Question about Whirlpool Kitchen Ranges
Oven element started to spark
Whirlpool Range Model RS386PXB, oven element started to spark, the element had one spot that appeared it was being welded together, a sharp bright light. I shut the oven off and the one spot on the element continued to spark and glow red.
I shut off the circuit breaker to the range.
I later turned the circuit breaker back on to use the cooktop but the oven started to warm, the controls were off for the oven, what could be the problem? I know that the element needs to be replaced but is there more to this than I know?
I get a start? when pressing start and oven wont come on my whirlpool electric oven
Terrence, Could be defective oven element, control board, etc. have a good tech. diagnose and estimate repair. Check the attached links trouble shooting,instruction and guides for electric oven, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Whirlpool Oven Won Turn on
Troubleshooting Guide for Whirlpool Electric Range
http://www.partselect.com/Repair/Range-Stove-Oven/Will-Not-Start
Jul 29, 2016 | Whirlpool Ovens
I have Whirlpool RBS305PDB16.The bottom broiler element will not heat up only the top.Any ideas on the problem?
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
Nov 16, 2012 | Whirlpool RBS305PD Electric Single Oven
Heating element burned out (literally!)
No you are fine...just replace the element, they will fry like that sometimes...
Check out this tip that I wrote about this problem...
Oven Problems Electric Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Apr 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Oven erupted like a blow torch why?
The broiler element burned into. Look at the top element and you will see a spot where it is rough, melted or burned. Replace the element by removing the two screws at the back of the oven and pull the wire out a little and unplug the element and plug the new on it.
Dec 26, 2009 | Kitchen Ranges
I have a Whirlpool AKZ451 built in oven that is not reaching temperature. The oven element appears to be working, could this problem be the oven temp sensor?
yes, or the oven control itself,make sure also to closely inspect the element itself for any "HOT-SPOTS" where its getting a high resistance area and not passing all the current needed to heat the element
Oct 29, 2009 | Whirlpool AKZ159IX Oven
Less than 5yrs. old...sensor replaced, oven does
check your element for a hi resistance or hot spot it will be pitted and discolored and its ready to break there,not enough current can pass through that spot to heat-up properly
Jul 10, 2009 | Whirlpool RS610 Electric Kitchen Range
Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
Feb 25, 2009 | Ovens
Getting a error code F3E2
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven. This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board. If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe. If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly. I recommend calling a service technician to diagnose and repair this oven failure. If you want to attempt to diagnose and repair this failure yourself, resubmit your question with additional details.
Good luck and please rate FixYa!
Dec 23, 2008 | Whirlpool RF365 Electric Kitchen Range
i dont know want is wrong with it when i turn the oven on it keeps saying e2 and f3 i dont know what that mean please help me one on .... :(
Dec 05, 2008 | Whirlpool SF357 Gas Kitchen Range
Kitchen Ranges Logo
3,685 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
