Question about Refrigerators
Manual for a heller ppr240 fridge
Have got 2nd hand heller fridge similar to a ppr 240 one, has its temp controls outside at top of fridge,am unable to adjust the temp control ,seems to have a mind of its own . Tried to put it on a 6 setting but due to outside temps when opening and closing fridge it was going up to 12- 13 and started to freeze, anyway of sorting out how to to regulate it
ngfam1
  • 639 Answers
SOURCE: replaced single digit temp control
WHAT'S YOUR QUESTION????????????????????
Posted on Aug 28, 2008
SOURCE: cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Posted on Sep 12, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My refrigerator freezes everything
Not only the thermostat needs to be considered but the adaptive defrost board and the air damper between compartments. Something happened yesterday and my solution was changed to a clarification request. Sea Breeze
Posted on Nov 18, 2009
heatman101
  • 43501 Answers
SOURCE: Hotpoint FFA70 Fridge Freezer, the fridge is
Check out these tips...they can help you figure out whats going wrong...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Aug 12, 2010
  • 116 Answers
SOURCE: I have a stainless GE profile PSS26SGPASS side by
HI has the temp held steady at 28? And do you notice if the fan in running in the freezer if you open the door do you hear a fan running, if you do not, then the problem is a bad control board located in the rear of the refigerator behind an small access panel this control board runs about 175-200.00 to buy.
Sean
Posted on Mar 26, 2011
I see the usual reply is go to Heller Im asking because there is no answer at Heller. I need a manual for a Gusty 10CO portable air con. I have searched Google ALL DAY.I need a better reply please
I did a google search and found only one link (below). I don't know if it is a con or a genuine manual.
In the absence of a dedicated manual you will have little choice but to gather information of a more generic type and apply it to your air-con. I expect most of them use the same working principle and similar component arrangement.
http://dattorrent.com/search/heller+portable+air+conditioner+model+gusty10co+m
Apr 01, 2017 | Heating & Cooling
Jams when duplexing on ricoh mp161
if you are talking the origanal in the DF check for staples or ppr clips inside the DF, or if it is jaming the copies try fresh ppr clean the rollers.
Apr 08, 2010 | Ricoh Aficio MP 161SPF Color Copier
The fridge is not cold
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Mar 24, 2010 | Whirlpool ET8RHMXKQ Top Freezer...
Heller fridge keeps freezing up at the rear of the fridge
Model # would help!. The symtoms relating could be of a # of issues depending on the design (model #). Cold control, defrost issues, non or slow moving evaporator fan, slight pressue loss (undercharge), partial restriction, extra ambiant heat.
Ric
Mar 09, 2010 | Refrigerators
Fridge section is too cold causing food to freeze
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Dec 03, 2009 | Refrigerators
We have a Dometic 2310 - freezer works well, fridge seems inconsistent. Top of fridge gets very warm. Is it helpful to add a cooling fan?
Sep 24, 2009 | Dometic RM2652 Refrigerator
Temperature setting
The fridge should be just above freezing, maybe 2 or 3 degrees celsius. The freezer should be around -15 degrees celsius. The outside temp doesn't matter as far as the settings go.
Sep 09, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Refrigerator side of hotpoint side by side quit working - replaced the control panel and it is still not working. the crisper drawers seem to be colder than the refrigerator part, but it is still not cool...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 30, 2009 | Hotpoint HSS25GFP Side by Side...
Model # FRS23h5afb8- seems to be freezing all the food- milk, oj, mayo - i first thought it was anything on top shelve but not the case-------
Aug 21, 2009 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
