
4. Install the printer from the saved drivers and plug it when asked.
Restart computer once the installation is compete and hope the scan would work after this.
Mar 24, 2010 | HP OfficeJet 6310 All-in-One Printer...
"NO SCAN OPTIONS" in HP Officejet 6310 all-in-one
You need to install the software and driver for the version of windows that is on the new computer.
Link to you model printer/scanner below:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1119598〈=en&
Mar 19, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP 6310 Scanner problem
Install these drivers and "controller" software from HP:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&os=2093&product=1119598&
Feb 28, 2009 | HP Officejet 6310 All-In-One InkJet...
Scanner saves multiple pages separately, need saved as one
hi,
thats very easy, i believe so ur trying to scan from the printer itself becoz that happens if u try to scan from the printer itself, instead of that use the solution center software.
if u have installed the complete software which was provided by hp, u will a icon on ur desktop called solution center, click on that and click on the scan document button on it and u get a pop window in that select the file type as PDF and click on scan at the bottom of the window and once it completes the scan, it will give a message do want to scan another page, click yes and go ahead with that........
i think i have answered ur query..............
Regards,  raj_p5983
Jan 21, 2009 | HP Officejet 6310 All-In-One InkJet...
Office Jet K60xi Scanner Failure
Try HP's web site suggestions first.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01077492&cc=us&lc=en&dlc=en&product=61736
If your sacnner still fails to function, uninstall everything for the Officejet through add/remove in control panel. (Power off printer before uninstalling).
Go to Hp's web site. http://welcome.hp.com/country/us/en/welcome.html#Support
Step 1. Click, Download drivers and software (and firmware).
Go to step 2. For product, type in Officejet k60xi .
Power on your printer. (Wait for printer to fully power on).
Click, Start Detection>> button.
Allow HP to scan your system & install the latest software.
Follow the on scren instructions. (When finished, restart your PC). Test your scanner by scanning something.
If your scanner still fails to scan, you may be missing basic HP files loaceted in windows system & windows system32 folders.
(These missing files were not installed during your install of windows). Not your fault.
Apr 25, 2008 | HP OfficeJet k60xi InkJet Printer
HP Officejet 6310 All-In-One InkJet Printer Logo
554 people viewed this question
Ben Johnson
